Question about Krups Small Appliances Espresso Machine
Bunn coffeemaker leaking
My coffee maker is leaking water from underneath
  • 189 Answers
Is this a Bunn or a Krups-you have both listed.
Posted on Jul 01, 2010
My Bunn coffeemaker is leaking water after it stops brewing and the coffee doesn't seem to get as hot as it once did. It also only gives back 4 cups for a 6 cup brew.
if you unscrew the top there's a rubber seal in there that you might have to replace that causes the leaks. also clean your coffee maker regularly with vinegar.
my husband had to replace the seal in ours 4 times but after owning the same Bunn for 20 yrs it was time for a new one
Jan 18, 2011 | Bunn 10 Cup Home Coffee Brewer
Hot water leaks out the bottom when filling resevior with water of my Bunn coffeemaker GR10-B
If you will call 800-352-2866 with the model and date code and we will be able to help you resolve your issue.
Jul 01, 2010 | Bunn GR10 Coffee Maker
I have a Bunn coffeemaker and it is not that old. It leaks from the bottom when you fill it with fresh water for a new pot of coffee. The number is NHB code date is 204305. Do you have any ideas?
The brewer probably has a bad seal or gasket. By the date code, your machine is 5 years old. If you call Bunn Customer Service they will be able to offer you an exchange of your old brewer for a new one at a reduced price.
May 29, 2010 | Bunn NHB Coffee Maker
Water seeps from under the bunn coffeemaker about 1 cup of water has to be dried off countertop, can this be repaired?
If you can provide the date code located on the bottom of the brewer, I will be happy to offer a solution to your leaking problem.
Jan 09, 2010 | Bunn NHB Coffee Maker
Our Bunn VPR coffeemaker takes a LONG time to heat up the water. If we don't wait several hours between pots of coffee, the coffee is luke-warm at best. Does this sound like a heating element or...
We left vinegar in the coffeemaker overnight. Seems to have done the trick - water is heating up now after 20 or so minutes instead of several hours.
Jan 05, 2010 | Bunn VPR Coffee Maker
Unable to remove our sprayhead from our Bunn NHB Coffeemaker
You might try putting a butter knife underneath the sprayhead to remove it. If this doesn't work, then please contact customer service and request a tool that can be provided to remove the sprayhead.
May 14, 2009 | Bunn NHB Coffee Maker
Bunn coffee maker leaking from underneath the bottom
Please get the model and the date code from the bottom of the machine and contact customer serivce. Depending on the date code, there might be a seal kit available or the machine can be replaced at no cost if 3 years old or less. If it is over 3 years old and the seal kit isn't available, the machine will be replaced at a reduced price.
Apr 29, 2009 | Bunn 10 Cup Home Coffee Brewer
We find water under the coffeemaker in the morning.
Sounds like a leaking water pipe from the water source, unless you have a over temp heater and this results in steam and dripping.
Mar 30, 2009 | Bunn VPR Coffee Maker
Water leaking
The silicon seal inside the coffee maker tends to disintergrate. Bunn Inc. does not sell parts for the inside of the coffee makers, but a seal kit can be purchased through a small appliance repair center or repaired for a small cost. Kit is about $8.00 at most places.
Oct 24, 2008 | Bunn Cuisinart Coffeemaker: Pour-Omatic...
Bunn coffeemaker
If you still have warranty on the machine take it in to the nearest service center.
Its probably a lose pipe in the machine. so if you dont have warranty left just open it up and look for lose pipes and reconnect them.
Jul 14, 2008 | Bunn Cuisinart Coffeemaker: Pour-Omatic...
Krups Small Appliances Espresso Machine Logo
436 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
Billy Mac
cyfred
Level 1 Expert
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
