Question about Microsoft Windows 98 for PC
My PC wnts Windows 98 second edition CD what is it? as i have only one installation CD
For loading Cirrus 7543 display driver i need above said CD. From where i can find it?
  • Microsoft Master
  • 2,794 Answers
Windows 98 isn't supported anymore. Are you using a different operating system on your computer?
Posted on Aug 09, 2008
I bought jet flash 500 pendrive model TS4GJF500 I HAVE USE WIN 98 MY PEN DRIVE IS NOT DETECTED WHAT CAN I DO PLEASE GIVE ME A SOLN
Hi..
Windows 98 does not support Plug n Play Devices. So you have to download appropriate drivers from Microsoft Website. Though Windows 98SE ( Windows 98 Second Edition ) thought to be support USB Mass Storage Drives fairly, these drivers are not pre-installed with OS. You have to download Service packs to install these drivers.
Since Windows 98 have TWO versions, we have to download corresponding service packs .
You can
Download Service Packs for Windows 98 Here
Download Service Packs for Windows 98 SE (Windows 98 Second Edition) Here
To Know how to install these, please click on
How to install on Windows 98
How to install on Windows 98 SE
You can find more details about this issue on this page
Thank You.
Mar 24, 2011 | Operating Systems
How to instal file 'asms The file 'Asms' on Windows XP Professional Service Pack 2 CD is needed" when installing WinXP Pro,
When you install Microsoft Windows XP, you may receive the following error message:
[Files Needed]
The file 'Asms' on Windows XP Professional CD-ROM is needed. Type the path where the file is located, and then click OK.
This issue may occur if the Setup program cannot communicate with the CD-ROM drive.
To resolve this issue, use the appropriate method for your computer.
Hard disk formatted with FAT or FAT32 file system
If the hard disk is formatted with the FAT file system or with the FAT32 file system, follow these steps:
Use a Microsoft Windows 98 Second Edition or Microsoft Windows Millennium Edition (Me) Startup disk with CD-ROM drivers to restart the computer.
Copy the Xcopy.exe tool from the Windows 98 Second Edition CD-ROM, the Windows Millennium Edition (Me) CD-ROM, or the hard disk to the Windows Startup disk. To do this, use the appropriate method.
Insert the Windows 98 Second Edition CD-ROM in the CD-ROM or DVD-ROM drive, and then at the command prompt type the following lines, pressing ENTER after you type each line, where cd-rom is the drive letter of the CD-ROM or DVD-ROM drive:
c:
copy cd-rom:\win98\smartdrv.exe
copy cd-rom:\tools\oldmsdos\xcopy*.*
Insert the Windows Millennium Edition (Me) CD-ROM in the CD-ROM or DVD-ROM drive, at the command prompt type the following lines where cd-rom is the drive letter of the CD-ROM or DVD-ROM drive, and then press ENTER after you type each line:
c:
copy cd-rom:\win9x\smartdrv.exe
extract cd-rom:\win9x\win_17.cab xcopy.exe /L c:\ xcopy.exe
extract cd-rom:\win9x\win_17.cab xcopy32.exe /L c:\ xcopy32.exe
extract cd-rom:\win9x\win_19.cab xcopy32.mod /L c:\ xcopy32.mod
Hard disk
At the command prompt, type the following lines where drive is the drive letter of the hard disk where Windows is installed, and then press ENTER after you type each line:
c:
copy drive:\windows\smartdrv.*
copy drive:\windows\xcopy*.*
Eject the Windows 98 or Windows Millennium Edition (Me) CD-ROM, and then insert the Windows XP Professional CD-ROM.
Copy the I386 folder and all its subfolders to the hard disk. To do this, type the following lines at the command prompt where cd-rom is the drive letter of the CD-ROM drive, and drive is the drive letter of the hard disk, and then press ENTER after you type each line:
smartdrv
xcopy cd-rom:\i386 drive:\i386 /e
Restart the computer, and then start the Setup program again.
When you receive the error message, click Browse, and then type the path of the I386 folder on the hard disk.
Note You may be prompted several times for the location of this folder. If Browse is not available, see the "Hard disk formatted with NTFS file system" section.
If the hard disk is formatted with the NTFS file system and you are upgrading an earlier version of Windows, use one of the following methods.
Method 1
Important This section, method, or task contains steps that tell you how to modify the registry. However, serious problems might occur if you modify the registry incorrectly. Therefore, make sure that you follow these steps carefully. For added protection, back up the registry before you modify it. Then, you can restore the registry if a problem occurs. For more information about how to back up and restore the registry, click the following article number to view the article in the Microsoft Knowledge Base:
322756 (http://support.microsoft.com/kb/322756/ ) How to back up and restore the registry in Windows
When you receive the error message, press SHIFT+F10 to start a command session.
Type regedit.exe, and then press ENTER.
Click HKEY_LOCAL_MACHINE.
On the File menu, click Load Hive, and then load %Windir%\System32\Config\System.sav.
When you are prompted to specify a name, type Test.
Locate and then click the following key:
HKEY_LOCAL_MACHINE\Test\ControlSet1\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
Delete the UPPERFILTERS and LOWERFILTERS registry keys.
Repeat steps 6 and 7 for the other ControlSet# keys under the Test hive.
Click File, and then click Exit to quit Registry Editor.
If the path in the error message is the correct drive letter for the CD-ROM drive, click OK to continue the Setup program.
If you receive the error message again, the Setup program cannot correctly read from the CD-ROM drive, or the path information is incorrect. In this case, restart your computer and let the Setup program resume.
Method 2
If you cannot start Regedit.exe at the command prompt, and there is another available partition where you can install Windows on the hard disk, follow these steps:
Install Windows in the other partition.
Start the new installation of Windows, and then start Regedit.exe.
Follow the steps in method 1, but load the System.sav hive from the original Windows folder.
Method 3
If you are not using a retail Windows XP CD-ROM with a hologram (for example, if you are using a burned CD-ROM), try to run the Setup program from a retail CD-ROM with a hologram. To verify this, start the computer by using Recovery Console, and then check the C:\$win_nt$.~ls folder. Look for the Asms folder. If the folder is missing or the files that it contains are zero bytes, the CD-ROM was not burned correctly.
For additional information about how to use Recovery Console, click the following article number to view the article in the Microsoft Knowledge Base:
307654 (http://support.microsoft.com/kb/307654/ ) HOW TO: Install and use the Recovery Console in Windows XP
Apr 27, 2010 | Microsoft Windows XP Professional With...
Fails to start
Insert the installation disc and select repair.
If problem persists, format the windows partition and install a fresh copy of the OS from a ORIGINAL CD.
Mar 26, 2010 | Microsoft Windows 98 Second Edition for PC
I don't have a Windows 98 Second Edition CD or
sir,
you can download win98 cd or anything form the site named thepiratebay.org freely.
please try, it is tested, search for any appropriate software it is there.
Feb 20, 2010 | Microsoft Windows 98 Second Edition for PC
How can I put wireless adaptor on win 98 first edition
Good luck.
The first edition of Windows 98 lacked support for many devices. Windows 98 Second Edition added some support.
Can you find a "Windows 98 Second Edition Upgrade" CD-ROM and
license-key?
Search for a wireless-adapter that *CLEARLY* states that it is supported on Windows 98 SE.
It's time to "trash" that computer.
Find somebody who has an older Pentium 3 or Pentium 4 computer that is running Windows XP, and buy that computer from them.
Nov 09, 2009 | Microsoft Windows 98 for PC
What steps do I take to down load windows 98 drivers? what is the download time?
you can download win 98 drivers from this site. Microsoft does not support win 98 anymore so you will have to go to third party sites to download any drivers I suggest you start here
http://windowdriver.com/drivers/drivers.php?t202id=9733&t202kw=Download%20Windows%2098%20Drivers&gclid=CJrYwuGJ450CFRQpawodYm4BQg
Oct 27, 2009 | Microsoft Windows 98 for PC
I have a laptop without a cd drve on it. it is installed with a windows 98 second edition and it doesnt work on my local area network. i want to change it to windows xp. i bought a usb 2.0 to sata ide...
Well, there is a solution, but it depends how comfortable you are with computers. I assume you have a driver to use it under windows 98, and I'm hoping it's a cd burner, and that you have XP install disk.
You would need to use a program called nLite or another similar one, but this is the only one I've personally used. Just googled for it and you'll find instuctions on their site. You will be using that program to copy your XP install CD to your harddrive, integrating the needed drivers with it, and then burning a new bootable XP install CD that includes the needed drivers.
Jan 11, 2009 | Microsoft Windows 98 for PC
HP 1210 c/ps will not print
you will need the usb port drivers for windows 98 and the usb drivers for the printer as the earlier windows 98 had'nt the usb drivers included with operating system an as the new motherboards came about with usb ports then a new in 98 was needed to catter for this that's why you have win 98 first edition and win 98 se edition please chech that you have the driuvers installed for both parts to work.
good luck
Nov 22, 2008 | Microsoft Windows 98 for PC
Microsoft Windows 98 for PC Logo
41 people viewed this question
Top Microsoft Operating Systems Experts
Brian Sullivan
Brian Sullivan
Joseph Coppeto
Joseph Coppeto
M Beutner
M Beutner
Are you a Microsoft Operating System Expert? Answer questions, earn points and help others
