Question about Miele S548 Bagged Canister Vacuum
Electrical to power head
The rewind works fine, it's the power to the carpet head that is not working..
  • 438 Answers
Greetings from GoVacuum,
There could be a couple of reasons why you are not getting power to your power brush. The first and most popular reason is the hose of the machine. Sometimes the wires inside of the hose will go bad, causing the power not to get down to the power brush, but the rest of the vacuum working well.
You can test this hose easily. You will need to go out and purchase a continuity tester from Home Depot or Radio Shack. When the electrical test is in the continuity position, remove the hose from the canister, and put one of the testers on one of the electrical prongs that plugs into the canister itself, and put the other tester into socket where hose connects into the wand, you should have continuity on both terminals. It is important that the switch that controls the power brush is turned to the on position. If one of the terminals does not have continuity, you will need to replace the hose itself.
If both terminals have continuity, then you should then follow the same procedures on the electrical wand. If the wand tests ok as well, you may have a loose connection in the power brush.
Please let me know if none of these solutions work for you, I can then shoot a video showing you how to open the power brush to check for loose connections.
You do have a Miele S548, correct?
Please feel free to email me with any questions, I really enjoy sharing my knowledge of fixing and repairing vacuums, and would be delighted to answer any questions you might have.
Chris Jones
GoVacuum.com
chris.jones@govacuum.com
Posted on Oct 03, 2008
Agitator brush won't rotate. belt is fine, replaced v belt but it is loose. thought the old one was stretched out but new one is the same size.
The brush spins around an "axel", try removing rotator & spray wd-40 with red straw into it. See if that works, but do NOT use on carpet until dry or you will get grease stains on carpet.
Nov 05, 2013 | Hoover WindTunnel Pet Rewind Plus, UH70086
Solaris electro plus need replacement roller brush for electric carpet cleaning head
The part number for the roller is 4929740 if you are in Australia or NZ we can get the part for you (VacuumSpot)
Feb 16, 2013 | Miele S514 Solaris Electro Plus Vacuum
I have a Kenmore Elegance Vacuum with Dirt Sensor, Model # 116.30750400C, Serial number M41901532. When vacuuming the carpet the power head will work for 3-6 mins then automatically shut off, power is...
It is an electrical problem in the handle, if you can or know somebody that has any fix it ability it can be fixed in about ten minutes. Oh, and Sears SUCKS!!
Oct 17, 2010 | Kenmore 34612 Bagged Upright Vacuum
My Hoover stopped sucking! If I use the attachment for stairs that works just fine, but in the upright mode for carpet it won't **** at all.
The tube in the power head probably has either a clog or a leak/crack. Since the hose attachment works fine, then the hose should be clear. You may be able to clear it without much difficulty, but replacement should be done at the Hoover shop.
Aug 25, 2010 | Hoover F5872-900 SteamVac Wet/Dry Vacuum
The power head on my vacuum keeps shuting on and of when vacuuming carpet
the electric cord may be loose on the head. I have had this happen on my other power head vacuum. you may not be able to fix it.
Aug 12, 2010 | Filter Queen Majestic Canister Vacuum
Difficulty vacuuming SmartStrand carpet
Wish I had a solution because we have the same problem with our Smartstrand. We have a Beam Central Vac put in our new townhome and it takes a huge amount of effort to push the power head forward. I have tried a couple of regular vaccum cleaners on it; same problem. The bottom of our power head has a black residue on it. ILike you, I am thinking there is something in this green product that accumulates on the bottom of the power head and prevents the power head from going forward smoothly. There must be other people having the same problem.
Help!
Jon
Aug 17, 2009 | Oreck XLS700A Upright Vacuum
Automatic Cord Rewinder is not rewinding anymore
I had the same problem - the power cord for my Hoover Elite Upright (U5507900) was stuck a few inches out and wouldn't go any further. But when I unscrewed the rewinding mechanism, the cord had clearly gotten twisted and partly buried under itself so after some work I was able to free it. Now it seems to be working fine, at least for the moment. Note that I had to use small screwdrivers to unscrew the cord rewinding compartment, like the kind of screwdrivers you use for computer repair.
HTH!
May 27, 2009 | Hoover Elite Rewind Bagless Upright...
Power to power carpet head
it sounds like the spring on the cord reel let go. difficult to reinstall. it may have been broken already and that is why it came off. it is rather meticulous trying to work on a cord reel. many can't be disassembled without breaking
Aug 09, 2008 | Miele S548 Bagged Canister Vacuum
Canister works, vacuum doesnt
There could be a break in the electric from the machine to the hose - or from the hose to the wand - or from the wand to the Power Nozzle - or it could be the motor is bad.
Wiggle the cord at the Hose with it running- then go to the Wand - then to the Power Nozzle. You may find a break in the wires anywhere along the line.
unplug the Vacuum:
If you have a meter check to see if the reset is working - and last check to see if the motor will work removed from the Nozzle.
Ralph
ifix@shentel.net
Oct 17, 2007 | Filter Queen Majestic Canister Vacuum
Lack of Suction
There are actually several possibilities.
Check to make sure that the brushroll is spinning. The brushroll is responsible for virtually all of your pickup on carpet, and is the culprit for most complaints of "lack of suction."
If the brushroll is not spinning, listen at the head to see if the motor inside the power head is active. If you can hear it running but the brushroll is not turning, you have a broken belt. If the motor in the power head is not turning at all you may have an electrical short in the hose, the wands, or the main power outlet from the body of the canister; but before you get too involved check the power head for a thermal reset button. Some of the Electrolux powerheads are equipped with these, and some are not, so check your user's manual. If there isn't one, or if it isn't tripped, you'll need to look for electrical issues.
In this particular model it is fairly common for the electrical contacts on the wands to short out, so inspect the metal contacts to look for scorching, or melting of the plastic around them. If you have access to a VOM, check for voltage at the contacts on the end of the wand, and if it is not present, check all of the contacts sequentially back to the canister body to determine which part is not passing voltage. If you have voltage all the way through the wand, you either have a loose connection inside the power head, or the power head motor has burned out. If you have power from the canister body, but not through the end of the hose, either your hose has a short in it, or the circuit board in the handle assembly that controls the power head power has shorted out.
If your brushroll is turning, then you do, in fact, have a clog somewhere inside the power head, which a visual inspection behind the brushroll and into the elbow will confirm.
Best of luck,
-R
Apr 01, 2007 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Miele S548 Bagged Canister Vacuum Logo
309 people viewed this question
Top Miele Vacuums Experts
Mack Baxter
Colin Stickland
Colin Stickland
Are you a Miele Vacuum Expert? Answer questions, earn points and help others
