Question about AEG B1180-4 Electric Single Oven
Diplomat 600gs model no 050502078
The oven will heat up as normal but after a few minutes or when it gets hot the electrics cut out the digital display will stay off (but not the gas) once cooled it will come back on. any advice on which part i should be looking to replace will be greatly appreciated.
  • AEG Master
  • 5,568 Answers
Your heater is probably equipped with a bimetal thermal switch to prevent overheating and, if it is like most made in China now, it is defective or at least highly inaccurate. Look for a thick (4-5 mm), button-like device customarily with two terminals (apparently some have 4) and a diameter of 1.5-2.0 cm.  Bypassing it will expose you to a loss of hearth and home if the regular control circuits fail.   Rather try this; locate the device, use a metal shield to divert some of the heat which will allow it to serve its original function as a safety.
This point of failure is shared with a majority of drip coffee makers that fail way too early.
Posted on Oct 18, 2008
Diplomat ADP 5520 Stainless Steel Range not getting hot enough
The circular element that the fan sits behind heats the oven. Ensure the thermocouple is back in the right place. Too near the element and the oven will stay cool.
Circular elements can be pricey and fitting should cost no more than an hours labour.
http://www.espares.co.uk/search?SearchTerm=ADP5520%20element
Jun 23, 2017 | Ovens
Model RBS275PDB12. I had a recent Power Failure. Since the oven has malfunctioned. When placed on bake the preheat timer does not display. At 350, the baking element gets warm. At higher temps the...
Good Afternoon! If your Whirlpool oven isn't heating to temperature, and your temperature sensor is reading good, the control board may be the issue. Fixyourboard.com can test and if necessary repair the control board in your oven. We back all control board rebuilds with an industry leading two year warranty. Contact us for more information- info@fixyourboard.com
Thank you!
Mar 30, 2017 | Whirlpool RBS275PD Electric Single Oven
How do you reset the clock on a Diplomat HJA 3300 oven? Would you by any chance have a pdf of the manual?
Press and hold the timer and casserole symbol buttons at the same time then press or - to set the time. If "auto" flashes you will have to cancel that programme.
Feb 25, 2011 | Ovens
Built-in Whirlpool model GBS307PRS01 oven won't get hot
First check the thermal fuse to see if it's open circuit and if so replace with http://www.appliancepartscompany.com/product/9223815
This is normally the problem (I have already replaced it twice on my oven).
If this doesn't solve your problem, let me know as there are some other option to try.
Jul 08, 2010 | Whirlpool GBS307PRS Stainless Steel...
Diplomat Softline ADP0300 Gas-just not cooking ...anything!
Hi there..
I Just recently had the same problem, also with a diplomat gas oven..
The problem I found was down to a small resetable component under the main cover. ..
It took me ages to find the problem and I had taken the whole electical parts of the oven to bits before 'accidentaly' coming across this 'thermal switch' (located inside the main cover, at the top, behind the display module).. - to reset this there is a tiny red button between the connectors.. press this - and it should all be fine again... : One importnat note is that this may be tripping as a consequence of the fan not running or by my thinking not running on after the oven is switched off, leaving the casing to heat up and then trip this switch component.. - if this component is faulty it can be found in RS components or Farnell components.. look for Thermal swich manual reset part no: L100C 9082 470.
Nov 29, 2009 | Ovens
Diplomat Double oven bottom oven fan works but
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Oct 18, 2009 | Belling XOU592 / XOU593 Electric Double...
Diplomat integrated oven- 13amp?
You need to get an electrician to wire it in to a 30amp cooker outlet. It is 30amp rather than 13amp (like most sockets). It should go to its own fuse in the fuebox
Feb 22, 2009 | Belling XOU592 / XOU593 Electric Double...
Amana Convection Wall Oven Model AOCS3040 Does Not Heat in any Mode
sure its possible, sounds like you've blown an over limit thermostat behind stove, gets too hot and for safety reasons cuts off unit untill replaced
Feb 11, 2008 | Amana AOCS3040 Electric Single Oven
Cuts out over 100deg Celcius
the oven cut out stat may be cutting out to early first try this, it should be mounted at the top of the oven unit.
Jun 23, 2007 | Baumatic B180 Electric Single Oven
AEG B1180-4 Electric Single Oven Logo
295 people viewed this question
Top AEG Ovens Experts
ashburton
Sal De GO PATS
Steve
Are you an AEG Oven Expert? Answer questions, earn points and help others
