Question about Twinhead SlimNote N12PI Notebook PC
How to upgrade my twinhead notebook hard disk?
Hi guys.i try to upgrade my storage from 80 to 250GB but unfourtunaly i cant find the hdd location.....where the hdd location?
  • Mohd Hairizuddin Aug 09, 2008
    but i have pull out all the screw and juz see the ram/cooler/optical drive.......
    but cant wheres the hard drive.
  • Mohd Hairizuddin Aug 10, 2008
    ok i get it and i see the hard drive under the notebook motherboard....i need to pull out the keyboard/cooler/all the screw.....and finally see the hard drive..its really hard and difficult ....
    Genius:
  • 2,028 Answers
I've never had the pleasure of working on one of these. What I do when trying to find the hard drive in a machine I'm not familiar with is put my ear down to the machine, start it, and listen for the hard drive to kick in. This let's me know where it is, then I look the machine over to figure out how to get to it systematically. On most laptops, there is a cover on the bottom or the side that hides the hard drive. If on the side, it's generally a caddy that is held by a screw on the bottom, and the hard drive slides out with it. On some models they put the hard drive under the keyboard or palm rest/touch pad. So, listen to find out the location of the drive, then look for a cover on the side or bottom in that area. If there's not a cover, then remove the keyboard and check if you can see it. I know this isn't the answer you were looking for, unfortunately there's no manuals on line, but I hope this helps, and get you started in the right direction.
Posted on Aug 09, 2008
  • Ryan Rogers
    Ryan Rogers Aug 09, 2008
    Look under the keyboard.
  • Ryan Rogers
    Did you even read my post. Let me shorten it for you. LISTEN CAREFULLY ON START UP FOR THE HARD DRIVE. THIS WILL TELL YOU WHAT AREA IT'S IN, THEN YOU CAN FIGURE OUT HOW TO GET TO IT!!!
Hard-disk #44w4z2y3764-595B the system primary HDD, is protected by password authentication system how to solve this problem how unlock it by correct password?
Here is your Dell Hard Disk Master Password for HDD serial #44W4Z3Y3764-595B
Your HDD Master Password is: w2cuzked
When asked for HDD Password use the HDD Master Password to unlock the HDD password. The Dell HDD Master Password is what Dell can calculate for you or a third party.
Thanks to the great guys at unlockbiosrecovery.com for providing the HDD Master Password that will unlock your hard disk. They can unlock your laptop bios or hard disk.
Apr 01, 2011 | Dell Inspiron 8200 Notebook
Hi . I have notebook hp nx7300 , the hard disk 80GB I'm upgrade the hard disk to 320GB but the computed dont see the hard
Your motherboard does not support the new SATA II HDD. You will need to go to the HP website and download the driver to a flash disk and then when you install Windows it will ask if you wish to install drivers you would select yes and then open the flash disk - Windows will install the driver itself.
The other way is a bit more tricky and that's to go back to your old HDD and create a custom slipstreamed windows CD with your new driver installed as standard.
Sep 15, 2010 | HP Compaq nx7300 Notebook
I have a laptop Toshiba Satellite A75-S206 Intel Pentium 4 2.8GHz / 802.11b-g Wireless / 15.4-inch WXGA / 512MB DDR / 60GB HDD / DVD-ROM/CD-RW Combo / and I want to change the hard disk.I want a list with...
That takes an IDE HDD. They are universal so any notebook IDE HDD will replace that 1. I like Weatern Digital because they really are good about standing behind their hard drives. Now it only came with a 4200 RPM so when u upgrade purchase the 5400 RPM. If the bios firmware only supports the 60GB then u will need to format a larger drive with a second partition using admin tools as a mass storage device.
Aug 14, 2010 | Toshiba Satellite A75-S206 Notebook
What is the hard disk maximum capacity I can upgrade for my R50e? What is the type of HDD I can used? Please advise.
Hi, there is no restriction regarding the size, but thinkpad usually run better the HDD Air bag protection system with 5400RPM disks. Thanks and have a nice day J -
Jun 09, 2010 | IBM ThinkPad R50e Notebook
Slave is ok but master freezes...
you can install even if it is a slave disk. also you can try setting the jumpers to master mode, check the sides of the hdd, it has a jumper setting and set it to master, using the shorting pin, just plug it out and connect it to the right setting
Jun 03, 2010 | Seagate Notebook Hard Drives: 40GB...
Old twinhead slimnote 5100c do not start
Try removing its HDD and another removable disk. Finally the RAM module. If does not, take it for repairs.
Apr 28, 2010 | Twinhead SlimNote N12PI Notebook PC
I HAVE LAPTOP IBM THINKPAD T30 AND I WANT TO CONNECT HARD DISK 80GB OR MORE
  • Supported HDD thickness:
    • 12.5 mm for systems without the touch pad
    • 9.5mm for systems with the touch pad
  • Standard 20GB, 40GB, 60GB HDD sizes.
    Note:
    • The 60GB HDD orderable as marketing option part number 08K9688 has a height of 12.5mm and will not fit in the HDD slot of the systems with the touch pad installed. For these systems, it is only supported via the ThinkPad 2nd HDD Adapter for the Ultrabay 2000.
    • The 60GB HDD orderable as replacement service part number 08K9833 is 9.5mm.
  • Supports one additional HDD which can be used concurrently to offer expanded storage utilizing the Ultrabay 2000
  • S.M.A.R.T technology to issue an alert if a hardware failure is pending
  • ATA Bus Interface
  • 4200 or 5400 rpm
  • Although you can upgrade the HDD, it is not designed to be removed and reinserted on a regular basis. Repeated and frequent removal, for purposes other than to upgrade for greater capacity, can cause damage to the system. The Ultrabay 2000 HDD adapter is designed to provide this flexibility with a second HDD in the Ultrabay 2000 IBM says. I say if the OS recognises it and so does the BIOS, you're good. good luck, hope this helps.-jmattes p.s. I found this info on: http://www-307.ibm.com/pc/support/site.wss/MIGR-42218.html
Oct 17, 2009 | IBM ThinkPad T30 2366 Notebook
I want to upgrade my hard drive.
If you have 50% or more disk space free then you may not need a larger hard disk at this time. If you have 512Mb of RAM, you can get better performance with 1Gb or better still 2Gb of RAM if your Acer can support more than 1Gb of RAM.
Jun 09, 2009 | Acer Aspire 5315 Notebook
Hard disk problem
Change the other HDD to either Cable Select or SLAVE.
Then make sure you partition it correctly, Windows does a decent job at it.
Right click on My Computer, go to Manage, then under storage, click on Disk Management; you should see the HDD here.
Dec 09, 2007 | Toshiba (HDD2188) 80 GB Hard Drive
Open Questions:
Twinhead SlimNote N12PI Notebook PC Logo
479 people viewed this question
Top Twinhead Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Alun Cox
Lee Durbin
Lee Durbin
Are you a Twinhead Computer and Internet Expert? Answer questions, earn points and help others
