Question about Olympus Cameras
Put new battery in the camera and when I turn it on the green and yellow light flash as though the battery is dead.
Maybe dirty contacts? try fine sandpaper on them carefully
Posted on Aug 09, 2008
6ya staff
SOURCE:
Kodak easyshare m320 charge light is green, but not charged
Hello Dead Battery, Well this sounds pretty easy compared to most questions I get. If the camera says the battery is dead, then the battery is dead !! the problem with batteries is they loose their capacity over time. The charger can not put any more in it and says it is charged. Just get a new one and give it a full charge and this should do the trick.
Best Regards, Russell
Sep 29, 2012 | Kodak EasyShare M320 Digital Camera
I have a kodak easyshare c533 camera and it won't turn on. I tried new batteries but all it does is flash the green light. Any ways to fix this?
Green light flashed, turned red, lens would not open. Put in new rechargeable batteries, still nothing. Someone here suggested to try regular AA cheapie batteries. IT WORKED!
Nov 09, 2010 | Kodak EasyShare C533 Digital Camera
Won't turn on
look for reset near the battery compartment. should need a paper clip to push.
Jun 02, 2009 | Cameras
Flashing orange and yellow lights
Most likely your battery is dead.
If you are worried about your HD , the best thing to do would be to power it off.
Remove the battery and see if it will boot on the AC adapter.
If it boots , just get a new battery.
If not you have a motherboard issue and need to call Acer if it is under warranty.
Apr 22, 2009 | Acer Aspire 5003WLMi Notebook
With new batteries already put in--no power
Are you using rechargeable batteries, and have tried lots of different batteries? Also, sometimes rechargeable batteries fresh out of the package can be dead or have very little juice. Just a thought...Hard to say that's it though if you were having the same thing happen before...
Jan 16, 2009 | Apex Digital Digitrex DSC-3000 Digital...
Camera wont turn on batteries are new
I had the same problem that the green light turned on then the red one, even though the camera batteries where new.
I found a solution for this problem, hope it works for all as it did for me.
http://www.sendspace.com/file/ysolwv
The link shows the images of the steps you need to follow to fix this problem.
This problem actually is from low batteries or low voltage in the camera, but its not because the batteries are dead, it is because the batteries don't have a good contact with the metal conductors in the camera.
In the images you can see that the camera has a plastic cover for the battery contacts, so the way to fix it is to remove that plastic cover with a small screwdriver, and pop in the new batteries.
With that it should fix the problem. Hope it works.
Jan 02, 2009 | Kodak EasyShare C533 Digital Camera
Flashing green light
I also have the same problem.
Does anyone know the solution?
Mar 30, 2008 | Polaroid One600 Ultra Instant Camera
I have a Samsung digimax cyber530 that turned on with the lens coming out but will not do anything else (blank screem etc) I've put new batteries in and although when I press the power button the green...
I was borrowing the camera so the simple solution was quality long life batteries than the cheap versions (even though they were new) I had installed.
Mar 06, 2008 | Samsung Cameras
Cameras Logo
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Ekse
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
