Actiontec (GT701) Modem Logo
Posted on Apr 21, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Do they have any upgrades for a actiontec gt701 wg modems
Clive Gray
Level 3:
Genius:
  • Master 1,479 Answers
  • Posted on Apr 21, 2011
Clive Gray
Master
Level 3:
Genius:
Answers
1479
Questions
Helped
291311
Points
4728
Here's the page, check the firmware in your router and see if it's older than these
http://www.actiontec.com/support/product_details.php?pid=71
2answers
I did a firmware upgrade on my Gt701-wg modem QW06.5.3.60.3.8.6 and now i can't acess the modem configuration page
First, the upgrade may have replaced the default functionality. Second the wireless signal capacity allowabel for most computers requires letting the system aware of the new setup to share signals. The software is on the computer however requirign to adjust the wireless distribution to accept new codes to retain usual fucntionality.
1helpful
Trying to change from actiontec gt701 to actiontec gt701-wg. after new modem is hooked up, internet light stays red. switched by to old modem and all is fine. anyone know why internet light stayed red?
The reason why your internet light is red for the actiontec gt701-wg is because it is not yet configure. You need to access the gui of this router. enter the username and password for your internet connection. You can contact your ISP provider so they can walk you through for the steps on how to configure your new router.
The old router has green light because it was already configured by your ISP provider.
I have a dsl modem and an actiontec gt701-wg gateway
Yes this is a normal method to setup a wireless network.
To set-up and secure the wireless router from unauthorized access, follow these steps :-
1. Connect the wireless router to your computer with a LAN cable.
2. Start your browser and enter the router's configuration URL IP address.
3. Enter the router setup, login and password
4. Change the admin password
5. Go to the wireless settings and change the default SSID and turn off SSID broadcast.
6. Setup encryption key the strongest is WPA2 (if not then WPA).
7. For further security measures - turn on MAC address filtering and enter the MAC address of the wireless cards on the computer/s you want to connect to this wireless router.
8. Record the settings you have made and keep it in a safe place and Save the settings.
9. Configure the wireless cards on the computer/s with the SSID and encryption settings of the router.
10. Remove the LAN cable between the router and the computer then the computers should be able to connect to the router.
2answers
WEP code error
If you're using 64-bit WEP Key, it would usually require you to put in 10 digits from 0-9 and A-F. so if you're putting in your wep key, make sure it's using only the characters 0,1,2,3,4,5,6,7,8,9, A,B,C,D,E,F.
Use a Qwest Actiontec GT701-WG router with a different ISP?
Yes, if the other isp is also providing dsl services, but you will have to configure the device the other isp will not help you with that.
but its really not that difficult.
2answers
Actiontec GT701-WG won't operate wirelessly
In looking on the internet the unit is a DSL gateway. Trying to use it on cable internet is not a real good way to set up your network because I believe the router is waiting for a DSL sync before the services turn on. I would spend the money and pick up a Linksys or Netgear G router, there around $50.
Actiontec gt701-wg Installation
You can use USB instead of Ethernet port but its not a common practise. Leave it empty then.
How to connect to Actiontec GT 701-WG
choose add new connection and choose wireless and follow the direction
Top Actiontec Computers & Internet Experts
Jesse Walters
Jesse Walters
NOEL
NOEL
Are you an Actiontec Computer and Internet Expert? Answer questions, earn points and help others
