Need a wiring diagram for main circuit board plugs on WMA62 Hotpoint washer
    President:
  • 1,462 Answers
These plugs are keyed so they can not be wrongly connected
Posted on Aug 09, 2008
SOURCE:
Wma62 wont spin
Check out the carbon brushes in the motor. Theyre graphite blocks which transfer mains power to the copper segments of the motor - located at the other end of the motor from the drive pulley. Theyre probably worn down. They're quite cheap parts and easy to replace - the holders are plastic or bakelite and are generally held in with screws or plastic clips. Also, look at the copper segments they run on to check for burning or pitting. If the segments are burnt or damaged you need a replacement motor or a replacement armature (motor part) if you can source one. Occasionally may be a fault in the motor drive circuit board - in which case replacement of board only real option. Other possible causes of spin problems: Faulty pressure switch - machine "thinks" the drum is still full of water so wont enter the spin cycle. Spin problems may also be caused if the machine reckons the load is out of balance, rearrange the load. If problem persists could possibly be a fault in the out of balance detector switch or the suspension and damping system.
Nov 20, 2012 | Hotpoint WMA64 Front Load Washer
What is the fault code F01 referring to
Hi You have a short circuit on the motor or motor plug, or wiring from the module (main control board) to the motor
You will need an insulation tester to test the motor unless you can see any burning etc on the plug or wires.Suggest you take the motor off and get it tested.
Good luck Jack
Jul 10, 2011 | Hotpoint Ultima WF860 Front Load Washer
My waashing machine a WMA62 Hotpoint comes on, you
that sounds like your heating element is o/c .... get your heater tested ..01179512835
Dec 30, 2009 | Hotpoint Washing Machines
Wiring plug came off of main circuit board and not sure where it goes
You do not state which plug, as there is more than one, it is impossible to help you
More info please?.
Dec 06, 2009 | Hotpoint WMA54 Front Load Washer
Hotpoint WMA62 shaft removal
draw off the spider with a pulley extractor,
Sep 03, 2009 | Hotpoint WMA64 Front Load Washer
Htptn wma 42 control board on facia wiring diagram(plugs)
Brian
1 x11 2 Black Blu
1x9 2 Black Black
1x2 2 Red Red
1x6 2 spare on my machine wms38
Mar 16, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint WMA62 door will not lock
Sounds like the door lock switch has failed,normally they go bang when fail,they start the machines cycle so are important,when door is shut it should click,this engages a timer which keeps door locked switch is live at mains potential,cant be tested have to be replaced about 12 pounds cost,best for a tech unless you feel competent
Dec 13, 2008 | Hotpoint WMA64 Front Load Washer
Hotpoint DW440 flashiing lights
I have just seen the same problem on a neighbours WD440G. I have tracked down the problem to the main circuit board at the back, bottom of the machine. Transistor/FET Q9 has exploded. There was water at the bottom of the machine and the wiring in the vicinity of the nearby connector was wet.
This neighbour is in no financial position to be able to buy a new board, or get an official Hotpoint engineer to confirm what we already know. Anyone know where I can get a schematic diagram for the board?
Dec 10, 2008 | Hotpoint Aquarius WD63 Front Load...
Wiring Diagram
Have you looked under the main control panel for this??The other way is to contact Hotpoint(GE) support,they will have this information.Just have model & Serial number ready.
Jun 03, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Washing Machines Logo
168 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
