Question about Car Audio & Video
Icbm-7071 performance teknique alarm remote starter wont work
Everything works on alarm sys but the remote strter makes evrythng look like is going to strtbut it doesnt
  • 4 more comments
  • jvb94 Dec 01, 2008
    I installed this system and when I arm the starter and then try to start the car and the lights flash but nothing else happens, then the system flashes again and stays armed.
  • faithful0124 Dec 31, 2008
    I have ICBM 7071 in my truck also. I had installed 10 months ago. It's was working well at first, but now it's giving me problems. For some reason the remote control is beeping without any cause. The control is shutting off/on by it self casing it to beep off like I had just installed a new battery in it. I would like to know if there is a way to fix this problem.
  • V-Dub Jun 21, 2013
    I have had at least 4 of these alarms. Very reliable however, I know exactly why the alarms beeps for no reason. I'm really on the thread to find/locate replacement remotes, but read your problem. So, in a nutshell, you will need to keep your second transmitter around, becasue it is a matter of tem before the "beeping" one stops working and you will be left having to put your alarm in valet mode. Inside of the remote there is a small resistor, and it is loose. gaurantee this is the issue. I have opened up both of my broken remotes, and noticed the same problem with all of them. Unless you know someone who can solder small electronics, my advice is to start searching like me, for replacement transmitters.
  • Anonymous Mar 17, 2014
    how do I install a new remote to this alarm. I am having problems with the 2 original ones. The company sent me 2 new ones. It says it will only be able to use 2 remotes at one time. I try to install one new one following the directions, but it will not alow me to. I think it is because I need to eliminate the remotes that are already used. I tried to remove the old remote batteries, & disconnect the fuse to the alarm, but none of this helped.
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 108 Answers
What type of vehicle and year is it in? Also, most remote start alarms have a neutral safety wire that needs to be grounded and a hood-pin wire that needs to be connected. If the start system was working and has since failed, it is pointing at the hood-pin wire. If it never started remotely, then you may look to the programming on the alarm. Make sure that the tachometer wire is connected and that the tach setting has been programmed. This should take care of it. If not, I would recommend visiting a local stereo shop to have them diagnose what is wrong with the system.
Posted on Sep 28, 2008
Some one out there need help with a 7071
Posted on Aug 25, 2009
Hi, i check you have a PERFORMANCE TEKNIQUE ICBM-7071 car alarm, I want to ask you about, I need a car alarm with dual zone shock sensor, but I need to know if comes with 3 or 4 wires, can you tell me?
And the siren, it’s 1 tone or multitone.
Thanks, hope you can answer.
Posted on Apr 11, 2010
I am sorry for bad English, I use the Internet translator. You could not scan the instruction on installation Performance teknique icbm 7071. I from Russia, and at us was not present such alarm systems. Thanks.
Posted on Nov 03, 2009
I install 7071 performance teknique remote start & alarm ,it work fine ,after few months my battery of car death and i replace new battery after that it not work at all ,i try to reset and lock and unlock door work ,but no horn and no start engine ,i try to read manual over and over but i don't know how ,cause the manual not much imformation ,how to reset & how set up horn or start ...thx
Posted on Nov 11, 2008
Do i need a bypass module in installing performance teknique 2 way alarm system w/ remote in my 2008 mazda 3
Yes, to do a remote start properly, a bypass module will be needed. The less expensive ones will require you to lose a key. The better one will program to your car using 2 existing working keys. Many online retailers sell them. Look for Fortin, Idatalink, etc.
Feb 20, 2013 | 2-Way Car Alarm System w/ Remote Start
Performance Teknique Icbm-7071 Everything on my alarm system is working, but now the only thing that will not work is the alarm sounding off. My receiver still beeps when my alarm goes off, but the car...
Sound like the siren. check the connections at the siren. If the connections are good and the system is sending a signal then, you may need to replace it.
Jul 27, 2012 | Car Audio & Video
Lost the manual to program performance teknique icbm-7071 alarm systemHELP!!!!
there should be a help line number on the product or the box or a website go to the m they can walk u thru it or google instructions for performance technique car alarm
Feb 24, 2010 | 2-Way Car Alarm System w/ Remote Start
Hey I just recently buy a performance teknique
good luck finding one, check ebay, or call Teknique directly.
Feb 13, 2010 | Performance Teknique ICBM-9794 Car Video...
Performance teknique icbm-782 amplifier will not power on
run 12 volt into your rem terminal and see if it comes on if it does your remote wire coming from the headunit is bad or cut
Apr 15, 2009 | Performance Teknique ICBM-782 Car Audio...
Wont power on after checking all the wires
HI DUDE PLS CHECK UR REMOTE WIRE IN UR PLAYER .... U MIGHT BLOW THE FUSE .. ... THE CONNECTION IN REMOTE WIRE WILL POWER EVEN THE FUSE BLOW ..
Performance Teknique ICBM-9550 Amp Problem.
one of the power transistor of your unit shorted check use a tester
Aug 27, 2007 | Performance Teknique ICBM-782 Car Audio...
Car Audio & Video Logo
2,975 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
