Question about Canon Pixma iP6000D InkJet Photo Printer
Canon ip6000D My printer worked great...then it started not feeding. it grabs the paper (seems to be grabbing only from one side) and then says it is printing (and sounds like it prints) but the paper never feeds through HELP!!
    Champion:
  • 214 Answers
use good quality paper for printing. clean the feed roller or get the printer serviced from the authorized dealer.
thanks
Posted on Aug 15, 2008
My canon pixma mx320 won't feed paper properly it seems to grab one side of paper and feeds it crooked then stops
When the paper does not feed straight, dirty or stickyrollers can cause it to jamb or crinkle, also failure to remove all traces ofpaper from a previous paper jamb will cause further paper jambs.
Check for tiny pieces of at the edges of the rollers, and remove these piecesof paper. The rollers may be dirty or sticky and causes the paper tonot feed straight.
Try cleaning the rollers with methylated spirits.
Jul 26, 2011 | Canon PIXMA MX320 Color USB InkJet Printer
Paper grabbed from one side
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 22, 2010 | Canon Pixma iP6000D InkJet Photo Printer
Canon pixma ip 1600. paper feed mechanism faulty. will not grab paper and feed through or takes it through at an angle
You said that the paper is fed on one side. Am I right?. If it so,it seems that another material is present inside your printer.
Please check this post for more information
Nov 29, 2009 | Office Equipment & Supplies
Canon ip2600 keeps grabbing the paper wrong, only grabs it on the right side so it feeds in crooked and jams.
you need to see the left roller and determine if broken or needs cleaned. to clean use an eraser,thats the best way. if broken i suggest new printer. have a great day and please rate bama46, thanks.
Aug 18, 2009 | Canon PIXMA iP2000 InkJet Printer
Grab paper
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 27, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Paper does not feed - GRABS RIGHT SIDE
gears below the paper feeding tray are damaged or some dust particle have blocked the gears try to clean it by blowing the dust use normal greece (oily substance) between the gears so that they can move frequently to pull the paper, and if the gears are damaged you have to change the gears.
Aug 03, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Paper feed problem
i disconnected turned upside down and started shaking it and believe it or not the roller starting working it prints fine!
Feb 03, 2008 | Canon MX300 Office All-In-One Printer
Paper Feed Error
Your saying the printer grabs the paper on the one side more than the other?
Nov 13, 2007 | Canon MultiPASS MP390 All-In-One InkJet...
Canon Pixma iP6000D InkJet Photo Printer Logo
183 people viewed this question
old marine
old marine
