Question about Jabra BT8010 Wireless Headset
Jabra BT8010 doesn't power up
After second charge, Jabra BT8010 didn't power up. Tried another outlet thinking it may not have charged, but got same result. I'ts completely dead.
Tom Nelson
  • 2 more comments
  • shinank Aug 11, 2008
    I have exactly the same issue. When charging the display will say "Charging..." then "Charging Complete"(this is correct behavior). But when I unplug the charger and try to turn it on I get nothing on the display. Furthermore, it will connect to my Nokia n95 but it will constantly "Connect" and then "Disconnect" for no apparent reason. Strange because it was working yesterday.
  • emerger04 Sep 04, 2008
    Exactly the same issue... about to charge for the second time and... nothing.
    The headset was showing Low Batt. then about an hour later (with the headset still "on") I picked it up and it was dead completely, no display nothing. Plugged it into the wall pack charger and still "dead" no display, won't power up, doesn't even show "charging" on the display like it nomally does...
  • Anonymous Oct 04, 2008
    My bluetooth was lost and then found . When i found i was so happy. So, I charged it . When i went back it said charged compete . Tryied to turn it on and nothing.
  • Anonymous Mar 13, 2009
    same^
Contact me if you are interested to sell it for parts acidx0 ~(at)~ gmail.com
Posted on Sep 14, 2008
I had the same problem as shinank, I downloaded the firmware upgraded from the jabra site and it fixed this problem.
Posted on Apr 22, 2009
I have a jabra bt8010 but it does not turn on when i charge it it says charging
Posted on Aug 04, 2010
4 Suggested Answers
SOURCE: Jabra BT500 will not power on or charge
I would also like to know if you find a fix for this problem. I have the BT500 and it will also not turn on.
Posted on Feb 03, 2008
  • 4 Answers
SOURCE: Jabra bt250v Indicator light doesn't remain on...
i have just repaired my bt250 with this problem, i hadn't used it for around 2 years and when i put it on charge just got i flash of blue led. the fix was to "jumpstart it" the headset needs to se some sort of battery voltage to start the charging process, i stripped mine right down but that was just to fiddley. IF YOU DO THIS IT WILL BE ENTIRLEY AT YOUR OWN RISK AND I TAKE NO RESPONSIBILITY IF YOU TRASH YOUR OTHERWISE USELESS HEADSET. ok all you need to do is very carefully remove back cover (undo 1 screw and ease it apart). be very carefull as there are delicate wires inside. lift the inner part out slowly and you will see the battery.it has some orange tape around the end and there is a small circuit board attached to it with a small red wire and a small black wire. look at the battery and you will see under the orange tape there are to larger tags.these are the main battery terminals, peel back the orange tape just until the tags are slightly exposed. now you need to solder a wire to each of them and DON'T TOUCH THEM TOGETHER. on the battery it says which tag is + and which is - make sure you mark your wires or get red and black ones. now i used the lead from the charger. look at it . it has a hole in the center of the pin that is the + so put the + wire in there. if you are not sure use a volt meter. now touch the - wire to the outer metal of the connector that is the - point on the charger connector. hold this for around 2 mins but no more. as the out put of the connector is 6.2v and the battery is only 3.7v the battery will get warm. if the battery is getting too hot in under 2 mins then take of charge. when you have done that and taken off the connector i recommend to use a volt meter and just put it on the battery wires you soldered on to check battery voltage. as long as it reads you should be ok. de solder your wires from the tags and rebuild headset then try and charge it. this worked for me. i am no electronics expert i just like to mess with broken stuff so i know it seems a bit dodgy to connect like this but i had nothing to lose and it worked.
Posted on Dec 01, 2008
  • 16 Answers
SOURCE: jabra bt 250v not charging or cannot use headset.
Try this link to help you on this site it is a battery problem
http://www.fixya.com/support/t190081-jabra_bt250v_indicator_light_doesnt
Posted on Jan 07, 2010
Philips HS8020/18 Shaver Red Light
How can check the s pass status check the passport number?
Jul 27, 2013 | Health & Beauty
Can't find anywhere the bt8010 software
Bluetooth headset hbh-iv840 sony ericsson doesn't work with my ipone4s to lisen to music, can someone help?, plssssssss :)
Feb 05, 2013 | Jabra BT8010 Wireless Headset
My headset will not turn on
Hello
Your bluetooth headset is powered by an internal battery. If the battery is not charged,it just won't turn on. Fully charge your battery before use.
Make sure that the power outlet you're using is working and that the cord is fitted correctly into the wall, PC or Car outlet and the Jabra Bluetooth device.
Try unplugging the Jabra Bluetooth device and see if it turns on. If so, use the Jabra Bluetooth device until the battery is completely exhausted. The next time you charge it, check that it is charging properly
If the Jabra Bluetooth device is still not charging, check what happens when you initially plug the Bluetooth device into its charger. If the light on the Bluetooth device flashes on and then off again quickly, it is likely that the battery is no longer working. Batteries cannot be replaced or covered warranty
Dec 30, 2010 | Jabra BT150 Wireless Headset
I need a set of new earhooks for Jabra BT8010 can't find wher to buy. I stay in Moldova, can go to Bucharest, ROmania. have aquaitances in Bilbao and Paris - they could pick it up there could you please...
If price is not an issue and you don't mind the outrageous shipping charge, Jabra sells a pack of 5 from their own website.
http://www.buyjabra.com/accessories/earhook-5-pcs-for-bt125-bt135-17.html#
Sep 23, 2010 | Jabra BT8010 Wireless Headset
Where to find Jabra BT8010 earhook
Contact the company on website WWW.jabra.com. they are 10.95 plus s/h and you get 5.
Jan 29, 2010 | Jabra BT8010 Wireless Headset
My jabra BT160 won't charge
i had the same problem with mine. the problem is with the completely empty battery.
solution is to disassemble it and force charge the battery inside.
you have to cut any usb cable leaving the side which connects to pc and remove the insolation from red and black wires. connect them for few seconds to battery soldering points on jabra board (red to red, black to black, sometimes you have to scratch the solder a bit if it oxidized a bit). once you see the light you can start charging it normally.
Sep 23, 2009 | Jabra BT160 Wireless Headset
English instruction manual
you need to charge the head-set fully and then.... disconect it from power supply. hold down the call button until a continus light appears. and then flip out the speaker tusk.... then search for the device on your phone a couple of times.... if you dont find your headset then your phone is not compatible with the head-set....
Nov 28, 2007 | Jabra BT8010 Wireless Headset
Sep 17, 2007 | Jabra BT500 Wireless Headset
Jabra BT8010 Wireless Headset Logo
966 people viewed this question
Top Jabra Radio Communications Experts
Michael Vincent Cruz
Jerry Greenberg
Jerry Greenberg
Mohammad Nawaid...
Level 1 Expert
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
