Question about Fuji FinePix E900 Zoom Digital Camera
Focus error my camera is FinePix E900. the zoom lens doesnt go in and it displays a focus error. what should be done with it?
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
Posted on Sep 30, 2010
SOURCE:
Fuji finepix s3100has no power even with new batteries
I have this problem also with Fuji Z90 model.
Problem is fixed and focus now working ok.
Camera is fall down and after when camera was started giving sound click click from focus big motor and error on screen Focus error
Focus ( lens ) was open ( small cover on top bellow sticker ) Small "snail" gear is taked out . Two sliding segment adjusted for focus ( upper full up and lower full down - beware about spring inside below this focus pins )and snail is inserted back. Camera started and focus start working. I need to make small adjustment . Reason when camera is started picture is not clear and before using camera i need to do full zoom in and back zoom out. After this picture is crystal clear and all working ok.
Dec 17, 2012 | Fuji FinePix S304 Digital Camera
Fuji film finepixF480 showing focus error
Possible that the lens mechanism is jammed , sometimes the flexible connector of the lens focus/zoom can be faulty.You try to check for some tips from the link below; http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Dec 30, 2011 | Fuji FinePix F480 Digital Camera
Getting an zoom error on my fuji film finepix z90, what can i do?
Lens errors (zoom errors on Fuji's) are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to lens error problems can only be corrected by professional repair. But, here are some last resort troubleshooting steps that you can try that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try.
Jun 25, 2011 | Fuji FinePix S304 Digital Camera
Focus error? The camera won't focus. Focus Error is displayed in the viewing screen. Zoom action & everything else seems to work fine. Won't focus, won't take pictures.
This is a known issue with Fuji S3000 cameras caused by dust and dirt that get in through the loosely mounted lens mechanism, there are only three solutions.
  1. If under warranty you can send the camera in for repair.
  2. Saturate around the lens with WD40 and wiggle the lens until it becomes responsive again every month or so.
  3. Dismantle the camera and clean out around the internal gear-box and lens components about once a year.
May 03, 2010 | Fuji FinePix S3000 Digital Camera
Hi, the zoom wont retract and it says focus error
It won't focus because ya lens is out of focus due to it being stuck had same prob wig my Sony worked out cheaper to buy a new camera than have it fixed.very fiddley to repair hope if bin some help
Nov 23, 2009 | Fuji FinePix A500 Digital Camera
My Finepix 12.0 megapixels camera is having a problem
The focus mechanism is jammed inside the lens. The lens will not retract if any of the slide rings inside the lens are out of alignment.
Read my tips page on my profile under "the only way I know how" for focus, zoom error.
If you can't free it from the out side then you have to open it up and reset it.
my email is on my tips page if I can be of any more help
Oct 06, 2009 | Fuji Finepix F50FD Digital Camera
Taking a picture, I get a focus error message and the lens won't retract.
Try this post:
http://www.fixya.com/support/t2284005-camera_powers_down_when_pressing_shutter
It is probably a battery problem, I had no error but autofocus didn't work. Replacing batteries solved it.
Gus
Jul 28, 2009 | Fuji FinePix E900 Zoom Digital Camera
Focus error
Can't take photos, camera show focus error.
May 04, 2009 | Fuji FinePix S9500 Zoom Digital Camera
Zoom error
Turn Camera off remove batteries for a few moments. Re insert batteries. Turn on will reset itself. Ensure you use correct focus settings as per instructions. If you dont use correct settings this problem will reoccur.
Oct 27, 2008 | Fuji FinePix S1000FD Digital Camera
Focus error
The zoom and focus operate on screw thread drives. 1 of these has detatched resulting in "ZOOM ERROR" and locked the camera up. Dis-assemble lens and re-attach drive.
May 25, 2008 | Fuji FinePix S5200 / S5600 Digital Camera
Fuji FinePix E900 Zoom Digital Camera Logo
89 people viewed this question
Top Fuji Cameras Experts
Ekse
Steven Wander
Steven Wander
Azam Ali
Level 1 Expert
Are you a Fuji Camera Expert? Answer questions, earn points and help others
