Question about Garmin Suction Cup Mount with 12V Adapter (010-10935-02) Mounting Unit, Vehicle Mounting
Garmin Suction Cup (Rubber)
The suction cup on my Garmin keeps droping the unit. The neoprene rubber has some flaws ( small missing area's )due to it being remove from the windshield. It needs a new neoprene gasket I believe (Or some type of repair).
  • 1 more comment
  • Anonymous Sep 28, 2008
    I have the same problem with my Garmin, I am still looking for a solution.
  • blpow Mar 03, 2009
    Works great, thanks for the info.
    Bob
  • Anonymous Mar 13, 2009
    I'll try it
Put a drop of dishwashing detergent and a few drops of water on the rubber and distribute it evenly before You mount it to the windshield. This mixture enhances the suction power and keeps the rubber soft. Repeat after 3-4 months! If You don't like the look of it on the outside of the window, put a smiley sticker on it! :-)
Posted on Mar 03, 2009
Nees replacement rubber feet for my magic hostess food processor
I have replacement suction cup feet for most, if not all, Rival and Magic Hostess kitchen equipment so equipped. The replacements I offer are black, not gray as originals, newly manufactured and work very well. They can also be used on Rival and Magic Hostess kitchen equipment that used a foam foot, rather than suction cup and improve non-skid safety. mailto:lallin@juno.com
Mar 19, 2012 | Food Processors
I have a Rival handcrank food slicer,it has no other markings other then it says Rival on the crank handle. The rubber feet that keeps it from sliding around during use are gone. Where or how can I get...
I can supply suction cup feet for most, if not all, metal framed Rival and Magic Hostess brand slicers, Kitcheneers, Shred-o-mat, etc. If it is RIval or Magic hostess and uses small rubber suction cup feet, I can help. mailto:lallin@juno.com
Feb 16, 2011 | Rival Electric Food Slicer 1101G
Need new rubber tank gasket for Holmes humidifier Model HM4600
after scouring the INTERNET AND FINDING PLENTY OF SITES THAT WOULD SELL ME THE WHOLE CAP FOR 24.00. I MAD MINE USING SOMETHING FROM ace hardware THAT COST 2.50 Small suction cups with the hook [CDBL-7500S11] PART NUMBER 7500 .CAN BE MODIFIED INTO MAKING YOUR OWN GASKET. IT WORKED FOR ME ..REMOVE HOOK FROM SMALL SUCTION CUP. cut off nib with sharp pair of scissors. THEN DRILL HOLE THROUGH CENTER OF CUP WITH 7/64 DRILL BIT. re insert plunger part of cap through cap with spring and re- attach suction cup instead of gasket. MINE WORKS FINE ON A HOLMES 3700
woodinvirginia
Jan 23, 2011 | Holmes Products HM4600-U 11 Gallon...
Mounting of gps can't mount on windsheild.
Tomtom GPS devices come with a variety of windshield suction mounts. All have in common that the windshield and the suction cup both must be clean; use a mild soap dispersed in some warm water to remove any dirt. Rinse properly. Sometimes it helps to keep the cup a little moist.
Make sure the cup is not warped due to previous exposure to heat, and check for any nicks in the rubber. Small damage may easily make the mount unusable and you'd need to get a replacement.
Models with a lever mechanic: open the lever (cup becomes flat), press the cup against the windshield and while keeping pressure, close the lever. It will lift the middle of the cup away from the windshield, causing a vacuum.
Models with a ring around the cup base: Turn the ring all the way counter-clockwise (cup becomes flat), press cup against windshield and while keeping pressure, turn the ring clockwise 90 degrees. This requires some force, but in my experience these mounts stick more reliable,
Jan 04, 2011 | Tomtom ONE XL GPS
WIll not adhere to the windshield... suction cup does not hold GPS
Dec 31, 2010 | Tomtom GPS
How exactly do i fix the suction back onto the windscreen please? I have just bought a tomtom and don't understand the drawings!
Dec 31, 2010 | Tomtom ONE GPS Receiver
GPS will not stick to the windshield.
Check to make sure that the suction cup you have is the appropiate size for your GPS unit. Also check to make sure there is no grease or other slippery substance on the windshield or suction cup that stops it from sticking to the surface. If you have something like Rain-X on your windshield, you will need to clean the area where the suction cup will be placed, and after that, it should stick.
Oct 29, 2009 | Garmin StreetPilot C330 GPS Receiver
Can't assemble suction cup mount that came with Nuvi 350
They fit tight together. Sometimes you need a little force.
Sep 13, 2009 | Garmin 010-10723-03 Suction Cup Mount...
Unit will not hold suction (c330)
put a little spit on the rubber suction cup than install on window i had the same problem
Jan 01, 2009 | Garmin Nuvi 660 GPS Receiver
Installing my new street pilot
It is a mount for your dash that your suction cup mounts to just paste it to your dash ans put the suction cup on it and install your unit
Dec 20, 2007 | Garmin StreetPilot C330 GPS Receiver
Garmin Suction Cup Mount with 12V Adapter (010-10935-02) Mounting Unit, Vehicle Mounting Logo
936 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
