Question about Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag
Rechargeable lawn mower lacks power even with replacement battery. Six or seven year old rechargeable Black and Decker 24 volt mower. Replaced the battery last year after it became unable to mow my rather small suburban yard without a overnight recharge in the middle. New battery will last 3/4 as long as when the mower was new. Blade may be out of balance, but could the engine need repair, such as new brushes or something to get the full effect of the power in the rechargeable battery? http://www.toolpartsdirect.com/cgi-bin/bigimg.cgi/blackdecker/cmm1000_type_4 http://www.toolpartsdirect.com/cgi-bin/schematic.cgi/blackdecker/CMM1000_TYPE_4
    Champion:
  • 313 Answers
Just to let u know CMM1000 mower are on recall for pcboard.
if ur mower is type 1 to 4 then its the subject for recall for convertion to CMM1200.see ur nearest service center right away.
Posted on Aug 11, 2008
How do I replace the trailing rubber flap on a Black and Decker 36V mulching mower?
I need the answer too. My flap was so torn up that I just tore the remnant off. If you find out let me know, please.
Jun 18, 2015 | Black and Decker USA CM1936 - 19 In. 36...
Removing blade
put blade back on with the air valance pointing toward deck that is up tighten down as hard as you can done
Sep 03, 2014 | Black and Decker USA CM1936 - 19 In. 36...
Black and decker electric lawn mower wont start
I'd start by checking the motor brushes, they might be worn.
Jul 21, 2014 | Black and Decker USA CM1936 - 19 In. 36...
Black & Decker cordless lawn mower won't start
Hi Sandi-
This could be an issue with the battery itself or charger. The best way to know is to have the battery tested. You can follow the link to locate your nearest service center to have them tested.
Thanks
Black + Decker Customer Care Find Service Center
Jan 15, 2012 | Black & Decker Black Decker Cordless 24...
I have a Craftsman mulcher model 315.370270. The green recharge light goes on but the battery charge level stays in the red. Do I need a new battery and if so where do I buy it?
I guess you've solved this by now, sounds like you need new batteries if the mower lacks power after trying to recharge. There are two sealed lead acid 12-volt batteries connected together on this mower to provide the 24 volts of power. These are the same batteries that are commonly used on rechargeable power wheelchairs and scooters. So you could find them at a Durable Medical Equipment company. The last two times I bought them, I got them from a DME company where I used to work. I also looked into buying them over the internet. Just make sure the replacement batteries are the same size and specs. You could burn out your on-board charger by continuing to charge batteries that are shot. I did this a few years ago with my 315.370270. Since then I have been charging the batteries with my portable Craftsman charger. The 12-volt batteries last about 3-5 years. I have had my mulcher since 1995 and have replaced the batteries about four times. This is the best mower I've ever owned. I'm going to retire it this year, if you're interested in it for spare parts.
Aug 27, 2011 | Craftsman Garden
My Black and Decker rechargeable Lawnmover has a good battery but when I try to engage the motor by pulling onto the safety release, the motor will not run. I think it has a bad cable on the safety...
The first thing i would check would be the ground wires are nice and tight. If you can get a hold of a volt meter you can start at the battery and check the wires little by little when you get to a spot that had power a second ago but no six inches higher there is your problem. but make sure all conections are tight, grounds are secure, no wires bare wires are crossing i hope i have been helpful
SabiousOne
Nov 08, 2010 | Black & Decker Garden
I have an Allegheny 24 volts combo tool set that is missing a rechargeable battery and charger. Where can I get the battery and charger? Thanks Sal
you can order 1 from black & decker ,from ther website or by phone.or in some cities they have stores.or try battery depot.
Aug 22, 2010 | Black & Decker SZ360 Cordless Power...
My 24 volt lawn mower is all of a sudden not working, it is just over 2 years old. You can hear it but the noise it was giving off is missing?? It doesn not have the same sound. The blade is turning, I...
If the blade is turning it should cut grass. Try mowing. If it's not cutting the grass then the blade is not turning, or is no longer turning at the proper speed. Look for a fuse or circuit breaker.But after 2 years the battery may have a problem. Try the manufacturers website for help: http://www.blackanddecker.com/en-us/support
Sep 24, 2017 | Black & Decker Black Decker Cordless 24...
Battery replacement for unit
The unit itself is obsolete.
However....
Open the unit up (six cross-head screws). Inside you'll find a 12V 5.0AH rechargeable battery, like the kind used in many home alarm systems.
You can get a replacement at most battery stores (they'll even pre-charge it for you). Somewhere around $20, I guess.
Sep 12, 2008 | Black & Decker String Trimmer Cordless 12"...
Replacement batterys for cmm1200 black&decker electric mower
You can find replacement batteries on amazon, click here and take a look: Amazon com Black and Decker 24 0 Volt Lawn Mower Battery 90508011. I hope this was helpful. Cheers
May 04, 2008 | Black & Decker 19" Electric Lawnhog...
Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag Logo
364 people viewed this question
Top Black & Decker Garden Experts
Jim Parker
Jim Parker
Simon Elder
Level 1 Expert
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
