Question about Whirlpool Washing Machines
WHIRLPOOL GWH9150PW0 - washer won't fully drain-cleaned out hose, it worked for one load then only partially drained for next load-switched to drain and spin, water drained properly-what's up?
5 Suggested Answers
  • 641 Answers
SOURCE: Ge Profile Harmony Washer doesn't drain properly.
It sound like you have a blocked pump. Remove the pump from the machine and check where do you have this clogged, inside the pump or in one of the pipes connected to it. Good luck!
Posted on Aug 16, 2007
fanny
  • 146 Answers
SOURCE: Whirlpool front loader washing machine (AWO3361) WONT DRAIN
Remove drain hose from where it connects to the plumbing under the sink/tub. Inspect the spigot. If clogged, clean. If clean, then tilt machine back and remove drum to pump hose from pump. Check hose and also drain pump. Clear any obstructions.
Posted on Nov 03, 2007
  • 26 Answers
SOURCE: whirlpool duet hf error
This error code indicates a water supply problem.
Are both the hot and cold water faucets turned on?
Turn on the water. Check the household faucets to see if the hot and cold water faucets are turned on. Completely open both faucets for proper fill.
NOTE: Both hot and cold water must be connected to the washer and turned on; the washer will not properly operate with only one incoming source of water.
Are the water inlet hoses kinked?
Straighten the water inlet hoses.
Are the water inlet valve screens on the washer clogged?
Turn off the water and remove inlet hoses from the inlet valves in the back of the washer. Inside the inlet valves are screens. Remove any accumulated film or particles from the screens. Reinstall hoses, turn on water, and check for leaks. See the Installation Instructions for details; find them by entering your model number in the search tool below.
fl_hot_cold_back_of_washer.jpg Is the water pressure less than 10 psi?
If the water pressure is too low, the washer may not properly operate. To find out your exact pounds-per-square-inch (psi) value, contact your local water utility company.
Are you using HE High Efficiency detergent?
Use only HE High Efficiency detergent. Using non-HE detergent, or more than the manufacturer's recommended amount of detergent, can cause excessive suds. The excess suds can prevent the washer from detecting the incoming water.
Concentrated detergents labeled 2x and higher will require a small amount of detergent based on load size. Always follow the manufacturer's recommendations.
See also: Why HE High Efficiency detergent is required.
Are you using flood-preventing inlet hoses that can shut off the water to the washer?
These hoses have a valve inside that will close if the water pressure is higher than two gallons per minute; this will shut off the water to the washer. If one of these hoses becomes loose, the water flow through the hose will increase and close the valve inside the hose, which will shut off water to the washer to prevent a possible leak or flood. If the hose is not loose, try taking the hoses back to the store for a replacement set.
To remove the error display, press Pause/Cancel twice.
If Pause/Cancel does not work:
  1. Unplug the washer or disconnect the power for one minute.
  2. Plug in the washer or reconnect the power.
  3. Re-select the cycle and press Start.
NOTES:
  • On some washers, when the washer is started for the first time after this error code, it will begin to drain. You will not be able to pause or cancel the cycle for about 8 minutes while it drains. This is normal.
  • If the error remains on the display, and all of the other conditions above have been checked, call for service.
Posted on Dec 20, 2008
SOURCE: UL Code
Solved the unbalanced problem - open the top of the machine (press in with a flat putty knife about 3" in on the front on each side while lifting up as there are 2- 1" wide catches). Once both sides are unlatched, raise the lid then slightly lift the rear of the lid so that it fits into the curved part at the top of the hinges then open all the way - tape the lid to the top so it doesn't flap about and scotch the lid to keep it from falling back down on you. Now, look around - see all that rust?  The rust has fallen into and gotten underneath one or more of the 4 white plastic suspension "ball joints" which have probably totally dried out by now from their factory grease because of the water, bleach, and rust particles.  Having someone help you, simply lift up on one of the 4 corner suspension rods - gravity and weight is all that holds them down. The white ball will lift out of the socket and still be attached to the rod. Clean out the rust, lightly sand the "socket" with emery cloth, then slop in a fingerful of grease. I used automotive wheel bearing grease with graphite in it. Also scrub off all embedded rust on the white plastic ball. Lower that corner back into the newly cleaned and greased socket and repeat for the other 3 corners. Now when you move the tub around notice how the balls pivot in their sockets like they are supposed to. When they were dry and rusty they wouldn't move enough to allow the tub to twist like it should so it slammed around.  Now, shake your head in disgust that after only 2 years there is so much rust that you wonder if it will make it another year before falling apart, close the lid, and try another load.  That totally solved my off-balance problem where even a single handkerchief would give the UL error. It is still a finicky machine, but at least once again works like it did when new.
Posted on Jan 06, 2009
SOURCE: My Whirlpool washer won't agitate or spin . But it does drain the water.
i also had the same problem, and it ended up being the coupler. It was not hard to replace, it cost me about 19.00. I didn't follow full recomende instructions. I tipped the washer backwards. Removed the drain pump and the motor itself. Then I removed the old coupling and placed the new one. The washer is working like new...
Posted on Jun 02, 2009
Whirlpool duet washer error code f h
HF indicates a fill problem. This could be no water entering the washer, an issue with the pressure switch or the flow meter.
Does any water enter the washer? Check the shut-off valves to make sure that they are open. If water enters and then exits, make sure that the drain hose outlet isn't below the water level of the washer. Check your inlet hoses; some anti-flood hoses will restrict the water flow if they detect a leak. Close the shut-off valves and take the hoses off the washer. Put the ends of the hoses into a bucket and open the shut-off valves one at a time. Replace the hoses, if they are bad. Clean the filters on both sides of the hoses (washer and shut-off valves). Make sure that the hoses aren't kinked.
If the error happens during a drain and refill sequence, check if the pump is fully emptying the washer. (The pressure switch will trigger the error if the tub has too much water in it.) You may need to clean out the drain pump filter. Also, if the flow meter sees 10.5 gallons flowing through the inlet valves and the pressure switch doesn't trip, then the error will occur.
Next, check if the solenoids for the inlet valves are opening. Check that the pressure switch tubing isn't clogged or have a pinhole leak. (You can blow through the tubing and listen for the reed switch clicking.) Similarly, check the resistance when you blow through the flow meter. It should give 300-400 Ohms when you are blowing air and 0 when not air is moving. Unplug the wiring harness and check if the error occurs with the pressure switch disconnected from the CCU.
Sometimes the error is caused by the CCU. It can fail to provide the needed voltage to open the inlet valve solenoids.
I hope this helps.
Jul 16, 2015 | Whirlpool Duet GHW9150P Front Load Washer
Maytag Neptune MAH8700A tha detergent drawer is filling up with water and running out of the drawer onto the floor not going into the tub.
see this causes and fix it. God bless you
Belt, Water Pump If the washer won't drain the pump belt might have broken or might have worn out. Check the belt and replace if it shows signs of excessive wear.
Drain Pump If the washer won't drain water the drain pump might be defective. It's also common for a small sock or other article of clothing to get caught in the drain pump or in the drain hose. Check both for an obstruction before replacing the pump.
Clogged Pump or Hose If the washer won't drain there might be a clogged pump or hose. It's common for small socks or other small clothing items to get into the water drain system and clog the hose leading to the pump or the pump itself. Remove the hoses from the pump in order to remove the article of clothing. Keep in mind that any water in the washer will pour out of the hoses when removed.
Drive Belt If the washer won't drain, should check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't drain properly, if at all.
Lid Switch Assembly If the washer won't drain the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't drain the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Drain Hose If the washer won't drain water check the drain hose. Be sure the hose did not get kinked behind the washer. Also, remove the hose from the pump and check it for obstructions.
Coin Trap If the washer won't drain the coin trap may be clogged. This washer is equipped with a device near the water pump called a coin trap. The purpose of this device is to trap any foreign materials that make their way down the drain. Normally, the coin trap can be accessed through an access panel. It is designed with the homeowner in mind and is normally easy to clean out.
Oct 11, 2012 | Maytag Neptune MAH7500WH Front Load Washer
My indesit iwc6105 washing machine is not draining at all.
see this causes: and fix it. God bless you
Oct 11, 2012 | Washing Machines
CHANGE DRAIN PUMP WASHER
Oct 02, 2012 | Whirlpool GHW9300 Duet Washer
The washer broke filled with water and won't drain
Sep 28, 2012 | Kenmore Washing Machines
Bosch Nexxt Premium Washing Machine Drainage Blocked. Cleaned out impeller still not working.
You need to check the drain pump externally to see if the pumping is good Also remove the drain hose clamps and remove the drain hose flushing to clear off all dirt. Now test using power to see if this works and can be simulated. When refitting, the hose must be tightened properly. If the pump/valve does not work even with power then it must be replaced. If there is intermittent power to the drain valve/pump then the program controller unit is a suspect.
Cleaning a pump: http://www.youtube.com/watch?v=zKjKi50YBpI&NR=1&feature=fvwp
Finally the washer must be placed with a tilt- use a spirit level- so that all water will drain to the outlet port and thereby there is no residual water remaining.
Replacing the pump on a Bosch machine, please check this link for tips:
http://www.espares.co.uk/advice/washing-machines/a/7/1373/how-to-replace-the-pump-on-a-washing-machine-.html
Jul 02, 2012 | Bosch Nexxt Premium WFMC6400UC Front Load...
Doesn't fully spin all the time, sometimes takes 3 attempts to fully drain water
The pump filter is probably clogged if the washer is drained tip it forward till it is lying on its front disconnect the pump hose es and find the filter and clean the stuff out of it.
Mar 12, 2010 | Whirlpool LSQ8000 Top Load Washer
THE CODE LD IS SHOWING UP AND WASHER IS NOT OPERATING
Press stop, cancel twice to reset. The Ld error is when it takes longer than 5 minutes for the washer to drain and reset the sensor. You probably have a partially plugged strainer or drain line. To check the strainer, remove the kick panel at the front bottom of the machine. The strainer is ibetween the drum and the pump, being connected to the drum with a rubber hose. Open the strainer (caution, water!), and clean. If you did not find much in the strainer, clean the drain hose. Dump the contents of the drain hose into a bucket. If possible, run an empty losd with dth drain line pointed outside.
This should fix your issue!
Best regards, --W/D-- feel free to rate this solution...thanx!
Aug 02, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Washer stops after aggatating and wont drain
My Kenmore 70Series washer goes through the wash cycle then just stops when it is to drain and then spin.
Jun 10, 2009 | Whirlpool Washing Machines
Wont spin and drain!!
Hi there, thanks to everyone who responded to my problem!
I solved it with a collection of ideas posted, first i was able to actually get the filter out fully, it was being held in place by a hair clip, a little gentle persuasion solved that! secondly the drain hose was partially clogged and the suggestion to snake it out worked a treat. once again thanks to everyone who helped the machine is back in full action!!!
Feb 24, 2008 | Whirlpool AWM5125/1 Front Load Washer
Washing Machines Logo
91 people viewed this question
Dan Webster
Dan Webster
prem mathew
