Question about Whirlpool GU2400XTP Built-in Dishwasher
WHIRLPOOL QUIET PARTNER IV
SUDDENLY (ONE USE TO THE NEXT) DISHES ARE NOT DRY, LOTS OF STANDING WATER ON DISHES. USING MOSTLY 'POTS/PANS' CYCLE AND PUSH 'AIR DRY' WHEN CYCLE IS COMPLETE. NO CHANGE TO THE WAY I USE IT BEFORE OR AFTER PROBLEM.
  • Anonymous Mar 29, 2014
    complete cycles are taking a longer time and dishes are not drying
  • 487 Answers
Ok this can mean 2 things.
Pump or filter is clogged
or heater is not working correctly. Can you give the precise model number?
Posted on Aug 18, 2008
  • Ken Brand Oct 12, 2012
    Model # is GU1200XTLB2 and it's a Whirlpool dishwasher approx. 8 years old.
My Whirlpool Quiet Partner II does not clean the upper rack of dishes properly. They are greasy. I have checked the top spray arm for blockages. There were none. I am fairly certain that water is
Make sure the center loading is not obstructing the water jet to the top shelf. Top shelf is only for glasses and saucers , use Jet-Dry .Pre rinse and clean bottom pan strainer from dirt debris.
May 14, 2012 | Whirlpool GU2400XTP Built-in Dishwasher
The sprayer on the roof inside of my dishwasher does not work. My dishes on the top shelf are stll dirty after a complete cycle wether on normal or pots & pans. I have the whirlpool Gold Quiet Partner...
I'd look at the "spray holes" on the sprayer to ensure no clogs.
Next, ensure tube at the back (if I'm thinking of the correct model) of the top shelf meets with the spout sticking out of the baqck wall of the washer.
Jul 17, 2011 | Whirlpool Dishwashers
The dishes coming out dirty on my Whirlpool Gold Quiet Partner IV. Cycle seems to complete. The soap is being used. Not sure how old it is ... it came with a house I just bought. Any suggestions?
Clean the jets on the unit. Jets are the small openings the water comes out of. Contact Whirlpool, follow their recomondations, or add some CLR or Lime Away to the washer without a load of dishes. Both products remove Calcium Lime and Rust deposits which impede the flow of water, causing your dishes to come out dirty
May 16, 2010 | Dishwashers
I have a whirlpool gold quiet partner iv; will not turn on; the light is blinking between normal and pots and pans cycle. Thanks
it may be a door inter lock or program board failure . need model # to tell you more about it . but it sounds like p c board ., you can try turning of power for 15 min then try it again .. . if this doesnot you may need a tec ..
Nov 22, 2009 | Refrigerators
The only number on the nameplate of my Costco-purchased "Quiet Partner IV" built-in Whirlpool dishwasher (steel insides) is 8575637. This dishwasher does not clean spoons right-they always have dirt left...
Yes, you almost certainly have a Whirlpool Gold Quiet Partner III Model #8575637
Of course the great news with buying from Costco is the ability to return products you are dissatisfied with. Check with the customer service desk.
Please reply if you want to to get into repairing it and we will get under way.
Mar 31, 2009 | Whirlpool Gold 24" Tall Tub Built-In...
Seem like its not draining. soapy water when finished cycle.
found a kink in the drain hose, shortened hose-problem solved.
Mar 22, 2009 | Dishwashers
Wet dishes
Hello
The heat dry button must be lit up or you are using air dry instead!
ican
Please leave a rating before you leave
Dec 10, 2008 | Whirlpool 24 in. GU1500XTLS Stainless...
Whirlpool gold quiet partner IV
You probably need to clean the filter; here is a site to show you how to do it: http://01tutorials.com/video/1686251/how-to-clean-the-filter-on-a-whirlpool-gold-quiet-partner-iv-dishwasher/4107
Sep 20, 2017 | Whirlpool Gold 24 in. Built-In Dishwasher...
I have a whirlpool quiet partner dishwasher that is not getting even light food residue off the dishes. Cycles seem to be running and progressing normally, tho I do not think the water is spraying from the...
Welcome to fixya,
You said, you have a whirlpool quiet partner dishwasher that is not getting even light food residue off the dishes. Cycles seem to be running and progressing normally, tho you do not think the water is spraying from the arms with adequate force.
I have the same machine.
And I notice if I leave the dishes in the sink rather than rinsing them off and putting them directly into the dishwasher, (Like My Wife says to do). That sometimes I have the same problem.
So I bought Jet Dry, and filled the holder. It's a small sometimes clear plastic knob that unscrews out above the soap dish.Fill it once a month!
Do you put the detergent in both cups or only the closed one?
1. If the load is not real dirty you should only have to fill the one with the door that closes.
If it is real dirty then both. To always use both is a waste of money!
2. If your hot water heater is far from your dishwasher, let the hot water tap run a minute till it comes out hot, before starting the dishwasher.
3.If the dishes or pans are very dirty and or baked on use hi temp scower and heavy or potscruber for those loads.
I use heavy wash and hot temp scower if the stuff is relly messy or dryed on.
And for baked on HI- temp scower and pot scruber which sprays harder.
You will have to experiment a little to see what works for you.
You will find it washeing good after you find what works for your families dish habits!
If you have any more questions let me know!!!
Please remember to leave me a solved before you leave the site.
Thank You for using us!
Huuum
Oct 02, 2008 | Dishwashers
Whirlpool Quiet Partner 980
Bad control board ,replace it.
May 26, 2008 | Dishwashers
Whirlpool GU2400XTP Built-in Dishwasher Logo
520 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
