Question about HP PSC 2410 All-In-One InkJet Printer
Clicking noise it clicks when i turn it on and clicks for awhile then quits and the on button is flashing
  • 4 more comments
  • Anonymous Aug 14, 2008
    same problem. cycling on and off doesn't help
  • dianemiller Aug 14, 2008
    I have the same thing going on with my printer. Have you found a solutuion?
  • Anonymous Aug 15, 2008
    Same problem here.
  • sixkellers Aug 15, 2008
    I am having the same problem--it clicks (loudly), quits, on button flashes and the screen shows an hourglass (like it's waiting for something). Please help.
  • kclifton Aug 18, 2008
    me, too! any ideas???
  • StuartT Aug 18, 2008
    Same problem as described (On button flashing, hourglass displayed, loud clicking noise - stops after a while, none of the other buttons work). I've nothing in my print queue. This problem started after i had to switch off/on a fuse to change a socket in another room.
Step 1. Disconnect the printer from the computer.
Step 2. Take the printer on top of a tall building.
Step 3. Yell, "I can't take it anymore!" while a crowd assembles.
Step 4. Chuck the printer off the building.
Step 5. Let out a big sigh of releif.
Posted on Nov 18, 2009
Some time ago I've visited a forum and found a solution that tells me to clean the mirrors of scan and other stuff
but EVERY TIME that power supply goes off it didn't turn on again and I need to open the scanner and roll the gear so with that the scanner goes to the middle of the page and try to turn on again
after a few tries the printer turns on again and I can use it...
Posted on Aug 30, 2008
I had this problem for the second time due to a power cut. It was solved by
Turning the printer on, letting it load up, do all the clicking, once that had finished then press the power button to turn it off.
Leave it for 5 mins, then turn it back on, this time it should setup as normal.
Hope this works for you!
Posted on Nov 27, 2009
    Problem Solver:
  • 5 Answers
The clicking is the scanner seeking the index as part of the power up procedure. Search the hp site for the procedure to clean the scanner glass, Pay particular attention to the white strip, which is which is the scanner index.
Posted on Sep 08, 2008
When i push scan button on hp psc 2410 all in one printer it tells me scan options net set. install or run device software on computer. help
Posted on Aug 13, 2008
All the lights flash but the engine will not start
Find the security system and write down the make and model. Use internet to find owner's manual, or how to disable the system.
Jul 12, 2017 | 2004 Toyota Matrix
I have a Lexmark E360d and every time I print it beeps. How do I turn that off?
Quite mode OFF is the default factory settings. To reduce noise produced by the printer, quite mode need to be turned ON. This will reduce the amount of noise but this will set the printer run at half speed.
To do this click on Menu Button > General settings> Quite Mode> ON and then press the check button to submit.
For further assistance, please contact Lexmark Technical Support.
Jul 11, 2011 | Lexmark E360d Laser Printer
I had to do system recovery on my computer. now
Quick and dirty here we go, before you click finish see if the hard drive light is on, if it is is it on steady or is it flashing. Doesn't matter so long as it is on, go have coffee for 30 minutes or so and then come back.
Check to see if the hard drive light is still flashing if it isn't then do this press ctrl+alt+del this will bring up an screen. On windows 7 you want to click on task manager then open the applications windows, look and see if there is anything there that says not responding. If not click the finish button and let it run for awhile.
Thing you have to realize about this system of installing is that everything is compressed and needs to be unpacked and this can take awhile to do this, also make sure that network cable and phone cable are disconnected from the computer.
Hope this helps
Apr 26, 2010 | HP Pavilion a420n PC Desktop
We cant turn on the Sharp Aquos TV and the power and opc buttons are flashing.
Ur power light stable green first turn on?Then awhile click,POWER and OPC flashes.Tries on/off couple time,will work.Not then ur backlight video board is dead.
Dec 25, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Whirlpool refrigerator side by side freezer won't freeze
your over-load/contactor is defective, un plug it from compressor and shake it if it rattles its bad
Oct 28, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Flash will not pop up
depending on the type of camera just hold the flash button and if that dosent work then gently put a flat screwdriver and lift up.
Mar 30, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Clicking noise from the blinker wont turn off!
There are 2 common things that cause this.
1. the hazzard flasher is faulty. the hazzard button and the turn signal flasher are all in one. Sometimes pushing the hazzard button in slightly will get the noise to happen, and is an indication it is faulty.
2. The turn signal switch in the steering column is bad. Turning the turn signal from left to right- very fast and harshly, will sometimes clear it up for awhile.
Tech JK
Jan 21, 2009 | 2004 Pontiac Grand Am
Flash not working
I figured out how to fix the flash... but not the clicking sound in the lens. To fix it... click the mode button, then go to the settings icon
(the arrow pointing at the wrench), then keep going down to the reset all part. and click okay while your on it. Your flash should work after that!
Dec 23, 2008 | Nikon Coolpix S210 Digital Camera
Tv wont turn on only clicks and then flashes red timer light
tv wont turn on when i hit power it makes the clicking noise like it is going to turn on, but never does and the red timer light next to the power button just flashes.
help!
trinitron kv29f1u
only clicks and blinks
Jul 26, 2008 | Sony KV-35S42 35" TV
Insignia 42 in plasma tv
cableman try this exactley to the "T" with the instructions in front of you. The procedure resets your monitor to factory settings. On step 13 use the factory setting on the right side menu block not the left. It may or may not work if you have a bad board or eeprom. 1. Using the Volume button (Remote or Monitor) turn the volume all the way down.
2. Hold the Menu button on the Monitor.
3. Press the Menu button on the Remote.
4. Press and hold the Volume button on the remote for 5 seconds and then release the Menu button on the Monitor. After this step the date will appear on the left side of the screen within 10 seconds.
5. Click the Menu button on the remote.
6. Click the Left Arrow button on the remote.
7. By using the Down Arrow button, scroll to Settings and then click the Left Arrow button.
8. Highlight "Eepreset" and click the Left Arrow button. (The monitor will turn off at this time)
9. Push the Power button on the remote, the unit will turn back on.
10. Click the Menu button on the remote.
11. Click the Left Arrow button on the remote.
12. By using the Down Arrow button, scroll to Settings and then click the Left Arrow button.
13. Highlight Factory and click on the Left Arrow button to select "Off"
14. Click Menu on the remote.
15. Click Menu on the remote.
Jan 06, 2008 | Haier 42EP24S 42 in. EDTV-Ready Plasma...
HP PSC 2410 All-In-One InkJet Printer Logo
470 people viewed this question
Seeker5211
Seeker5211
