Question about Sharp AL 1631 Copier
H4 Problem Machine will not shut down after copy clear pattern at any speed. Plus how do you enter 14 on the machine? My controls don't have a numeric pad, it had 2 buttons 10+ and 1-9.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Sharp Master
  • 1,362 Answers
H4-0 Fuser temp too low
you can enter 10+ and on the other add the rest (4) = 14
Posted on Aug 11, 2008
H4 ERROR CODE
press on the keypad, # * C * the machine will enter a diagnostic mode. Then enter 14 as if to make 14 copies. You may then have to press 1 and execute the program. But that will clear the H4 code 99 percent of the time. Once you enter 14, just press start and follow the directions on the screen. An H4 means the machine was just slow to warm up. It can be a fuser error, but there actually being a problem is extremely rare. Performing a clear 14 will almost always clear that.
Feb 22, 2011 | Sharp AL 1631 Copier
Blinking a printer screen number h then 4
press on the keypad, # * C * the machine will enter a diagnostic mode. Then enter 14 as if to make 14 copies. You may then have to press 1 and execute the program. But that will clear the H4 code 99 percent of the time. Once you enter 14, just press start and follow the directions on the screen. An H4 means the machine was just slow to warm up. It can be a fuser error, but there actually being a problem is extremely rare. Performing a clear 14 will almost always clear that. It may also be P * C * to enter diagnostics.
Feb 22, 2011 | Sharp AR-M205 Copier
My sharp al 1631 did not make the copi the machine codig is h4
press # * C * the machine will enter diagnostics. Then enter 14 and follow the directions to clear an H4 code.
Feb 06, 2011 | Sharp AL 1631 Copier
Probleme code H4
Press # * C * , that will put the machine into diagnostics.
Enter the number 14 as if you were making 14 copies. Then follow the screen directions to clear the fault code. Should be enter 1 then press start.
The machine will reset and should be fine.
Jul 21, 2010 | Sharp AR-5320 Black and White Copier
One number of photo copy machine drum cartridge wasinstalled. It worked once. Now machine is showing letter H and 4 flickering alternatively on the screen. Because of this none of the function of machine...
This code is almost always a false code. I would try clearing it by entering the following key sequence:
Press "Clear" then "Exposure Mode" then "Clear" then "Exposure Mode" (Note that the exposure mode key is the far left key and that these 4 keys must be pressed within 4 seconds)
The display should have gone blank if these 4 keys were pressed properly.
Now enter 14 as if you were making 14 copies then press the Print Button.
This should clear the H4 code and the machine should operate normally.
If not and the H4 comes back then you have either a thermal fuse or heater lamp failure.
Good Luck
Nov 10, 2009 | Sharp AL 1631 Copier
How to solved code H4 Xerox Xc1245
This code is akmost always a false code. I would try clearing it by entering the following key sequence:
Good Lucj
Nov 09, 2009 | Xerox XC356 Copier
Xerox Workcentre Pro16fx - H4 error code after power outtage
You shut the machine off then on, Press Clear, auto,clear , auto, then when the lights go out, program it as if you were running 14 copies. press start and that should reset it.
Thats the redish pink clear button and the auto exposure button, Clear, Auto , clear auto, and the display goes blank , enter 14 and start. Dont ask me why I repeated that LOL
Feb 02, 2009 | Xerox WorkCentre XD100 All-In-One Laser...
Xerox XC 1020 copier code H4
With "H4" flashing press:
1.Clear button
2.Auto button then again
3.Clear button
4.Auto button
It should be done quickly. If it's done quickly enough all lights on display should go off.
5.Enter number 14 (as if you are making 14 copies).
6. Press START/COPY button.
The machine goes back to normal. If not, thermistor on the fuser (heater) should be replaced.
Sep 02, 2008 | Office Equipment & Supplies
Trouble code
NOTE: Some Status codes will not clear even though the problem has been fixed. Status codes that will not clear must be manually reset using the 'Fault Reset 14 Procedure'.
  1. Locate the [C] (Clear) button on the Control Panel, at the far right.
  2. Locate the Image Quality button, below the Auto on the Control Panel, toward the left side.
  3. Press the buttons in the following sequence within 4 seconds. Press [C] (Clear), press [Image Quality], press [C] (Clear) again, press [Image Quality] again.
  4. The error code should disappear. If the Status code does not clear, repeat step 3 until the status code clears; but no more than five times.
  5. Use the [10] and [1] buttons to enter 14 on the Display Screen, as if you were to make 14 copies.
  6. Press the [Start] button. The machine should be ready to use.
  7. Make a copy, to check that the machine is working properly.
May 06, 2008 | Sharp AR-160 Copier
H4 Problem
Hi there, if you want to clear this code its very simple, do the following: -on your control panel locate the clear and auto exposure buttons, next -hit in the following sequence clear, auto, clear, auto without holding them down, after that all your panel lights should go out. If they do not you have to keep trying...They will go out. -Next program the machine as if your going to make 14 copies -Once 14 is displayed, hit the green start button and your copier should be working again. Cheers! :)
Sep 11, 2006 | Xerox WorkCentre XE88 Laser Printer
Sharp AL 1631 Copier Logo
26 people viewed this question
Top Sharp Office Equipment & Supplies Experts
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
