Can't install router ppoe login error - Computers & Internet
  • 6,487 Answers
If it give you a PPPOE authentication failed that can only mean one thing that you username and password for your PPPOE account from your ISP is not matching try to retype it again and make sure you typr it correctly because its case sensitive if still having a PPPOE error call your isp and verify the username and password from them...
Hope that helps.........
Posted on Aug 09, 2008
How to disable the dchp settings of the router siemens se260??
In order to clear off dhcp settings in any router you need to login into it and select bridging instead of ppoe. ppoe is for dhcp and bridging is for static ip.
Jul 01, 2011 | Siemens Computers & Internet
I am installing a 10/100 Router to my DSL line, but only 1 computer is able to access the internet at a time. When both computers try at the same time there is an IP conflict.
You need to reinstall it again. Try change mode using ppoe.
im also have this problem when i'm forget to change my router to use ppoe, when my friend came and use internet, my pc can't connect. Try it
May 10, 2011 | Dynex 4-Port Ethernet Broadband Router...
I cannot connect to the internet with my linksys wireless router hooked up through my dsl modem. I also lost the installation disk. What can I do to resolve my problems?
DSL uses a ppoe account. Your DSL provider should have given you a router/dsl modem to connect to the internet, and then you can use another router to feed the house a wireless connection. The ppoe user name and password should be set up on one of these devices. If you don't know what your user name and password is, (I forgot mine a long time ago), you can contact your provider and have your password reset. Once this is done, you will either have to connect via wire to the device that should have your user name and password, and set it. Default IP address to get into this router is 192.168.1.1, type that into your address bar on your browser.
default user name and password are both admin, all lower case for both.
Once you get into the device then you can go into the setting and look for connection settings.
Here is the PDF for this router. Start looking at page 5 to learn how to set up a ppoe user and password.
http://www.quickline.com/Shop/Documents/Benutzerhandbuch_WRT160N.pdf
Dec 30, 2010 | Linksys WRT160N Wireless Router
I have at@t dsl ppoe service trying to connect my dlink dir 655 and a bit confused on why it will not work
I use same router at my house and a ADSL2 modem. I put the modem as bridge and enter password and login at the router. Use the wizard configuration of the router and it should be easily done.
If you have the wireless computer with G/N try to use a high channel (>9) for the wireless and avoid this way problems with other existent wireless networkS on your area.
Hope it helps.
Feb 13, 2010 | D-Link Xtreme N DIR-655 Wireless Router
My router will not connect to internet at step 3 on cd
After several hours on hold and internet searches gave up and took router back to store for refund. In the process I did find out what was wrong with my old router and was able to get it going.
Mar 25, 2009 | NetGear WGR614 Wireless Router
Error: 1670 Unable to load Module D:issetup.dll error code 1114
Router setup
If you are using the cd that comes with the router, that is the problem. You do not have to use the cd. Go to the control panel and un-install the program that the cd installed. then:
Shutdown your PC. Unplug the power from the router and the cable modem.
Wait 30 sec. then plug in the power to the cable modem, wait 30 sec. then plug the power to the router. Wait till you have "Internet" light then restart your PC. The PC should pick up an IP address and you should be able to get on-line. This is if you have a cable service provider. If you have DSL, the router needs to be configured with PPOe.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Mar 02, 2009 | Linksys Ultra RangePlus Wireless Routr...
Unable to load install CD
Router setup
Thanks, Joe
Dec 26, 2008 | Computers & Internet
I have a WRT160N and when I put in the install CD it gives me an error code: Unable to load Module D:\issetup.dll Error Code 1114
Router setup
Thanks, Joe
Dec 26, 2008 | Linksys WRT160N Wireless Router
Belkin router
as long as you know your isp password and usename for your broadband connection, all you need to do is connect to the router via an ethernet cable and type in your web browser 192.168.2.1 to enter.
You will need to the router login details which is normal 'admin'
select ppoa or ppoe depending on your isp and the router should connect to the net
Sep 05, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Downloads locks up - Belkin N1 Wireless Router
I had the same problem. My Belkin N1 Router was constantly dropping the WiFi connection (every few minutes). I tried several solutions I found on different forums:
Change the channel selection from Auto to a specific channel -- I tried all 13 channels, but no improvement.
Update the firmware to the latest (Beta) version -- still no improvement.
Finally I enabled "Protected Mode" and the connection seems fine now. Hope this helps, and good luck!
Nov 05, 2007 | Belkin (F5D8231-4) Wireless Router...
Computers & Internet Logo
224 people viewed this question
David Payne
David Payne
