Question about Toshiba Satellite A105 Notebook
Power adapter thanks for the info about the dust build up. this laptop is my Granddaughters and she says that the laptop does not recognize the power adapter and goes directly to battery. could she need a new adapter
    Sergeant:
    Champion:
  • 327 Answers
Welcome to fixya
That could be a problem ... i hope it is just the power cord
sometimes the plug in back of the computer needs to be fixed and that you would have to take to a shop to have it fixed
i hope this helps you out have a good day
Posted on Aug 09, 2008
Dell m5110 laptop won't charge new battery and ac adapter is not recognized in bios
Try another AC cord/charger with the EXACT same specs as original. Is the battery a genuine Dell battery, if not return it? Some aftermarket laptop batteries don't play well with your computer, the pin-out connections aren't correct and MAY be a fire hazard.
Apr 06, 2013 | Dell Inspiron Computers & Internet
Laptop wont recognize charger
Maybe you did damage a component due to overheating? What caused the Laptop to overheat? Does the battery work on another laptop?
Dec 29, 2012 | ASUS Computers & Internet
I have a sony VaIO laptop model PCG-3E2L, and i have notice that it has been turning off by it self. i checked the ac adapter, and its ok.
The heat sink may be clogged with dust and ifthe BIOS temperature sensor controls the fan speed then it may be compensatingfor the reduced cooling by the dust build-up.
If you are not using your laptop on a flat surface, it may beobstructing the cooling vents on the bottom of the laptop. Your laptop fanmay be faulty and not spinning freely, in this case replace the fan.
Check the fan and heat sink assembly and remove the dust, loosen the dust anduse a can of compressed air to clear away the dust. A laptop fanassisted cooling pad may solve your problem
May 20, 2011 | Sony VAIO Notebook
At first the computer would shut off after a few minutes, but now it will not turn on at all. I have verified that it is receiving power. Any ideas?
Battery is dead or dying. Replace it.
AC adapter is not plugged in. Plug it in.
AC adapter has failed, Replace it.
Computer is overheating. Use compressed air to blow dust build-up out of vents and fans.
If this helps please vote for my solution.
Nov 20, 2010 | Compaq Computers & Internet
Power soft touch power switch not working
I am having this problem and found info on another forum saying that the switch is located just above the fan, which causes dust to build up on it.
Mar 22, 2010 | Acer Extensa 4620 Notebook
I had the battery not recognized on boot up. then
the Dell AC adapter has a sensing pin so the bios can determine the wattage of the adapter. If the system cannot ID the adapter, the battery charger circuit is disabled. You'll need a functional DELL ac adapter to get the battery to charge
Sep 26, 2009 | Dell Inspiron 1501 Notebook
Can I use ther Targus Adaptor for Inspiron 1525
On the long term, a power adapter with a bigger amperage can damage battery and battery charger.
Better to get an adapter with same specs as the 65/70W one , or an original replacemant:
Dell Inspiron 1525 New AC Power Adapter Supply $14.29 - Buy.com Dell Inspiron 1525 65 Watt Original AC Adapter $25.00 - parts4nb.com Dell Inspiron 1525 Power Cord PA-12 $16.95 - AmeriMax Advance
DELL Inspiron 1525 DC Power Laptop Adapter ... £25.23 - B2C Shopping UK DELL Inspiron 1525 Laptop AC Adapter power adapter £38.99 - Very Good Battery Dell Inspiron 1525 Ac Adapter Charger Power ... £16.50 - eBay UK
AU/NZ - DELL INSPIRON 1505 E1405 E1505 AC Adapter Power Supply
Dell : Lind Electronics 70-Watt DC Power Adapter for Dell Inspiron
Apr 22, 2009 | Dell Inspiron 1501 Notebook
Power
Hi Mike..
This case mean ..there is loss of power from the Chagring adapter or the power socket ..
so check the adapter with another Dell just to check if its charging or not...
else the power socket which u plug the adapter ..and that's what i guss quz u said the critical light was blinking,,
best luck
Dec 01, 2008 | Dell Inspiron 1501 Notebook
I can not start my laptop.
Try removing the battery and try it just on AC.
What happens exactly? Does it turn on but nothing happens or is it not even powering up at all?
If it doesnt power up at all then try another AC adapter.
Dec 21, 2007 | HP Compaq nw8440 Notebook
Toshiba Satellite A105 Notebook Logo
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
