Sony Playstation 3 (PS3) Console Logo
Posted on Aug 09, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
System recovery error
When turned on, my Playstation 3 console shows a screen indicating i need to do a system restore. The system restore starts automaticaly and upon completetion the system resets and returns back to the initial screen that indicates i need to do a sytem restore....its a continous cycle
Anonymous
Level 2:
Scholar:
  • Expert 106 Answers
  • Posted on Aug 09, 2008
Anonymous
Expert
Level 2:
Scholar:
Answers
106
Questions
Helped
27472
Points
215
Hmm. sounds like a bad drive. you probably need a new one. if that doesn't work, then you need to get a new ps3 because the issue could be with your firmware chip.
2helpful
My ps3 wont read games or movies
This comes from the Playstation Forum:
1. Turn off Playstation®3.
2. Hold the power button down; the system will turn on and turn off once again.
3. Once the System has been shutdown, re-press you finger until you hear 2 consecutive beeps
4. When you hear the 2 beeps take finger off power button.
5. You will be prompted to plug in your controller via USB and then hit the PS button
6. The Recovery menu will pop up.
The current Recovery Menu supports:
• Restart System: Restarts the PLAYSTATION®3 System.
• Restore Default Settings: Reset all system settings back to default.
• Restore File System: Checks for corrupt/missing system files.
• Rebuild Database: Rebuilds the OS for the PLAYSTATION®3.
• Restore PS3 System: Fresh restore; Deletes everything and starts from Scratch.
• System Update: Update the PLAYSTATION®3 System
If it still doesn't work then your lens inside the PS3 needs to be cleaned. Here is a video tutorial that will show you how you can clean the lens inside the PS3:
http://www.youtube.com/watch?v=7O-8NzYHr80&feature=player_embedded
My playstation 3 wont start up, I press the power on button and it goes to start but then switches off
Follow the procedure below to fix the problem on your ps3,
• System Update: Update the PLAYSTATION®3 System.
Take care.
1helpful
2answers
The screen get freeze with multi colors dots on it
Take care.
It turn on and it stay on the main screen
Try these steps below to see if it will fix the problem on your ps3,
Take care.
My playstation 3 will no longer play blue ray movies or DVD why is this. It now just shows a black screen that I can not get out of. How do I fix this?
The PS3 has a special Recovery Menu, which you can access in the following way:
1. Turn off Playstation 3.
• Restart System: Restarts the PLAYSTATION 3 System.
• Rebuild Database: Rebuilds the OS for the PLAYSTATION 3.
• System Update: Update the PLAYSTATION 3 System
From the above select option "Rebuild Database". After PS3 has executed this DB rebuilding operation, the disc games will be visible again in the menu.
Wont read the disc .my sony playstation 3 wont read any disc.
2helpful
Ps3 wont load game circle is there that shows that it is loading but it never loads
I had a similar problem. My PS3 did not start the disk based games. Those disk based games were not visible in the game menu. I did not have problems with the normal movie DVDs or Movie Blu Rays. Those were working fine.
In case you have the similar problem, you should try the following steps;
The PS3 has a special Recovery Menu, which you can access in the following way;:
Select option "Rebuild Database".
After PS3 has executed the DB rebuilding operation, the disc games will be visible again in the menu and are starting automatically when inserted to PS3.
2helpful
2answers
Problem with playstation 3 games and blue-ray
definitely a prob with the blueray laser u need to bring it back to shop or sony as there is no way u can fix it yourself.
Ps3 wont load games up
I had a similar problem. My PS3 did not start the disk based games. Those disk based games were not visible in the game menu. I did not have problems with the normal movie DVDs or Movie Blu Rays. Those were working fine. Also downloaded games were working ok.
6helpful
Ps3 menu
Hi there. if you have PS3 Firmware 2.5 you could be in look. there is a System Restore ability on the PS3 which will allow you to restore your PS3 to a working state. and here is how to do it ! :
hope this Helps !
Top Sony Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
Jose Ramirez
Alexander
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
