Question about Kenmore 53642 / 53644 Side by Side Refrigerator
How to make ice maker work?
Im not sure how to turn the ice maker on?
Model # is 106.44433603
    Problem Solver:
MY FRIGE HAS BEEN OUT SINCE JULY 31, I HAVE BEEN IN STEADY CONTACT WITH THE WARANTY DEPT. STILL HANE GOTTON NO RESPONCE I HAVE FOUR CHILDREN AND MY SEVENTY YEAR OLD FATHER WITH ME IN THE HOME AND HAVE ALREADY SPENT ALL FUNDS FOR GROCERIES FOR THE MONTH HAVING TO PUCHURSE DAILY MEALS INSTEAD OF TOTAL SHOPPING PLEASE HELP US
Posted on Aug 09, 2008
  • devangel Aug 09, 2008
    THE FRIGE IN QUESTION IS LESS THAN ONE YEAR OLD FROM PURCHASE DATE AND IS STILL UNDER WARRANTY
How do I get the ice maker on this model to work?
You did not post the model of what you are asking about. In general make sure the water is being supplied to the refrigerator, make sure the ice maker is turned on. (usually there is some thing in the ice storage tray that will sense how much ice is in there and stop the ice maker when it is full.Make sure that can go all the way to the bottom of the ice storage bin.
Jun 22, 2015 | Kitchen Appliances - Others
Ice maker on amana abc2037dtb is not making ice, but water dispenser works
you could still have a bad water valve. there are 2 ports. i usually jump the ice maker thru a cycle and see if you get 110 volts to the ice maker water valve. if you get a reading the water valve is bad. if there is no reading then the IM head is bad. last and not least, the IM head needs to be pulled down, see if there is a build up of ice in the supply tube to the IM. then you have a problem with the board
May 14, 2012 | Amana Refrigerators
Ice maker not working in sub zero 561 model
you need to make sure that the unit has the water supply turned on. if you have a water dispensor on the front door and you are getting water then the water supply is on.
This ice maker is located in tight spot and has to be removed to cycle it manualy. so im going to give you a different way of doing a test.
first i want you to try to put your finger in the ice maker to see if you have any water or ice in it.
If it is empty then follow this step : try to get water in it without removing the ice maker. Do not fill it to the rim, just about halfway. This wont be easy, but if you do that you can check it the next day and see if it droped ice. if it did then your water valve is bad.
If it has ice in it then the ice maker in mostlikey bad.
or the switch for on and off is bad. (not common)
The freezer has to be under 14 F for most ice makers to operate.
Jan 07, 2010 | Sub-Zero 561 / F
Kenmore refrig model #106-56232400 ice maker
the ice maker unit prob' bad and if you sure it is on and the flag is not stoping it from runing you might need a new unit but there are other tests you can do before..
call me 843.789.4824
Im in Charleston S.C but will happy to help you
www.911servicetoday.com
Dec 30, 2009 | Kenmore Refrigerators
106:533332300 ice maker leaks; replaced
Good day,
Make certain the fill tube is aligned properly and not the problem. As well, make sure the machine and Ice maker are level.
If you installed a new water valve, and there was no change, then yes the IceMaker is probably defective.
Don't need a model number, just take the ice maker in to any appliance parts house. They will match it up.
You don't normally have to go to Sears. Take the model number of the machine with you if you like.
Dec 02, 2009 | Refrigerators
My freezer isnt working
this may sound stupid but is the ice maker turned on? Does it say "ice" in the display? If it does, check to see if the ice level arm is jammed into the upper position also make sure that the ice bin is in place (it actuates the ice maker switch) make sure there is no ice stuck to the top of the ice maker
Jun 16, 2009 | Sub-Zero 700TC Bottom Freezer Refrigerator
Whirlpool Gold Ice maker doesn't work
You definitely have something wrong with the ice maker if the water has turned to ice Schmerold. And the IM is not harvesting. The way it works is the IM needs 28 degrees F to harvest. If the coils below in the condenser are dirty the IM won't try to harvest. The Ice Mold thermostat is mounted on the firewall of the Ice mold in its own little cubby whole. To access it you will need to remove the head. Then remove the shell separating the Ice mold from the heads housing. There you will find the ice mold thermostat. It's only function is to get it on. If the temperature is right in the freezer. To test this precious thermostat one needs only to stick it into a freezer and let it hang out for an hour or so. Then grab it and check it for continuity. If it is open it has failed and belongs in the file 13. It is easily replaced and inexpensive.
On your model, ice maker operation is controlled by an optical sensor mounted on both sides of the freezer liner. The usual failure of this model is a bad emitter board, located in one of these recesses. You may view the service instructions for checking this sensor.
Visit my site, I offer free help and model and parts number search feature. Movies and instruction manuals for most brands. seanreezehvac@yahoo.com click on link below, Thanks, Sea Breeze
I will also send free manual for you through email. And Rate my assistance.
http://servicepartstec.blogspot.com/
Apr 04, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Ice maker stopped working on Frigidaire Model FRS262NHW3...
I would check the valve that provides water to the ice maker before doing any thing with the ice maker head. Check voltage to the valve when the ice maker is in harvest mode. (with a good volt meter). watch the meter for the whole harvest cycle or you will miss the reading. if volage is good 99% chance youve got a bad valve, assuming the inlet tube is not frozen. Best of Luck.
Sep 25, 2007 | Frigidaire FRT18FS5A
Kenmore 53642 / 53644 Side by Side Refrigerator Logo
77 people viewed this question
Top Kenmore Refrigerators Experts
John Tripp
John Tripp
minguy15
Level 1 Expert
mike cooper
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
