Question about Sony Xplod XM-1652Z Car Audio Amplifier
Sony amp xm-1652z what is the r.e.m. terminal next to the neg.& pos.on the amp. and I ran pos.&neg. cable from battery to amp to power on the amp ,but there was no power until I arched a wire from the pos.terminal to the r.e.m. terminal is this safe because the green light stays lite and the amp stays warm to the touch after the car is turned off. p.s. I got the amp given to me without papers or instructions. thanks Mark
    Novelist:
  • 100 Answers
The r.e.m. terminal is the remote terminal. It needs a switched 12 volt source from your battery to turn the amp on. Depending on what kind of cd player you have there, should be a remote lead from the cd player. On most aftermarket cd players it is a blue wire. otherwise you can hook the remote up to an accesory lead that only turns on when the car turns on. If you need I can allaborate on that procedure more. I hope I could help.
-Andrew Hawkins
Posted on Aug 11, 2008
My 77 Chevy c30 has no power. Jumped started it and drove it home. I turned it off then tried to restart it. No power no lights. nothing. Battery is good. An u help will be appreciated.
If the battery is good you will need to follow flow. Test light is the easiest to use. First hook light to ground and touch pos terminal,lights good next touch pos battery cable end, lights good. Next follow pos cable to starter pos terminal,lights good. Next hook test light to bat pos teminal,touch neg terminal,lights good. Then touch engine block, lights good ground. Next move test light clamp back to ground/neg side and touch alt pos terminal,lights good.if all that tests good, if all good move inside and check for power at ign switch pos term if at any time you dont find power you have wiring issue that needs to be addressed. Let me know what you find. Russ
Mar 29, 2015 | Chevrolet Cars & Trucks
Gauge showing low output alt only 1yr old wondering if it could be regulator or batt or wiring
if you have access to a digital multimeter, connect the meter (set to volts) across positive and neg. terminal of the battery, should read roughly 12.6 volts, close to 10 volts, battery may be going out, also test the alt output, disconnect neg term and place negative lead to battery neg post and positive lead to neg battery cable (make sure meter is set to amps) should read near the rating, if both those, then you'd want to do a resistance test, (set meter to Ohms) disconnect battery and connect meter neg to either pos cable terminal or where the pos cable connects to the alt and connect positive lead to opposite of neg, should read next to 0, the check resistance of the ground by connecting meter between batt neg cable and body of alt.
- Spenser
Apr 04, 2011 | 1988 Ford F 250
Can i bridge a sony xm-1600gsd amp???
try connecting power to one terminal and the negative to the other terminal this will bridge the amp
Jan 29, 2010 | Sony Car Audio & Video
How to install Sony Xplod XM-1652Z Car Audio Amplifier
First you will need to post the # of voicecoils each subwoofer has, and their resistance.
Next - you can purchase an amplifier installation kit just about anywhere that will supply you with everything needed to wire up 1 amplifier.
Power wire w/fuse
Ground Wire
Remote Wire
RCA cables
Speaker Wire.
CLICK HERE for your manual.
Thanks for using FixYa - a Very Helpful rating is appreciated for answering your FREE question.
Jul 21, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
One speaker is working more than the other
HAVE YOU THE LEADS ON THE RIGHT TERMINALS POS AND NEG?OR ONE SPEAKER WILL BE GOING BACK THE WRONG WAY, OR GENTLY PUSH CONES BACK SEE IF THEY MOVE THE SAMECOULD BE ONE IS SIEZED OR BURNT OUT
Feb 02, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
Green light, No Power
Disconnect the remote wire and make a jumper at the amp from the 12v + to the remote input and see if you get the same results. If yes, then you probably have a bad ground point. It might not be able to handle the transfer load it's receiveing. If no, then you have an issue with your remote wire or power wire. Check for any kinks or pinches in the wire.
Jan 25, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
How to measure watts
You need a Volt Meter and an Ohm Meter. P = VI & I = V/r, so Power = (Volt^2)/Ohms .
You can get the ohms by hooking them up to the subwoofer input wires, and you get the volts by hooking up to the amp output terminals/wires. Although, amps will put out different voltages for different frequences, this should give you ballpark estimates.
Nov 10, 2008 | Sony Xplod XM-1652Z Car Audio Amplifier
Trouble shooting XM-1652Z Amp
Grab yourself a test light and make sure that not only the 12v red power wire is putting out power but the thin blue or 12 volt turn on wire is also showing power. Then test the ground terminal and make sure u have a good ground. If that doesnt work try checking the amps fuses and check the fuse and connection on the battery. If everything checks out ok and the problem persists then put a small test speaker to the channel outputs and make sure that u are getting noise from those channels if you dont get any noise then u most likely have bad outputs and blown channels, you will need a new amp. Good luck, hope i was good help.
Jan 26, 2008 | Sony Xplod XM-1652Z Car Audio Amplifier
Amp connection
The speaker level input is designed to accept the speaker level signal from a head unit. This is generally no more than 20 watts RMS. If you drive the inputs with more than 20 watts, you risk damaging the input circuits of the amp.
Dec 28, 2007 | Sony Xplod XM-1652Z Car Audio Amplifier
Sony Xplod XM-1652Z Car Audio Amplifier Logo
56 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
