Question about Sony VAIO PCV-RS720G (027242658103) PC Desktop
Sony vaio cpu is makes a lot of noise
Our Sony Vaio PCV-RS720 CPU is always running and makes a lot of noise
  • Donald Harley Sep 27, 2008
    My CPU overheats easily when heavily loaded, especially when processing video. The RPM of the CPU fan increases and makes a lot of airflow noise until I terminate the video task (internet video viewing, video file conversion and compression, etc.). The 3.0 Ghz P4 Prescott CPU generates much more heat than the previous generation P4 (Northwood) at the same speed.and the cache redesign doesn't even work as well, resulting in slightly less performance than the Northwood. One solution is to replace the Prescott with a Northwood of the same speed. Another is to get a copper heatsink/fan to replace the inadequate aluminum one supplied with the computer; and use Arctic Silver 5 heatsink compound, not a less-conductive silicone-based compound. I'd prefer, however to upgrade to a higher performance processor, if this can be done. Will a socket 775 dual core processor (like Pentiun D) work in my Vaio?
  • Anonymous Feb 12, 2009
    I bought my PCV-720G a few years ago and the damn fan is RIDICULOUSLY loud. I didn't think much of it until a family member mentioned it...now I try to use my Vaio to record audio and all I can hear on the recordings is the fan...how can I fix it without replacing the chipsets (as I am NOT all that tech-savvy)
Im not 100% sure nut i think its the power supply cause some power supplys are very noisy and it might be why the cpu is overheating
Posted on Mar 31, 2009
I actually have the very same computer, PCV-RS720G, the best solution is to just upgrade the fan. The easiest thing to do is to take the fan out of the Vaio and bring it with you to Microcenter or whatever your local equivalent is and ask someone in the store for a compatable fan. Unless you feel comfortable ordering on line. I would suggest something with 3 speeds and 9 blades. Silicone pegs (instead of screws) would be a big plus.
Posted on Mar 11, 2009
  • AetaCapella Mar 11, 2009
    As an addendum to my previous statement, the fan you need to replace is the CPU fan the round one attatched to the heatsink... now I don't know if you can find thees anymore as this chipset is fairly old, you might have to replace the entire heatsink assembly...
    Novelist:
    Scholar:
  • 125 Answers
The C{PU isn't causing the noise, it would be the fan inside your computer. You might need to clean from dust or replace it.
Posted on Aug 09, 2008
This is a followup to my September 27 2008 posting, and represents the solution for me. I tried replacing the CPU fan and heatsink and used the best thermal compound. This reduced the fan noise a bit, but under heavy loading the CPU still overheats with the same result as before. Since the motherboard does not support upgrading to a more powerful dual core processor, my final solution was to buy a much more powerful laptop computer that makes no noise and can be easily moved anywhere in my home (I added a WIFI local network). I still use the older computer for some tasks, but I moved it out of the family room, so it would no longer bother us.
Posted on Mar 12, 2009
C'ant see videos in you tube. cpu working 100%
You need to go to MSconfig and turn off all programs you do not need running when booting the computer. Run scandisc and defrag. Make sure that you have a lot of RAM memory. Scan for viruses and malware.
Feb 19, 2014 | Sony VAIO PCV-W1 PC Desktop
What socket is my cpu for my pcv-rs630g
You Pc's Cpu Socket type is Socket 478
Good luck.
Thanks for using FixYa.
Aug 23, 2010 | Sony VAIO PCV-RS630G PC Desktop
My sony vaio VGN-CS11S is soo noisy
The fan's bearings are probably going bad, or there may be some object that was sucked in to cause the noise.
Sep 28, 2009 | Sony CPU FAN CPU Fan
Problem with VAIO PCV-RS320
The broken pins are definately the problem. Any CPU needs all the pins to work properly. This problem is solved by replacing the cpu.
Aug 11, 2009 | Sony VAIO PCV-RS412 PC Desktop
Would like to replace cpu in sony vaio rs402
From the research that I have done, you should be able to upgrade with no problem. I would suggest upgrading your RAM to make things run smoother. Good Luck
C2S
Apr 04, 2009 | Sony VAIO RS402 (PCV-RS402) PC Desktop
Cpu fan control wont stop running
I had the same problem. Luckily, I found the "Sony Fan Control Driver" here:
http://esupport.sony.com/perl/swu-download.pl?template=EN&upd_id=170&os_id=6,7&mdl=PCVRX450
Runs nice and quiet now!
Oct 18, 2008 | Sony VAIO Digital Studio PCV-RX540 PC...
Sony vaio pcv-rz40c1b
You might also consider a power supply. Sometimes they don't die completely, you'll still get a little power from them, but they still need replaced. The motherboard would be the next option, then finally the CPU. CPU's rarely go out before the power supply and motherboard.
Dec 09, 2007 | Sony VAIO PCV-RZ40C1B PC Desktop
Sony VAIO PCV-RS720G (027242658103) PC Desktop Logo
693 people viewed this question
Top Sony Computers & Internet Experts
Brian Sullivan
Brian Sullivan
laikexpert
laikexpert
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
