Question about Kenmore 13.7 cu. ft. / 388 liter Upright Freezer 23424
Freezer motor has burning smell
My Kenmore upright freezer's motor is making electric "shorting-out" noises/sparking noises, and smells like something is burning -- Help! Purchased January 2001, so freezer is 8-1/2 years old.
Annie
  • anniehadden Aug 15, 2008
    You were right, it was the "start relay" that had started melting --- caused by power outage jolts and other things, said the repair person. Too bad we live in the country and the power goes off so much!
    President:
  • 1,462 Answers
Disconnect from mains. take cover off compressor electrics. check starting device - easy to replace
Posted on Aug 09, 2008
Cause for burning smell from lower back of upright freezer
your freezer might be having blockage on the drain pipe thus not allowing water to flow on the drain tray if the drain tray is mounted on the compressor and its dry then the compressor or the condensor pipes are burning the drain tray. the solution to this problem is to service your freezer
Jan 23, 2013 | GE Freezers
There is a horrible foul smelling fish like odor coming from the freezer. It has been cleaned inside and out and we found a dead mouse under the freezer but removed it and then cleaned again. There has...
This is just an idea. the sounds may just be age.. some systems are louder than others and some that are noisy become quiet. But the smell concerns me. It may be that there is something in the cooling fins that is producing the smell. The air from the outside does not directly go into the freezer so I don't think the mouse is the issue. Problems like this usually end up coming from the insulation inside the walls of the freezer. But since you have no history of the freezer loosing power and fish going bad I can suggest anything...If you have any easy access to the inside of the freezer try and take a look. One way to possible clean the smell is to put a bunch of charcoal briquettes on some cookie sheets and put those inside the freezer for a day or two. then switch them out... also you can put a pan of armor hammer backing powder down inside and change that every other day. good luck
Sep 17, 2010 | Kenmore 16.7 cu. ft. / 473 liter Upright...
Foul fish smell emanating from the freezer
Well an old remedy is to put a box of opened arm and hammer baking soda in the freezer and fridge to keep it from having bad odors.If that doesn't work you can try some charcoal it is perfect for absorbing odor, just don't use the matchlight kind or it will smell like lighter fluid.
Apr 06, 2010 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Freezer smells hot and sides are hot
Check behind freezer , to make sure the fan which cools the compressor , is working . If not , replace the fan motor , or , something may be blocking the fan blade ( paper , plastic , etc ) .
Sep 12, 2009 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Compressor very hot on Kenmore 7.5 c.f. upright freezer. It is too hot to touch and smells like burning paint, but stayed cold inside. Wondering if this is a bad compressor and about how much it costs to...
Compressors will normally run hot to the touch, but should not have a burning smell. If the compressor does need to be replaced you would be better off getting a new freezer. Compressor replacement with the labor can run into more than a new freezer.
Aug 27, 2009 | Kenmore Freezers
New freezer. 15 days old. mildew smell in the
There is a curing process for the foam used to insulate these. It can give off a pungent odor until it is fully cured. Only experienced it a couple times in the last 20 years. eric
Jul 08, 2009 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Access to the circulation fan Kenmore upright freezer
There is a panel on the lower back wall inside the freezer.
Remove it to access the fan motor.
Mar 21, 2009 | Kenmore Freezers
Freezer making noise
MY KENMORE UPRIGHT 20.6 CF FREEZER IS MAKING HARMONIC METALLIC BUZZING NOISES. I TRACED THE SOUND TO THE MIDDLE OF THE BACK PANEL. SEEMS LIKE A METAL FREON HOSE OR SOMETHING IS VIBRATING AND HITTING THAT BACK PANEL, BECAUSE IF I PRESS ON THE BACK PANEL THE SOUND GETS WORSE.
MAYBE A MOTOR IS BEHIND THE PANEL, BUT THERE IS NO WAY TO REMOVE IT AND FIND OUT SINCE IT IS PLACED IN A LIP MADE BY THE SIDES AND TOP, AND THEN FOAM OF SOME SORT IS FORCED INTO A SMALL HOLE TAPED OVER IN THE BACK. TO FILL THE SPACE OR INSULATE. HOW CAN I FIX IT? I DON'T THINK I CAN, BUT AT LEAST I KNOW WHERE IT IS COMING FROM.
Jan 23, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Freezer wont freeze - digital display has no display at all -
Melanie--
Because this occurred as a result of a power outage, you need to check that the outlet is OK. Plug something in the outlet like a lamp and see that it works normally. If that is OK, check the display for a light bulb that is burned out--incandescant bulbs do that occasionally in a power outage. If it is an LCD or LED display, the power supply is bad on the display board. Is the motor humming and making normal noises?--and your freezer is just not cooling? If no motor noise, look for a reliable and trustworthy appliance repair person. If the damage is costly, try to pursue a claim with the power company.
Dave M
Dec 17, 2008 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Burning Smell
Keep it unplugged and look for burned wires, or rubber wires hardened from extreme heat. This will be a good start in finding what is going wrong. One more thing to check is if the compressor is heating up after running for a while. Let it run for 20 min or so, shut off the power and feel the compressor. Is it hot?
Jan 12, 2008 | Frigidaire 14 cu. ft. / 396 liter Upright...
Kenmore 13.7 cu. ft. / 388 liter Upright Freezer 23424 Logo
521 people viewed this question
Top Kenmore Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
christian nielsen
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
