Question about Weather King Heating & Cooling
Replacement Repairs My air conditioning unit is slightly less than three years old. It quit working so I called the business that installed it. He found that there was a blockage in the necking device on the evaporator coil increasing liquid pressure 40 PSI. I feel that, in as much as this is within a sealed unit, it is a manufacturing problem, not one due to my environment or my doing. It is a very expensive part to replace and I feel that there is some responsibility on your part for this problem. Please respond.
  • 182 Answers
Most units have a 5 yr parts warranty but you would be resposable for labor.
Posted on Aug 09, 2008
Air condition system is no longer working and the person who checked it out says it needs a new system installed
get a second opinion when this statement is made
ac units only need replacing if parts are no longer available for repairs or the quoted repairs make it uneconomical to repair when compared to new units
for example
if your units is 15 years old, parts will be scarce and if it needs a compressor the cost of the part and labor will be close to the price of a new unit
new units are inverter units and are less costly to run and the larger units have reverse heating capability which makes them a heater unit in winter
best advice -- get a second opinion and then quotes for new units and make a decision on that information
Jan 22, 2017 | Cars & Trucks
We have recently had three problems with our three year old Carrier 24 ACA airconditioner that I believe has led to it no longer producing the low temp. chilled air it did when it was installed. !. water...
Your air temp should be at least 20 degrees cooler than the indoor air temp. This is ideal. But it sound like your unit is low on freon. When units get low they will freeze up. They will also freeze up if air flow is restricted on the inside coil or the fan quits on the external unit.
Aug 08, 2010 | Carrier 38CKC024 Air Conditioner
DeLonghi Pinguino PAC CT90 It is less than a year has quit coolin
Read instructions and see if it says anything about cleaning or filters. A.C units **** air in and there is a filter that probably needs cleaned.Also,while cooling, the vent to the outside should put out warm air. Also, if it is less than a year old, contact the manufacturer and they should help you out. Good luck.
Feb 13, 2010 | DeLonghi Pinguino PACL90 Portable Air...
My washer went on control lock and now it wont turn on i tried to unplug it but nothing works
Would plug something else into outlet to make sure your power supply is ok. If you remove bottom panel in front(three screws) or top panel(three screws in back and slide panel back slightly to raise off) there should be a tech sheet with some suggestions. If it is less than a year old call for warranty service. Keep kids away with panels off. If unit is completely dead a guess would be main control board on top, but that is just a guess.......
Jan 19, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Goodman AC unit - fan starting outside but not getting cool air.
set the thermostat at alow temp normaly after few minute the compressor and the fan will start , if are stying off check control signal is energising the compressor relay if ok check the relay coil; if all are ok ncheck the capacitor then check if the air is still hot means the charge of freon is less and also before charging check the leak
Apr 27, 2009 | Goodman CLJ30AR32 Air Conditioner
WHEN THE HEATER COMES ON THE FAN STARTS INSTANTLY AND BLOWS COLD
Do you have a heat pump? If so this is normal. You are probably used to a gas furnace. There are heat pumps that do have a delay though. Look on the circuit board in the air handler. There may be a set of pins that say 0-30-60-90 yours may be at 0. Also some digital T-stats offer that function for delay off to get the extra heat or cold from the system. Find out what the model number of the air handler and call the Goodman supplier in your area to see if you have these options.
If you have a gas furnace and it's not delaying the blower there is definately something wrong.
Mar 17, 2009 | Goodman Heating & Cooling
Possible defective Maytag central airconditioner
Defective is a pretty broad term. If the unit isn't working its defective. You should have at least a part warranty. I'm assuming you bought an extended warranty/ labor warranty.
May 26, 2017 | Heating & Cooling
Air Conditioner Blows Warm Air (or at least not cool)
When serviced by a qualified service tech who finds and repairs a leak before recharging a system it is not illegal. However with the age of your unit you may want to balance the possible cost of a new unit against the cost of repairs to the old one. After repairs are made to an old unit you still have an old unit.
Jun 04, 2008 | Kenmore 72055 Air Conditioner
Heating & Cooling Logo
29 people viewed this question
Top Weather King Heating & Cooling Experts
Donni Steen
Tim Whalen
John Tripp
John Tripp
Are you a Weather King Heating and Cooling Expert? Answer questions, earn points and help others
