Question about Lexmark X7170 All-In-One Scan/Copy/Fax and Photo Printer
USB Connector Replacement
Is there any where I can buy a usb connector replacement (the part that is in the back of the printer where the usb cord connects)
  • sleeviroj Jan 26, 2009
    Is there any where I can buy a usb connector replacement (the part that is in the back of the printer where the usb cord connects) in the U.S.??? I have an HP 2015 Printer...Please email me @ sam1423@sbcglobal.net...Thanks.
  • 101 Answers
Locating and buying the connector is the easy part!.
if you live in uk then:
rswww.com
www.cpc.co.uk
Extracting the old connector is another thing, unless you have got specialist soldering equipment I would leave it.
Posted on Aug 09, 2008
Reset my Dell 926 all in one printer
The Dell 926 printer is an All-In-One model that you can use as a printer, scanner and a fax machine. When the printer becomes unresponsive there may be a communication problem between the printer and your computer. To correct this type of problem you need to first verify that the USB connector cable is not malfunctioning. You can do this by resetting the communication settings between the computer and the printer.
y1 Press the "Power" button to turn off the printer. Unplug the power cord from the electrical outlet or the power strip.
    • 2
      Disconnect the USB connector cable for the printer from the computer.
    • 3
      Turn off your computer from the Windows "Start" menu or by pressing the "Power" button.
    • 4
      Plug the USB connector cable back into a USB port on the computer.
    • 5
      Plug the power cord for the printer back into power strip or electrical outlet.
    • 6
      Press the "Power" button to turn on the printer. Press the "Power" button to turn on your computer.
Oct 22, 2011 | Dell Photo 926 All-in-One Printer
There wasn't a USB cord there. What cord shou8ld I buy?
Printer connection cables are not always included; this is something to watch for when purchasing new printers.
As an example, Lexmark sells a USB (2meter) cable for use with their printers. It has a Type A connector on one end (connects to computer) and a Type B connector on the other end (connects to printer).
See illustration here:
http://www.lexmarkshop.ca/product_info.php/info/p547_USB--2-Meter--Cable.html?XTCsid=8uf9jfg007037lui6nbrrvkko5
You should however be able to purchase a suitable cable at your local supplier; there are also on-line suppliers who are very reasonably priced.
Try to stay under 10 feet or 2 meters in length and ask for a cable with a Type A and and a Type B connector for use with an USB printer interface.
Trust this is helpful. Please vote.
Dec 30, 2010 | Office Equipment & Supplies
Usb cable not detected
  1. Disconnect one end of the cable and then reseat it ensuring the cable is firmly seated into the USB port. If the USB cable is plugged into a hub instead of directly into the computer, connect the USB cable directly into the computer.
  2. Repeat step one to reseat the cable on the other end.
    There shouldn't be any resistance when connecting the USB cable to the device. If the cable does not easily slide into the device's port, look at the end of the connector. The shape of the connector should match the port on the device.
    Note: All USB cables will have a USB icon on one side. The side of the cable where the icon is situated is different than the other three sides.
Icon on USB Cable
Shape of the USB Connector
  1. If there is still no communication, then it may be necessary to try a different USB cable or a different port on the computer.
  2. Make sure the correct USB cable type is being used.
Incorrect (A to A) USB Cable
Correct (A to B) USB Cable
Nov 02, 2010 | Canon PIXMA MP170 All-In-One InkJet...
I've lost the cord that connects the printer to the computer. What type of cord do I need?
You need a standard USB printer cable. It will have a different type of connector on each end. The end that plugs into your computer is Connector 1: USB Type A Male
The end that plugs into your printer is
Connector 2: USB Type B Male
Jun 16, 2010 | Epson Stylus CX5800F All-In-One InkJet...
I have lost all plug in's for my desk top printer can I order new one?
HP and other companies will quite happily sell you one but you will pay a premium price for it. You can also just buy any replacement power cord for a pc for a few dollars. The usb cable is also just s a standard item. If you can buy them locally you should get both for under $10 instead of being cloers to $50 from HP. I've run across both in dollar stores and computer shops.
The only thing you have to watch for when you buy a replacement is making sure the printer usb cable has the correct ends. One end that plugs into the computer is a standard USB connector and the printer end will either look the same or will look like a doghouse shape (seenon end). Just look at the printer before you go to the store and you should be fine.
Apr 19, 2010 | HP Deskjet F340 All-In-One InkJet Printer
Just got a brand new canon pixma 320 mini photo printer that didnt come with a usb cord so I can't print from the computer
USB printer cords (D type connector) can be found at many retailers including Wal-Mart and online at places like newegg.com. My favorite is firefold.com. http://www.firefold.com/USB-20-Cable-A-Plug-B-Plug-C8.aspx
Oct 04, 2009 | Canon PIXMA mini320 Photo Printer
Can i use any usb cord to plug my printer into tower? Moved and found power cord but not other and i forgot what it looks like.
There are various types of USB cables for various purposes.
You need to look at the USB connector on the printer and the computer.
The USB connector on the computer will be a female connector approx 13mm x 5mm and have 4 contacts on one side.
The printer USB connector most likely will be a female connector approx 9mm x 7 mm and two corners have a small chamfer.
The printer cable will most likely be 4 pin USB A male to B male type.
Mar 31, 2009 | Dell 926 All-In-One InkJet Printer
Lost usb connection cord any suggestions??
I bought a new usb connector in The Reject shop for $2. MP3 back up and running!
Dec 28, 2008 | Verge DFP-200 MP3 Player
I'm not sure if I have the correct cord or if I have it pluged into the correct port.
It is either a usb "A" connector which is the squarish side of the usb cable and the flatter "B" connector is the side that goes into your computer's usb jack. Some printers, like yours also still use a parallel port which is a Centronics big, wide rectangular connector that connects to the printer side and the other end is a DB25 parallel connector than goes to the parallel DB25 printer jack on your computer. You must have at least one of those cables but you only use one or the other. The usb will be configured to a usb local printer port or the parallel will use the LPT1 port. HP.com will provide you with a quick install brochure with pictures for you to see. post back if you need more help! Steve Medley
Oct 21, 2008 | Office Equipment & Supplies
Lexmark X7170 All-In-One Scan/Copy/Fax and Photo Printer Logo
120 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
