Question about Acer DVP 1640A Internal DVD Drive
Acer cdrw dvdrw drive
My cdrw dvdrw drive says its not supported and acer dosnt have a good websiite for support so if any body cant get me fit up it would help alot
  • 2,794 Answers
There's a bug on their website that isn't getting you to the support section. You should contact them by e-mail to get the problem solved.
This is as far as I got
Posted on Aug 09, 2008
Where do i insert a disk in a dall latitude E7440?
It doesn't have a CDRW drive. Only an optional smart card reader slot.
You'll have to buy an external USB DVDRW or CDRW drive.
Jun 28, 2014 | Toshiba Satellite M115-S3094 Notebook
Acer dvd-rw and cd-rw
If you have installed these devices yourself check that the jumper settings on the back if the drive anre set correctley if they are plugged into one cable you must have one set to master and the other as slave .
If these devices have work ok previousley go into device manager and delete your cdr and dvdrw and the delete the ide or sata controler and reboot this will cause all the drivers to reloaded the check to see if the y work
Jun 01, 2012 | Computers & Internet
Dvdrw drive for acer vista computer is missing how do i fix it?
Sometimes your CD/DVD drive is hidden by default if it's empty. There is a setting for that. If you have a disk in there and the drive is not showing up then you should check the power and sata or ide cables to the drive inside the case. If they are connected properly, then you need to replace the drive.
Jun 01, 2012 | Acer Computers & Internet
My nephew has a dell inspiron 1525 & the college computer center told him his dvdrw is broken. What dvdrw will work in it
Any CD/DVD-writer drive will work -- just remove the face-plate and mounting-brackets from the "dead" drive, and connect those parts to the "new" drive.
Dec 10, 2010 | Dell Inspiron 1525 1526 24x CDRW/DVD Combo...
I cant burn any dvd, but cd r or rw are capable . mayber the driver is out of date..please help me.
hi
perhaps the CD media you purchased is not compatible with your CDROM drive ..?
what is the model number oif the CDROM ? what computer model is used in ?
Nov 15, 2010 | Computers & Internet
DVD writer of DELL Vostro 1400?
if it has a DVDRW drive the yes.........if CDRW/DVD then no.....but it can read dvds
Dec 29, 2009 | Dell Vostro 1400 / Inspiron 1420 - 24X...
My Matshita UJDA 750 DVD/CDRW wont recognize a blank DVD discs. How ever it does read both CDs and DVDs and only burns CDs.... please help
Are you trying to burn a dvd? If so from the spec you gave in the problem description your drive will burn cds(CDRW) but will only play dvds(DVD). If it stated DVDRW then you would be able to burn DVDs as in the CDRW.
Mar 06, 2009 | Evesham Voyager 6400 Notebook
Cdrw and ethernet card
realtek is a good brand NIC, and sony or Lite On cd/dvdrw
Apr 23, 2008 | Zonet Fast Ethernet Adapter Realtek 8139D...
Have problem with computer allowing me to copy to dvd-rw or cd-rw. I can play both, but can not copy to discs. I have windows xp professional version 2002 service pack 2
Please remember to always note Computer specifications and Operating system details when you post a problem and to explain your problem in more detail( Specify your CD-ROM / DVD Drive more)
If you cant burn DVDRW or CDRW it is likely that your Drive does not support burning these Formats. You can check on your drive at the front; it should tell you what it supports.
Another solution could be that you are not using the correct software to burn your DVDRW/CDRW. I recommend using: Nero
Kind Regards,
Stef
Apr 15, 2008 | Computers & Internet
Install question
Take the side of the case.
You should be able to get to the back of the slot where you want to install the CDRW.
Just push the bezel in the middle and it shoudl bend releasing the plastic catches securing it in the slot.
It is plastic and you are going to throw it in the garbage so dont worry about pushing to hard.
Let me know if this helps.
Feb 29, 2008 | Acer-Veriton-M410-US3800P AMD Desktop PC -...
Acer DVP 1640A Internal DVD Drive Logo
148 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
