Question about Dymo LabelWriter 400 Thermal Printer
DYMO THINKS ITS OUT OF PAPER ....
Hi all
Pls can somebody help, my new dymo ran out of paper for the first time then now after installing a new roll of labels only prints half alabel then thinks its out of paper and front light flashes, ask to re-print it just pushes out half a label etc. Pls help as im going to hrow it out of the window
Thanks xx
  • 6 more comments
  • Anonymous Aug 21, 2008
    Dymo Labelwriter 400 worked perfectly on MS XP OS, with 99016 labels. Used all the roll and put in new roll 30258 and the printer only prints half the label and continually reports it is out of paper.....
    Tried installing updated driver... same result
    moved labels closer to the left hand side of the printer so that the perferations between the labels were lined up... same result
    tried different label setting so that the printer thought the labels were longer and might print the whole text on the shorter label... no success
  • brijal__pate Oct 09, 2008
    Please anybody help. I have same problem of paper out.
  • Anonymous Oct 17, 2008
    same problem I was used Large add label. It was ok. Now I refill a standard add label. The printer shows me "out of paper". .........
  • needfixednow Dec 20, 2008
    I am having the same problem with the DYMO Duo...only it's December and you all have written these in August...no luck with solutions. this sucks...I'm about to pull my hair out!
  • Anonymous Jan 07, 2009
    Printer thinks its out of paper, although it's still fully loaded. Won't print at all.... help pls !
  • dixie1471 Apr 24, 2009
    Looks like that without the silly barcode prints on the back then we have no chance. Dymo want the label sales aswell as the printer sales. Damm!
  • Anonymous May 06, 2009
    My Labelwriter 400 has not been used for quite some time and now he gives me all the time: out of label
  • DamnDYMO May 11, 2010
    Wasn't their some EU ruling with regard Printer Manufacturers and chipped Ink Cartridges. I think EU Competition Laws need to be invoked ;)
New versions of the Labelwriter 400 (original and Turbo) do not take Generic Labels. It is an issue with the firmware Dymo have installed - it will only reDYMO THINKS ITS OUT OF PAPER .... - labelwriter400.jpgad the genuine labels made by Dymo. currently there appears to be no work around to solve this isses.
The Dymo OEM labels have lines print on the back, if you use labels without these lines, the printer gives an "out of paper" error
The only printers in the Dymo Range that will take our generic labels are the Dymo Twin Turbo and the Dymo Duo (both the more expensive from the range).
Dymo have only made this change in the last 6-8 months, old 400's will work with cheaper generic labels
Posted on Apr 14, 2009
Hia I had this problem for a while and I unplugged it from the computer for 30 seconds and replugged it and it printed. Just be careful to CLEAR THE PRINT HISTORY!!!
Posted on Aug 30, 2011
  • huynhmh84
    huynhmh84 Dec 03, 2012
    Awesome, worked great, thanks!
Had the same problem after replacing the labels.. After many unsuccessful attempts, had a breakthrough.
I placed the labels tightly close to the right border.. worked like a charm. The blue light stopped blinking and printing running smooth.
Posted on Jul 01, 2012
    New Friend:
I had the same problem with my LabelWriter Duo on my Mac OS X 10.10.5 (Yosemite). Print queue wouldn't clear "out of labels" error message after changing label rolls. I used Dymo brand labels. Unplugging and replugging the power cable and the USB cable did not work. Rebooting my system did not work. This worked: opened System Preferences > Printers and Scanners, deleted the LabelWriter driver from the sidebar list, added a new instance of the LabelWriter driver and attempted printing again. The error was absent from the new print queue and printing resumed normally.
Posted on Jan 24, 2016
  • Linda
    Linda Feb 01, 2016
    THANK YOU SO MUCH! This worked perfectly! I tried everything imaginable and was about to pull my hair out! You saved the day (and my hair)!
I had similar problem. Dismantled printer and cleaned all connectors and sensors. Then discovered that the "Genuine Dymo label paper" was a bad batch. The black timing marks were missing in a central portion of the label roll.
Posted on Jul 10, 2012
  • avonremote
    avonremote Jul 10, 2012
    I had similar problem. Dismantled printer and cleaned all connectors and sensors. Then discovered that the "Genunine Dymo label paper" was a bad batch. The black timing marks were missing in a central portion of the label roll.
  • Ramin Shahinfar
    Ramin Shahinfar Jan 11, 2015
    thanks it work
Just remove and reinsert the front cover - it fixed it for me for a brand new Dymo printer.
Posted on Mar 26, 2012
DYMO Labelwriter 450 thinks its out of paper! New roll fitted
Hi Chris, the Dymo's are very picky regarding the paper. Make sure you have genuine Dymo paper roll inserted and not the cheaper generics. You will notice the Label Position Hole placement is punched in a different location( ever so slightly ) in relation to the genuine labels.
Aug 11, 2017 | Dymo Office Equipment & Supplies
DYMO LabelWriter 400 Turbo Installed but gives error message when sending prints
First of all, on Dymos you need to use original Dymo roll,.
Dymo rolls have a tag at the back, non original ones does not have it.
Before reinstalling driver you also need to run the dymo uninstaller utility that you find at Dymo website.
I will post the links for download.
Oct 03, 2008 | Dymo LabelWriter 400 Turbo Thermal Printer
The print is faded at the bottom of the card
If the problem started when you changed label rolls, the problem is most likely the newly installed label roll. In the picture below is an extract from the Dymo Users Guide going over print quality issues.
Dec 17, 2014 | Dymo LabelWriter 400 Turbo Thermal Printer
Label writer 450 is only printing half a label and then the blue light flashes like it is out of paper. New roll, worked fine before it ran out
Make sure you use genuine DYMO labels, not compatible ones. Also, make sure you select the right size in DYMO Label.
Disconnect the USB cable and the power cable to reset the printer. Check if the roll is loaded properly - the holes between the labels have to be on the left. Connect the power cable. If the blue light is solid, connect the USB cable and try to print.
Check the DYMO Label version (Help > About). If it is below 8.5.0, you have to update it.
^CM
Feb 08, 2013 | Dymo ® LabelWriter® 450 Series PC...
How to reset the dymo labelwriter 400 printer
Make sure you use original DYMO paper, otherwise the machine may be confused as to where to begin and stop. Also, cleaning the print head is a good idea if you have had the printer for a while.
The latest software is crucial. Right now it is version 8.4.2, you can see which one you have by clicking on Help > About DYMO Label.
If the above does not help, you are welcome to contact the DYMO help desk (dymo.com and select your country).
Dec 02, 2012 | Dymo LabelWriter 400 Thermal Printer
My dymo labelwriter 450 says its out of paper when I try to print a label. When its initially connected the printer says "ready" as soon as a print command is made it says it's out of paper....
Hi, I had this problem and found that the labels were rolled up the wrong way, make sure the series of horizontal black lines on the labels are nearest to the left side of the printer as you look at it, this worked for me, hope it helps - Paula
Jun 19, 2011 | Dymo LabelWriter 400 Thermal Printer
My dymo says it is out of paper even I just put a new roll of lables in. What do I do to reset the dymo so it will think there is paper?
Disconnect the USB cable and the power cable to reset the printer. Connect the power cable first, then the USB one, try to print.
^CM
Dec 08, 2010 | Dymo ® LabelWriter® 450 Series PC...
Can you use regular thermal paper rolls in the Dymo 400 turbo printer?
It should work. I have one of those tiny label printers, and thermal paper does indeed work.
Aug 27, 2009 | Dymo LabelWriter 400 Thermal Printer
OUR DYMO LABELWRITER TWIN TURBO JUST STOPPED PRINTING--
OK! The first time you tried to print ON THE LEFT SIDE, without anymore labels there, there was a "pending" error message in the print queue. This typically cuts off all furtther printing, as all subsequent requests are "behind" it in order or priority.
To fix this, open the Dymo Labelwriter "Printer" dialog box (double-click it on the tray or go to "start / control panel / printer and faxes" - then double-click on "DYMO LabelWriter Twin Turbo". Once open, you'll see a list of "failed" print requests. Somewhere in there you'll find the one with the "laserwriter output" out of paper message. Select that and cancel or delete it.
If this was the problem, all your attempts will now print (make sure you have enough postage paper in, and you'll have extras you can use, I'm sure!
Hope this helps.
Jun 17, 2009 | Dymo LabelWriter Thermal Printer
Consistantly Intermittent Connection Problems
If you've tried installing the latest drivers and the problem persists it sounds like you have a lemon. The printers have a 2 yr warranty, so I would contact the retailer you purchased from and replace the printer. If your labels are jamming. Try the compatible File Labels available at LabelValue.com. They have both the Dymo 30327 and Dymo 30277 labels in a compatible version.
Feb 29, 2008 | Dymo LabelWriter 400 Turbo Thermal Printer
Dymo LabelWriter 400 Thermal Printer Logo
34,423 people viewed this question
Top Dymo Office Equipment & Supplies Experts
Ed Mac
Jax Planet
Jax Planet
Are you a Dymo Office Equipment and Supply Expert? Answer questions, earn points and help others
