Question about Hoover Floormate H3000 Upright Wet/Dry Vacuum
Brushes Can the brushes be ajusted down or do you have replace them when they are worn?
    President:
  • 1,673 Answers
You will have to replace it, it comes as a brush block. Part number is 59177038 $34.00 tableWorkaround2(1)
Posted on Aug 10, 2008
Have replaced motor brushes & now popping sound when running, with sparks seen in filter housing. Please advise.
The armature is bad, you need to replace the whole motor. IF the armature has worn down where the brushes contact it, then it is continuously shorting out when it runs.
Dec 12, 2015 | Dyson DC14 Animal Bagless Upright Cyclonic...
When do you replace the brush on a vacuum cleaner
Replace when the bristles are worn or frayed or if they are not stiff. To check the length of the bristles, make sure your vacuum is unplugged, lay it upside down and lay a card or straight edge across the bottom plate to see how much bristle sticks out. If it's even the the bottom plate it's time to replace it.
Feb 20, 2015 | Vacuums
The brush bar is not turning
1) test the belt for broken or worn, and replace
2) test the motor for brush, lubrication, dirty,
3) pulley worn and replace.
4) brush bar worn or defective repair
God bless you
Jul 14, 2012 | Dyson DC14 All floors Bagless Upright...
My dyson DC17 makes a loud noise when i tip the handle down to make the brush spin on the floor?
Loud noises are usually caused by worn belts, unbalanced roller brush or debris in the roller brush. Check these things. Here is a link to the belt you need:
Dyson DC17 Replacement Belt
Nov 28, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Dyson DC07 brush roller is worn and won't make contact with the carpet anymore. I need to replace the brush roller but don't know how...HELP?
Buy the brush over the web etc..
To take the brush out
1 - Take the outer covering - uese a penny to turn the yellow srews
2 - Slide the black brush out from the assembly - Try the non belt side first.
3- Slide the belt out of the brush.
4 - Take brush out - Replace it with new one.
May 09, 2009 | Dyson DC07 Allergy Blue/Turquoise Bagless...
My purple and red Dyson has become hard to push. Could a belt have broken?
It's simple to tell if a belt has broken. Just switch the machine on and have a look (look, don't feel) to see if the brush roller is rotating. If it is, then the belt is not broken.
Depending on how much use your machine has had, it's quite likely that the brushes on the brush roller are worn to the point where you need a new brush roller.  Most vacuum cleaners rely on rotation of the brush roller to pull them along, so if the bristles are too short this doesn't happen.
I hope this helps. Please remember to rate this response.
Mar 11, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Carbon Brushes wearing out quickly on Kirby Heritage II
4 possible reasons.
1 – one or both bearings are worn so armature (rotating part) wobbles as it is spinning and cause motor brushes to wear fast. Solution – change bearings too.
2 – Whoever replaced brushes – did not use some brush seating sticks to make cmutator smother and contour brushes to the shape of the comutator (not likely). Solution – appropriately install new set of brushes.
3 – Comutator is so warped that seating sticks do not help anymore – solution – new armature or turn the old armature.
4 – The fact that ONLY ONE brush was worn may mean that there is something wrong with the brush or housing. Maybe it could not move freely within the housing? I think this may be most likely cause it it may be a combination of all 4.Is it worth to fix? Hmm depends how much will it be. If this is 100+ - I’d say get newer Kirby for 300 ad enjoy the tech drive (Heritage does not have tech drive so it is much harder to vacuum with than the newer models)
Nov 05, 2008 | Kirby Heritage II Vacuum
SEBO Power Brush
Hi.
Hold A straight edge over brush head EG ruler.
Now rotate brushes slowly by hant they should just touch the ruler, If there is a gap then brushes need replacing.
http://dysonmanuals.llc.nu/index.htm
Chris.
Mar 14, 2008 | Vacuums
Hoover Floormate H3000 Upright Wet/Dry Vacuum Logo
29 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
