Question about JVC Televison & Video
I HAVE A JVC HD61Z456 HOW 2 REMOVE THE LAMP - JVC Televison & Video
    Scholar:
  • 167 Answers
HELLO Iit can be accessed thru the front of the set. you will have to remove the screws that hold the speaker panel on the front of your set. !!! after removing the speaker panel you will see a small square box with a handle with two screws holding it on, you will have to unscrew those and pull on the handle to remove. hope this helps. "GOOD LUCK"
Posted on Aug 09, 2008
SOURCE:
70 rear projection jvc no picture and bulb ok
Hello, remove the lamp and make sure it didn't go bad. If it's ok the a color wheel or fan would be my next guess, but check the lamp first, I see cheaper lamps that don't match up correctly fail early. let me know what you find...tks
Feb 24, 2015 | JVC HD-70FH96 70" Rear Projection HDTV
Where is the ballast to turn on or "fire"the lamp on a JVC HD56-GC87 LOCATED??
I don't see a way to attach a file. Reply or send me your email address. I will send you the entire dis-assembly procedure.
3.1.3.18 REMOVING THE LAMP BALLAST BLOCK (Fig.6)
• Remove the LAMP COVER.
• Remove the BODY COVER.
• Remove the BODY BRACKET.
• Remove the MAIN UNIT.
(1) Remove the 2 screws [H].
(2) Remove the LAMP BALLAST DUCT.
(3) Remove the 2 screws [I].
(4) Remove the LAMP BALLAST UNIT.
(5) Remove the 1 screw [J].
(6) Remove the LAMP BALLAST BRACKET.
Feb 18, 2015 | JVC Televison & Video
How to replace a lamp on my jvc tv
If you haave the original manual, this is discussed at the start of page 91. If you dont have manual, it can be obtained at books.jvc.com
1. Purchase lamp TS-CL110UAA
2. Turn Off and unplugg set
3. Remove lamp cover located on the left side of TV
4. Remove and replace lamp
5. Reset lamp counter in menu for accurate hour information.
Jul 26, 2014 | JVC HD-52G786 52" Rear Projection HDTV
I have a jvc hd52z585. while watching tv it turned off and the lamp light and the power light are blinking at the same time. i have unplugged the tv for a couple of hours. when i plugged it back in it does...
very easy.
there is 1 thumb screw behind left speaker grill.unscrew it to remove the grill.the lamp is behind that.after changing the lamp,go in to CUST.MENU,scroll down to reset lamp timer. Best price for lamp is pureglare.com. Inspect the lamp for internal glass particles for 100% verification of being bad. Also at the root of the glass stem in the middle look for bubbling of the glass. This is another sign of a bad lamp.
May 20, 2011 | JVC HD-52Z585 52" Rear Projection...
HOW DO I REPLACE THE LAMP
Hello
To replace lamp in JVC projection TV follow the steps below.
[1]. Order a compatible replacement lamp from JVC. Order a replacement lamp from JVC's Accessory Store or a local authorized parts distributor to ensure that you obtain a compatible replacement lamp. To order a replacement lamp, you must have the lamp type and lamp code of your JVC projection TV, which can be found on the rear of the television.
[2]. Turn off the television and allow the bulb to cool. For safety reasons, turn off and unplug your television before accessing any of its internal components. Wait at least 20 minutes before attempting to replace the lamp so that it has time to cool down. If the back of the television is not warm or hot to the touch, it is safe to begin removing the lamp
[3]. Unscrew and remove the lamp door. The lamp door on JVC projection TVs is located on the rear left of the television and is shaped like a square. Several warnings related to the lamp will be printed on the door. Use a Phillips-head or flathead screwdriver to remove the large screw, then remove the door
[4]. Unscrew and remove the lamp assembly unit. After you have removed the lamp door, you will see the lamp assembly unit. Use a Phillips-head screwdriver to remove the two screws. One screw is on the top right corner of the unit and the second screw is on the bottom left corner of the unit. Detach the lamp assembly unit from the compartment by lifting the handle and pulling the unit away from the television
[5]. Install the replacement lamp and secure the lamp door. Hold the replacement lamp assembly unit by the handle and insert it straight into the compartment. Reinsert and tighten the two screws onto the lamp assembly unit with a screwdriver. Place the lamp door back onto the television and tighten the screw to secure it to the television
[6]. Reset the television's lamp timer. Press "Menu" on the television's remote, then scroll to and select "Lamp Timer Reset." Press "OK" to rest the timer. A prompt will appear notifying you that the timer has successfully been reset
May 18, 2011 | JVC HD-61Z786 61" Rear Projection HDTV
I have a JVC-HD projection TV model 56G786 and all of a sudden it will not power on. When you try to turn it on the blue light on the power button goes on but after a few seconds it starts flashing and...
The JVC 56G786 users manual will not give you a clear or specific answer about confirming bulb failure with the LED lamp or power indicators located on the front of the TV.
If the TV was operating normally for an extended period of time (months or years) and will not start, the problem is almost always bulb failure. If the "Lamp Replacement" warning previously appeared "On-Screen" and the TV will not start, bulb has failed.
The first step in a "no picture" situation with a JVC LCD Rear Projection TV is bulb replacement. There is no way to measure the bulb. Sometimes the bulb is visibly broken or damaged when it fails. Remove the lamp cage and have a look.
The JVC Lamp Gallery has all the JVC models and lamp numbers listed. There is also a link to DIY JVC bulb and lamp installation.
If a good bulb is installed correctly and the TV still does not start, you need a technician. There are no user serviceable parts other than the bulb. Failure of ballasts, power supply boards or controller boards is rare in these TVs.
easyab
May 05, 2011 | JVC HD-56G786 56" Rear Projection HDTV
How to replace a jvc HD61Z456 lamp
check on sides of tv you should see a little square cover, open it remove the lamp and replace it, and put it in. that should fix your problem, if you need more help please feel free to call me at anytime. 602-810-7149
Dec 31, 2010 | JVC HD-61Z456 Television
Hey i just replaced the lamp in my jvc 61' tv and needed to know how to reset the time
Scroll down the menu till you see "Lamp Reset " press Enter and your done..
Apr 22, 2010 | JVC Televison & Video
Red temp and lamp light flashing
you may need to replace the lamp in the unit, to do so, remove the lamp and if it sounds like a rattle inside when you shake it, its blown due to heat ,hence the red temp and lamp warning. after replacing the lamp make sure you reset the lamp use hours. good luck.
Sep 26, 2009 | JVC HD-56FB97 HDTV
Blue light and lamp light flashing, no picture.
Look in the owners manual for the directions on how to remove the lamp. Your model the lamp goes in from the front on the left looking at the TV. There is a thumb screw in the back on the corner holding the left front speaker on. Under the panel there is another thumb screw holding the lamp door on. You will need a Phillips screw driver to remove the lamp. You will most likely find that the lamp is bad. You will either have to order a lamp directly from JVC, a service center or a parts distributor.
Apr 21, 2008 | JVC HD-52Z575 52" Rear Projection...
Televison & Video Logo
106 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
