Breville ESP8XL Espresso Machine
Problem for Breville ESP8XL Espresso Machine
Pressure but no water
By ossomd on Aug 09, 2008
Water goes into filter cup but will not flow through filter. Pressure builds so it is hard to remove cup from the machine. It does this with either coarse or fine grind coiffee.
Same Problem
Dec 01, 2008
-   Note that if you use coffee that is too fine, it accumulates between the walls of the filter, and even poking the one hole doesn't seem to help. I am not sure how to clean my dad's filter now... I keep poking the hole and trying to run water through the filter, and it gets plugged right away... -   isabelzaza
Best Solution
posted on Aug 09, 2008
Helpful)
mirran
Rank: Guru
Rating: 87%, 326 votes
Make sure your filter is clean, take the filter and head it to light. If it is clean then you can see a little hole in the midle.
Was this helpful?
Yes
No
Solution #2
posted on Oct 21, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
The metal filter cup clogs up constantly. Poke out the tiny hole with a needle. But the real fix is find some pod type coffee filters and put that in the bottom of the filter cup before adding the coffee. You can even cut out your own if you cant find the little round discs. Been doing it for months and no more clogs ever.
Popular Solutions for Breville ESP8XL Espresso
Questions and Unsolved Problems for Breville ESP8XL Espresso
Do you recommend Breville ESP8XL Espresso Machine?
Answer
Answer
missing black frother wand for esp8xl. How do I get this missing part?
Answer
On first use, after it got to the right temperature, the water would not run through (ESP8XL model).
Answer
The strainers are stopped up and can no longer be used. The machine leaks.
Answer
Filters don't fit into filter holder. Can't put filter holder into place onto machine
Answer
My frother no longer functions. What should I do?
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Coffee and... Experts
Top Small Appliance Repairmen
(316) 283-4211
(316) 283-8664
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
