Question about Oster 12-Bottle Wine Cellar - Black
Oster 12 bottle wine cooler
Same as everyone else - question the fuse under the black cover does not appear blown by continuity check - will replacing it with a larger fuse still work?
  • 1 more comment
  • Anonymous Dec 19, 2008
    why can't we just fix this issue by replacing the fuse? Is it not able to be replaced or something?? I just bought one off of craigslist with the fuse issue and I thought I would see online about the issue before opening it up to replace the fuse. Am I out of luck??
  • Anonymous Feb 08, 2009
    oster does not reply and the manual states that the fuse will blow when there is a power outage, now I can't even get the stupid fuse. what is going on......
  • Anonymous Mar 14, 2014
    not working
You must remove the fuse from the circuit board to check it. More than likely it's blown. A continuity test while in the circuit will always show the fuse as being good due to feedback through the circuitry.
Posted on Nov 22, 2008
Hello:
I contacted the comapny via email on their website and apparently this model was produced under the Oster name by another company. Since then, the company has shut down, disconnected all numbers, and took down the website. They are trying to resolve the issue but I have not been told any thing other than my name is on a list.
Sorry, but I am going through the same thing.
Posted on Oct 13, 2008
Mine went out 4 months after I got it for Christmas 2007. I have spoke with Oster & they said for me to trash mine. I followed their instructions and mailed back the power cord along with my receipt & they were suppose to refund my money. Haven't heard from them & the phone # doesn't work any longer. 866-866-6283, do you still have your warranty paperwork, if so it is a different phone? thanks
Posted on Sep 24, 2008
Digital temperature display is missing part of the
You are going to have to replace the display. Easy fix even if you are not very familiar with this system
Jan 02, 2010 | Oster 12-Bottle Wine Cellar - Black
I have an Oster 12-bottle wine celler model OWO912H6H that was a Christmas gift in 2007. I just noticed the temperature is 98 degrees and I cannot get it to come down with the down button. I am very...
Hi, could be faulty thermostat, can you check compressor, is compressor running (working), listen to compressor for clicking sound, unplug it(switched off) for about 20 minutes, replug and let it run (work) for another 20 mins. see if temp. drops, what about temp. inside bottle (wine) cooler, is it 98 or colder, more info. could be valuable. check thermostat, check to see if compressor operates, if cooler temp. 98. remove you products, to another cooler, call mechanic.
Aug 12, 2009 | Oster 12-Bottle Wine Cellar - Black
Wine Cooler Does NOT get cool.
Here is the web site to locate your closest oster service center. They should be able to tell you what their charge will be up front so that you can compare that charge to the cost of a new one.
Now days, sadly, many of these items are too costly to repair so they go to the landfill..
http://www.oster.com/CustService.aspx?content=center
May 21, 2009 | Oster 12-Bottle Wine Cellar - Black
Don't cool-no refund/satisfaction from Oster.
Ok, fist problem was unit quit working..if it quit cooling yet lights still worked inside and still had power readings on door is not power coord. If the unit stoped cooling is probably fuse and there are two of them in back of unit. One fuse clearly can be seen, the other is coated with a black shrink fit coating and is not well seen. This second fuse is the problem, you will need to replace it. I have same unit and this is what I had to do to get it cooling again.
Jan 21, 2009 | Oster 12-Bottle Wine Cellar - Black
Wine cooler temperture
blown fuse in back panel, there are two of them, one you can see, one is in black shrink rap, this is probably problem fuse. It was on my unit and had to cut away the shrink rap and solder in new fuse. Found the problem fuse in top left of panel in back of unit, hope this helps.
Jan 19, 2009 | Oster 12-Bottle Wine Cellar - Black
The fan does not go on
Ther are two fuses in back panel of unit. One fuse can be seen other is hidden top left of panel and is coated in black shrink rap. I had to replace that fuse to correct the problem. Problem is I had to cut away shrink rap and resolder another fuse, you may have to have someone who can do this look at your uint. Hope this helps.
Dec 19, 2008 | Oster 12-Bottle Wine Cellar - Black
No response from company on Oster 12 bottle wine refrigerator
just replace the 5amp fuse on circuit board with a 6.3amp. tada!
use an exacto knife to remove the shrink wrap on both ends of old fuse. heat ends with a soldering iron and pull away old fuse. solder new 20mm in line fuse holder from radio shack to both poles insert 6.3amp fuse and done. at least mine works again! $6.00 total cost!
Dec 15, 2008 | Oster 12-Bottle Wine Cellar - Black
Fast start option does not work
I'm not sure how you ended up under this classification;
All Products > Oster > 12-Bottle Wine Cellar - Black > Troubleshooting
but your problem with an undescribed brand and model will not likely ever get a response.
I think your question is in regards to a microwave oven. Try reposting it with the correct brand and model #.
Nov 06, 2008 | Oster 12-Bottle Wine Cellar - Black
Oster wine cooler fuse
I just replaced mine with a "Slo Blow" and it is working just fine. Got it at Radio Shack , 4 for approximately $3.
Sep 25, 2008 | Oster 12-Bottle Wine Cellar - Black
Oster 12-Bottle Wine Cellar - Black Logo
487 people viewed this question
Top Oster Furniture Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
jasbo
jasbo
Charles T Nevin
Charles T Nevin
Are you an Oster Furniture Expert? Answer questions, earn points and help others
