1997 Jeep Grand Cherokee Logo
Posted on Apr 21, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
1997 Jeep Grand Cherokee Laredo It turns on then sometimes it turns off as I put it on drive or it gets stalled. It also makes a funny jerking-jumping move while on driving as it is going to turn off or as if it does not gets enough gas. Where is the fuel filter located? I have not tried anything yet. I do not know where to start. I thought the fuel filter is the most logical staring point.
Ricky Peters
Level 3:
President:
  • Jeep Master 2,620 Answers
  • Posted on Apr 21, 2011
Ricky Peters
Jeep Master
Level 3:
President:
Answers
2620
Questions
Helped
730593
Points
7327
Thats where i would start more than likely its over do for change anyway.Then check your fuel pressure no matter if its a 6 cylinder or 8 cylinder it should be 44-54 psi with key on engine off.If not within specs replace pump.HOPE THIS HELPS!!
Testimonial: "Thank you. I will try your advise and hope it works. Fast reply is very much appreciated."
1999 jeep grand cherokee laredo just stops while driving
Does it stall at idle or going down the highway? Does it restart right away? How long since a tune-up? Are there any applicable trouble codes? Check the cam and crank sensor. Could be other issues?
Sometimes the oil drive housing can cause a sync problem between the crank and cam sensors?
1helpful
Sometimes my 1997 Jeep Grand Cherokee Laredo will not start up. You have to hold the gas pedal to the floor and turn the key in the ignition before it will start. What is wrong with my Jeep?
if it has electric fuel pump turn the key on but dont start the engine you should hhear the pump turn on. do a pressure test on your fuel pump
I have a 1997 jeep grand cherokee laredo. it has
Sounds like a bad battery to me. Turns over really slowly? Also, be sure to check your oil, this is extremely important!
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
I have a 1997 jeep grand cherokee laredo hard starting
not sure when a tune may have been done but that is a suggestion and cleaning the throttle body throat with some cleaner.
1996 Jeep Grand Cherokee Laredo was not firing but now after replacing PCM and crankshaft and cam sensors and checked all fuses and relays it is getting correct amount voltage and will crank but while...
Chk the battery ground cable, Remove and clean. Then chk your charging system at the battery. Should charge between 13.6 and 14.2v If it is charging above 14.2 your alt is barely charging, The further below 13.6 the more amps the alt is putting out. Make sure you battery has adequate water in it. A battery will rejuvinate itself after it has gone dead after sitting awhile,but only enough to last a few minutes. Turning on you headlights would kill it right then.
2answers
I have a 1997 jeep grand cherokee with automatic and 4.0 six cyl engine--it drives great for a day or two then stalls out seemingly for no reason--now tonight it has no spark from the coil--so I feel it is...
Unlikely that it's a computer. Check your coil and the grounds, make sure you don't have any breaks in the wires that could cause an intermittent problem.
Top Jeep Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Jeep Expert? Answer questions, earn points and help others
