Question about Acer AL1711 17" LCD Monitor
Acer al1711 monitor
You said that the 1000uf....470uf caps on the inverter board they are two of each should all 4 be replaced? (c 922,c924,c925,c926) thanks for your reaponse.
  • fpclarke Sep 18, 2008
    yes , it solved my problem. thanks.
  • KONNN Oct 15, 2008
    I have an Acer Al 1714 that won't power up at all , i tried plugging to other outlets and even conntected to other computer/standalone and does not work............it's not drivers or computer..........what is it exactly and how do i obtain a diagram for the exact fuses or whatever i'll need..................PLEASE NO VAGUE ANSWERS OR SEND TO REPAIR SHOP ANSWERS ON HOW DO I FIX ANSWERS.
  • Acer Master
  • 5,568 Answers
I don't know if you ever got a response to this post since it isn't attached to the exchanges you had with someone before. Always retrieve your original otherwise the person who assisted you is unlikely to see your reply.
BTW, if you have done this by now, did it solve your problem? Often, the larger caps are not at fault but smaller ones that handle feedback in an inverter. The main filter caps are not subjected to the high frequencies and ripple currents that destroy the electrolyte in them.
Posted on Sep 17, 2008
Acer AL1711 monitor it almost too dark to read. have tried to adjust brightness etc. nothing seems to work. any help would be great. thanks
You probably have a back light problem. This is caused by a faulty inverter board or a faulty CCFL lamp.
LCD screens and Inverters are available from these WEB sites. www.lcdparts.net http://www.yallstore.com
Jun 29, 2011 | Acer AL1711 17" LCD Monitor
My Acer AL1711 goes black but the light indicator on..i've read some of comment similiar to my problem and tried to repair it..but still..it didn't work..i even replaced the 1000uf capacitor..but...
When you repalce the caps, they should be repalced in a set since bad caps can look normal but can have high ESR.
http://s807.photobucket.com/albums/yy352/budm/ACER/Acer%20AL1711bm/
And yes, you can have bad lamp assembly:
http://s807.photobucket.com/albums/yy352/budm/Bad%20backlight%20lamp/
You need spare lamp the test the inverter board.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
May 20, 2011 | Acer AL1711 17" Flat Panel LCD Monitor
Had the blank screen problem. Now it won't work above 800x600 res
When I replace caps in this model, I replaced all the caps (4 (1000uF by the heat sink, 1 (470uF) by the inverter transformer) for the 5v and the 12v since you cannot 100% relying on just by looking bulging tops. I am not sure why your has 3-470uf. See my example here: http://s807.photobucket.com/albums/yy352/budm/Princeton%20VL2018W/
Jan 23, 2010 | Princeton Digital VL2018W Monitor
Acer al1711: two monitors with same problem
The most likely cause is blown capacitors on the power supply/inverter board. Go to our web site at: www.ccl-la.com/badcaps.htm we have pictures of what the capacitors look like when the blow out. We also have some dis-assembly guides that may help you. Just open the back of he monitor and look at the board, replace all the blown capacitors that look like the ones in the pictures and you should be back going. The values hat you will need are going to be marked on the sides of the bad caps. Be sure to use a low ESR and high temp replacement or you will have to do this again in a month or two. We carry the proper caps in stock if you want us to supply you with them. The caps at Radio Shack will not do. When you replace the bad ones be sure to install the new ones with the polarity stripe on the side going the same direction as the old ones come out. If you have any additional questions just let me know.
I hope this helps, if you please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
tech@ccl-la.com
Sep 18, 2009 | Acer AL1711 17" LCD Monitor
Del e173fpc 17" power light comes on but screen black.
The issue you have is caused by a bad power supply. If you change the following capacitors on the power board you should be back running again. C925 and C924 are 470uf 16v and C922 and C923 are 1000uf 16v be sure to use high temp capacitors not just standard that you would find at Radio Shack, if you do they will blow again with in a month or two. We have a parts kit available and I will have picture posted on our web site at :
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Sep 05, 2009 | Dell E173FPc 17" TFT LCD Flat Panel...
Monitor goes black after a few seconds
I have the same problem on my Acer AL1711. The monitor was out of warranty so I opened it up and found one of the 1000 mf capacitor almost ready to pop. A 50 cents replacement from allelectronics.com fixed the problem.
Not recommended for anyone without experience soldering electronic components to PCB's.
Dec 11, 2008 | Acer AL1711 17" LCD Monitor
When i switch on my P.C. and my FP 5313 screen it flickers
This is a known problem with a series of components inside the monitor. There are about 11 capacitors that if replaced will allow the monitor to function properly.
The best place to go to read more is http://www.badcaps.net/forum/printthread.php?t=2658
The list of the capacitors that are bad are below with possible replacements.
C922, C925: Hermei LE 1000uF 16V, low impedance, general purpose, replacing with 1000uF 16V Samxon GF.
C201: Hermei LZ 150uF 25V, ultra low impedance, high ripple current, replacing with 1000uF 25V Samxon GF.
C924, C926, C929, C930, C932, C933: Hermei LT 470uF 16V, high ripple current, low impedance, replacing with 1000uF 16V Samxon GF.
C207: Unknown CD110 50uF 4.7uF (general purpose), replacing with a 35V 4.7uF tantalum unit (SCP/Short Circuit Protection pin on TL1451 won't get anywhere near 35V).
C907: WC (with stylized Westinghouse W) SM 22uF 50V (general purpose), replacing with 63V 100uF Samxon GF (used for SMPS controller Vcc filtering).
C905: Hermei HT 100uF 400V, standard, general purpose, leaving as is - generally no problem.
Dec 06, 2008 | HP Compaq FP5315 15" LCD Monitor
Acer al1711
We have repaired a couple of these. R1 on board normally burnt also C6 and C22 bad on inverter board. Replace these and it will probably work. R1 is 10 ohm. Capacitors are 220uf 25v.
Nov 07, 2008 | Acer AL1711 17" Flat Panel LCD Monitor
Acer 1711, entering sleepingmode in few seconds
same prob on mine gues its the inverter board but not tried yet
Jan 13, 2008 | Acer AL1711 17" LCD Monitor
Acer AL2021
I fixed my AL2021 by replacing the output caps on the power board. $4 repair. Pull the thing apart and replace the 1000uF, 680uF and 470uF caps on the end of the power board.
Jul 10, 2006 | Acer AL2032WD 20" Flat Panel LCD Monitor
Acer AL1711 17" LCD Monitor Logo
116 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
