Question about Alba Televison & Video
I don't understand how to record using my camcorder connected to the alba dvd recorder.
    Master:
  • 848 Answers
I have successfully recorded from camcorder on to disc on my Samsung SH893M machine. But can you please tell me how to record from video tape to a dvd disc.
you need to connect your wire to VCR out put and connect the other side to DVD input don't forget yellow to yellow, red to red and white to white if you have 3 prongs wire.
Jun 07, 2011 | Samsung Televison & Video
I have a dcr-sr200 and have 7 hrs worth of video to burn that took about five hours. But when I check it the time date stamp did not appear. I can seem to figure it out . please help
I understand that you have burned the videos to a disc using Computer and the burned videos does not have the date and time on it. In order to get date and time on videos taken using the Hard Disk Camcorder, the video should transfer using A/V interface with the DATA CODE option on the Camcorder enabled.
Once you enable DATA CODE, the date and time will be shown when playing videos in the Camcorder. You can view when you connect the Camcorder directly to a TV. While using the A/V interface with Computer to capture videos using an Analog Video Capture Software like Windows Movie Maker, you will get the videos in Computer with date and time displayed. You can burn those videos using a burning software.
If you're using stand alone DVD Recorder, you can enable the DATA CODE and use the A/V interface to connect the Camcorder to the DVD Recorder to get the date and time on videos.
Thanks for understanding. Please let me know for clarifications. You can also give more information about the recording method you're using to give more specific instructions.
Apr 30, 2011 | Cameras
I have a DVD/VCR recording device and I need to hook up my camcorder to record videos to a DVD to submit to an organization for my son to receive a service dog. I can hook up camcorder straight to TV...
To record to the DVD, connect the A/V cables from the JVC GR-D347U to the A/V In on the DVD recorder. Since the DVD already plays to the TV, you just have to keep the TV set to that input. Put a blank DVD in the recorder. Set the DVD recorder to record on from the appropriate Line In (input) with the DVD as the target recording media. To make sure that all of the devices are on and receiving the output from the camera and DVD recorder, start playback on the GR-D347U and check that it displays on the TV. Forward the tape in the camera to the point where you want to record to the DVD. Stop playback. Press REC for the DVD recorder and restart your playback. Press stop for both the DVD recorder and then the camera when the desired video segment has been played back.
See page 21 of the manual for the GR-D347U. Treat the DVD recorder as a VCR for this situation. The manual is available here: https://www.manualslib.com/manual/82266/Jvc-Gr-D347u.html?page=21#manual .
I hope this helps. Please add a comment with the details of the DVD recorder for more information on connecting the unit in this daisy chain.
(Many recorders have at least two composite video Line In inputs. That's why you need select the correct one for recording.)
May 19, 2017 | JVC GR-D347U Camcorder
I'm getting a message "Camcorder not connected. I can't program any recordings
When this recorder reads 'not connected to camcorder' you are simply accessing the recorder's 'DV' input on the front panel of recorder. This 'DV' input is used with DV Camcorders, thus the message.
Simply hit the 'AUX' button on the remote control to access the recorders other inputs. It will cycle between-TUNER>>AV1>>AV2>>DV.
Depending on what you want to access or view and where they are hooked up to the recorder. The "Tuner" will access either your over the air digital channels or your basic cable channels when hooked up through the 'UHF/VHF' input on the rear panel.AV1 is input 1 on the back of the recorder. AV2 is the input on the front of the recorder. DV allows for a Digital Video Camcorder to be hooked up to recorder using a 'Firewire'.
Oct 29, 2009 | JVC DR-MV100B DVD Recorder/VCR
Need to transfer order VCR-C tapes to DVD How
You will need to borrow or buy a DVD-Recorder, either way it's best to follow the manuals instructions on how to connect your camcorder (external device) to the DVD Recorder for Recording to DVD. Most camcorders come with a set of AV (audio/video) Cables for this purpose. On your camcorder you will find a little rubber door that houses the terminals to connect your cables to. Depending on how old your camcorder is you will find a Yellow (video) and a White (audio) and on the newer ones that have stereo capabilities...you will have a Red (audio), all these connections are video and audio Out-Inputs and should be connected to the Video and Audio "In" terminals on the back of the DVD Recorder. Now make sure your battery is fully charged (It's best here to use an AC Adapter for your power supply instead of your battery, which also usually comes with your camcorder if bought new.) and that your VCR-C tape is loaded and completely re-wound. Now if you want to watch this on your TV while you are recording to DVD...you'll need another set of AV Cables that come with a new DVD-Recorder, and hook these cables on the Out-terminals on the back of the DVD- Recorder and the other end of the cables to your TV's Video/Audio-IN terminals on the back of the set. Finally...Set your camcorder switch for Playback, turn on the DVD Recorder, And turn on your TV. Now you can go ahead and record all your VCR-C tapes to DVD! Any other questions? Contact me directly at over4dy@yahoo.com
Jul 29, 2009 | Video Cameras
Alba DVD recorder won't recognise any discs
The Alba DVD recorder may not recognise any disc due to one or two of the following reason.
1, the optical pick up (lence) may be dirty or may have gone bad.
2, the cable which connects the optical pick up to the circult panel board may have go borken.
Jan 04, 2009 | Televison & Video
Unable to connect dvd/vhs recorder to record via freeview box
Can you give me the model number of the dvd/vcr and set-top box?
Jan 03, 2009 | Daewoo DVRS04 DVD Recorder/VCR
Recording to dvd RW's from mini dvd's from panasonic camcorder
I didn't understand your question.
All dvd player can play mini dvd's. Why do you want to transfer it on a normal dvd disc???
Jan 04, 2008 | Samsung SC-DC164 DVD Camcorder
How to Record From a TV Using PV-GS13?
connect a lead via your tv video out audio out jacks. Select tha appropriate channel (You may have to go through the av channel on you tv and tune in the channel you want to record) or, video or dvd player audio out video out jacks. connect other end to your camcorder. Select on the camcorder menu video in audio in. Turn on tv. If connected to video or dvd player, press play. Press record on your camera. When finished recording press stop. Presuming the camcorder is tape, you can buy a tape adaptor to play or record your mini tapes in a standard video recorder, then take them out of the adaptor and play them back on your camcorder. You can also do all this via a computer. Also if the camcorder is disk or hard drive it can be used the same way as a regular dvd recorder to record tv programmes once connected to you t.v. Let me know how you go 26 red
May 08, 2007 | Panasonic PV-GS31 Mini DV Digital...
Televison & Video Logo
87 people viewed this question
Top Alba Televison & Video Experts
Demonic-2011
Demonic-2011
Michael Galve
Michael Galve
Are you an Alba Televison and Video Expert? Answer questions, earn points and help others
