I have ink buildup on the side of the printer that receives the printer cartidges when the printer finishes printing. In the case of my HP, the right hand side. How can I clean up the mess in there?
Well, I have since consulted the HP web site and they said not to worry about it and that I might do more harm than good trying to clean it up...soooo..I guess I will leave it alone.
Posted on Aug 17, 2008
  • 1,198 Answers
The ink hopefully is water base; have lots of paper towels, hand wipes, Q-tips. You can use a nail file or a screwdriver to scoop up ink and wipe it on a paper towel. It wouldn't hurt to have a wet wash rag handy. Don't be rough with the machine, you don't want to break anything.
Posted on Aug 09, 2008
Ink streaks
Ink streaks are usually caused by a buildup of died in on the print heads. There are two print heads in that unit. Remove one at a time and look for build up - clean it if you find any. Once you finish cleaning both print heads you will need to do a print head cleaning routine in the HP software to clear out any in clogging the print nozzles.
Oct 01, 2012 | HP Officejet 6500 Wireless All-in-One...
Scanner component scans and prints normally. Trying to print off an e-mail is a different story. The little screen says 'printing' and it goes through the motions. You can hear the carriage travelling line...
check the ink cartidges (the color ones) scanners use just black ink to print with (all grayscale) if you can't buy/ afford cartidges right now (who ISN'T broke these days!?!) then set the preferances on the printer to "black/ grayscale" and see if that works ( also is a good test to see if ink is out)
Mar 04, 2011 | Kodak EASYSHARE 5100 All-In-One Printer
My printer just prints in very light red
You are out of red ink, OR the print head is clogged (but that usually) produces streaky lines more so than light color.
You can try cleaning the print heads:
  1. Open the 3845 desktop assistant c00026601.gif icon on your desktop or start menu
  2. click on utilities or tools
  3. click maintenance
  4. click clean cartidges
  5. follow the on screen instructions
If that doesn't help, you're either out of ink in which case:
  1. Buy a new cartridge (or have yours refilled professionally)
or your print head is clogged beyond repair, in which case:
Happy printing.
Jan 27, 2010 | HP Deskjet 3845 InkJet Printer
Hp printer error massage no black ink supply NEW CARTIDGE IN have tried reinstalling several time
Hi Jack,
What I understand from your message is that, when you try to print from the computer, you are receiving a message "No black ink supply"...
Solution: If you have installed the full featured AIO software on your computer, then open the HP solution Center on your computer, then click on the settings>> print settings>> Printer toolbox.
Then click on the Configuration Tab and uncheck the option "Display the ink level message". Then click on the Device tab and try to print a Diagnostic page and then click Ok to close the solution center. Then resart the computer and try printing..
I am pretty sure this will resolve the issue..
With Regards
Feb 02, 2009 | HP Photosmart C6180 All-In-One InkJet...
HP PSC 2410xi color printing issues
Try using warn distilled water and Q-tips to gently clean the area where the ink cartridge and the carriage mate up. You may have dried old ink in there which is clogging the print nozzles. Allow to air dry, reinstall cartidges, start machine and let it go through its cleaning cycle. Also check Hope this helps.
Jan 30, 2009 | HP PSC 2410 All-In-One InkJet Printer
Hp f4288 all in one black cartridge( N0.818) refilling method
when i fill this cartidge after finishing the cartidge is not printing why?
Dec 03, 2008 | HP DeskJet F380 All-In-One Printer
Printer Designjet 110 Plus not working
Ink supplies Description HP part number 11 Black Printhead C4810A 11 Cyan Printhead C4811A 11 Magenta Printhead C4812A 11 Yellow Printhead C4813A 10 Black Ink Cartridge C4844A 82 Cyan Ink Cartridge C4911A 82 Magenta Ink Cartridge C4912A 82 Yellow Ink Cartridge C4913A
alot of printers now if the ink in the cartidge is the first ones placed in the system from the box are those that are only half full if not less depending on the maker but I know HP only fills their cartidges only just under the half way make but the printer sees it as a new cartrige because of the chips programming.
Have you tryed to turn the power of and let is sit for about 5 mins and turn it back on with the same result? (ushally a yellow error light is on)
Also if you can find the settings to only print in black and white on the printers properties that might also work as well for a temp fix.
But ushally once one ink runs out it likes to do that you where correct with the "is it because of the finished color cartidges.." either that or the carts all have finally expired.
Nice printer by the way.
But your best way to do it would be to replace the color carts and if not reasonable to do now there is also a way to reset the color carts so that the printer thinks that there is ink in them as well.
hope this helps you a bit if you need more info please let us know.
Aug 02, 2008 | HP Designjet 110plus nr InkJet Printer
How to refil ink in hp 2120 cartidge
actually your printer cartridge was cloted or maybe airlocked.
You must use tissue paper and rub it on the nozzle side. Ink may flow out.
Jul 30, 2008 | HP Office Equipment & Supplies
HP Deskjet D4160
This is Vikram Kumar Thumu from India-Hyderabad. I have seen your issue and I would like to provide my solution on the issue.
Well, this is the issue that could happen with either with Printer Software or with Printer Ink cartidges that could be out of ink or very low in ink...
To isolate and to resolve the issue I recommend you to perform below solution. I hope that this will fix the issue for you.
Solution 1: Hard Reset Printer
1. Turn OFF printer
2. Disconnect Printer from Computer.
3. Remove the Printer Power Cable from wall outlet and then try to remove the ink cartidges from Printer.
4. Wait for a minute.
5. and then reseat the Printer ink cartidges and then Connect the Printer cable to the Computer and then Power ON Printer.
This should generally fix the issue. However, if the issue still persists then I recommend you to proceed further solution on the issue.
Soltution 2:
Right click on the Printer icon of HP Deskjet D4100 Series and then select the option " online " and then press F5 key in the keyboard. to effect the changes.
Solution 3:
Try to print a Cartidges Test page from Printer Properties to check the ink cartidges ink status.
if found issue with ink cartridges then replace them else try to uninstall and reinstall the Printer software.
This should resolve the issue. If the issue still persists then I recommend you to contact HP CHAT SUPPORT or HP PHONE SUPPORT team or HP EMAIL Support on this issue. They can help you further to resolve the issue for you.
If you need any further assistance you can mail me at I 'll be glad to help you ...
Mar 27, 2008 | Apple HP DeskJet 3820 InkJet Printer
37 people viewed this question
