Question about Hoover U6630-900 WindTunnel Bagless Upright Vacuum
NO SUCTION Hello There is pleny of suction in the hose,but there is no suction when vacuuming.
  • 4 Answers
I fixed the very same problem about 15 minutes back. Mine is a 6660-900 but I believe all Hoover windtunnel uprights probably have the same basic design with minor differences. It has nothing to do with the belts.
When the vacuum is used with the hose, you are using it in the vertical locked position. When using on carpet, you step on a release tab/lever on the left corner of the deck. When you do this, a plastic gate opens diverting the vacuum (air flow) from the hose to the deck near the rolling brush area. When this gate gets stuck for some reason, it doesn't open even when you release the tab/lever. What I had to do was to open the cover over the brush roller (4 screws) near the front of the deck. Then when I wiped the bottom portion of the deck under where the hose is connected to the deck, I realised that the plastic there is clear plastic (it was covered with lot of dust before I wiped it). On the side where the hose connects to the deck, right under it is a tubular channel connecting to the brush roller area. Through the clear plastic of this channel, you will see a plastic disk blocking the channel opening. With the power disconnected, release the level for carpet cleaning (so that the deck can move relative to the handle). Now push with a finger on the plastic disk to make it go in and up. In my case some thread like material was caught between the disk edge and the channel/tube making it impossible to open with just the air pressure. After I removed the obstruction, the gate disk started moving freely when the vacuum was set for carpet cleaning. I put everything back together abd tested. Now it works beutifully.
If your model is different, you may find some minor differences but there has to be a vacuum diverter for the two positions. Just make sure it directs the vacuum where it is supposed to go.
Posted on Oct 25, 2008
Thanks for the input - I went out and paid $400 for a Dyson Animal VC and was basically sick to my stomach because of the cost. It seems that I had just purchased my Wind Tunnel. Anyway, after looking at the reviews above, I quickly took my VC apart to see if I could fix it....It turned out the belt was so stretched out and that was the problem. I had checked it previously thinking since it wasn't broke, than how could that be the problem. Bottom line, although the Dyson, I'm sure, is a good VC, that ****** is going back tomorrow. Wind Tunnel works just like it did out of the box. Thanks everyone for your input.
Posted on Nov 23, 2008
I cannot see the back of this model, so can't be sure this will help. I was having the same issue. The spot where the hose comes into the back of the machine is an l-shaped connector. I removed the hose and it was filled with fibres and dust that had gotten caught in the scraps of paper and such that had gotten stuck over the last few years. Works great now!
Posted on Nov 07, 2008
  • 97 Answers
If you mean that it is not picking up on carpet, then you need to change your belt. On any vacuum with a rubber belt you must change it every 3-6 months whether it breaks or not, and no matter how often you use it.
If there is actually no airflow at the nozzle there is probably a clog between where the hose connects and the front of the nozzle.
Posted on Aug 09, 2008
Plenty of suction from the hose pipe itself but no suction when vacuuming the carpet
Hello Can,
Go through this guide to help find the issue You should have suction without a filter. The bottom is on the unit, right? It needs to be air tight.
Apr 21, 2011 | Vacuums
How do I switch the vacuum from floor to accessory suction
It automatically switches over when you disconnect the hose from the power nozzle. No suction it getting to the power nozzle, so the suction is only through the attachments. If there is no suction through the hose, check for clogs in the hose and in the tank where the hose plugs in. Also, check the screen at the bottom of the tank. If there is a clog in the hose or tank, then there also will be no suction to the power nozzle.
Remove all clogs and you should get suction.
Dec 19, 2010 | Hoover U5721-900 WindTunnel Upright Vacuum
What do to if keeps spitting things out even if new bag is in?
It sounds like the roller brush is going, but the vacuum isn't working, i.e., no suction.
If you have a canister vacuum, disconnect wands from hose and place hand at end of hose. If there is suction, it's fine. If not, disconnect hose from vacuum, turn on vacuum, and hold hand to intake. If there's suction here, then the hose must be clogged; or holey hose can result in greatly reduced suction.
If it's an upright, the hose could be clogged. Or the fan broken, which would also result in no suction. It would help to know what model you have.
Oct 21, 2010 | Oreck Vacuums
Model UH60010, Series X12.0, Mfg code K09A. While attempting to use the hose and the extensions to clean shelves, my wife reported no suction. I removed the brush roller and the plastic piece just below...
There are six different reasons a vacuum can lose suction, a plugged vacuum hose, bad motor, full vacuum bag, or cracked or damage hoses. Purchasing a vacuum cleaner can be a costly expense while repairing the suction on the unit can be virtually free. Most suction loss problems on a vacuum can be easily fixed or remedied with common house hold tools and very little technical expertise.
If your vacuum cleaner losses suction, the first and easiest solution is to check the bag. If the vacuum cleaner bag is full suction will be greatly reduced and the unit will become ineffective. A vacuum cleaner works by passing air through the bag fibers leaving dirt and debris behind inside the bag. If the refuse bag becomes full, airflow is restricted, limiting the amount of air passing through the vacuum bag resulting in loss of suction. When replacing the vacuum bag always consult your owners manual to insure that the vacuum bag seals with the vacuum inlet hose. If your vacuum cleaner bag is not tightly sealed to the vacuum inlet hose you will decrease the air flow through the bag resulting in loss of suction.
The second and sometimes most common reason for loss of suction on a vacuum cleaner is a plugged vacuum hose. If the hose becomes plugged, air flow will become restricted. To unplug a vacuum hose detach it from the machine and inspect the inside. If there is a restriction in the hose, remove it with your fingers and replace the hose onto the unit. If the hose is long and the debris is hard to get too, a broom handle or other long object can be passed through the hose to dislodge the debris. Most vacuum cleaners contain more that one suction hose, so make sure to check each one by process of elimination. Another area that can become easily plugged on a vacuum cleaner is under the lower base of the unit by the roller brush. Large debris can get caught in this area and restrict air flow to the hose.
If your vacuum refuse bag is not full and the suction hoses are not plugged the next thing to check is the condition of the hoses. Many hoses are made from plastic which can easily tear or crack. If your vacuum cleaner shows signs of wear or are cracked they need to be replaced. Even the smallest hole in a vacuum hose can leak enough air to greatly diminish the suction potential of your unit. Replace your vacuum cleaner parts with OEM parts from the original manufacturer to ensure the tightest fit.
Most vacuum cleaners contain filters. Filters are used as a last line of defense to remove dust and smaller debris particles before the air is recycled back into the environment. If vacuum cleaner filters become dirty or plugged they also can decrease the amount of air traveling through the unit. Some filters can be easily rinsed with water whereas others need to be replaced. It is important to check your owners manual before rinsing a vacuum filter.
The last and probably least common problem for a vacuum cleaner to loose suction is a bad or failing vacuum motor. Over time vacuum motors lose power due to worn carbon brushes or long term damage. A vacuum cleaners worst enemy is moisture. If water or moisture is sucked into the vacuum motor it will greatly diminish the amount of suction the unit has. Replacing a vac motor can be a costly and time consuming ordeal. In some cases, replacing a vacuum motor can outweigh the cost of buying a new vacuum. Vacuum suction is measured in water lift which can easily be measured by using a water lift gauge. If the water lift measured in inches, falls below half the original water lift specifications for the unit, it is time to replace your motor. Most vacuum cleaner repair shops carry this type of equipment and can easily tell you if it is time for a new vac motor.
Jul 25, 2010 | Vacuums
Hello,We have an Hoover Mach 5 Cyclonic vacuum that has no suction. We have cleaned and checked all hoses, belts & filters. Please help us.
With this model, remove the dust tank, and turn it on, check for suction at the lower intake. If you have suction, install the tank and remove hose, and check for suction there. keep following until youn lose it. Then you problem will be between those 2 areas
Mar 27, 2010 | Hoover U5194-900 Mach5 Multi-Chamber...
I don't get much suction from the hose on my DC17 All Floors. I don't see any obtacles in the hose. The suction when upright is fine.
The way your Dyson DC17 is designed, there is a suction divert mechanism that diverts the suction to floor when the vacuum cleaner head is pushed down, and then back to the hose when the vacuum is in the upright position. If you are getting suction from the hose when the vacuum is upright, but no suction after the handle is reclined, this is actually the normal function for the Dyson DC17.
You can check to see if the filter is dirty. The washable filter on your Dyson DC17 is located directly underneath of the dust bin of the vacuum cleaner. After removing the dust bin, lift straight up on the part the bottom of the dust bin rests on. This is where the pre-motor filter is located for the DC17 models. If this filter is not cleaned on a regular basis, then it can start getting clogged, and you'll notice a loss of suction on the vacuum cleaner.
If you have further questions, please visit the link below where you may download the instruction manual. There are some trouble shooting guides at the back of the manual that you may do to try and diagnosis this further.
Dyson DC17 All Floors Instruction Manual:
If this was helpful, please be sure to rate the repair as helpful by clicking on the thumbs up icons on the top of the repair.
Thank you very much,
Chris Jones
Mar 23, 2010 | Vacuums
My vacuum tools have very weak suction.
There is a foam ring filter in the bottom of the canister that collects the dirt. It screws off of the bottom on the canister. Take outside and shake it out. It fixed our suction problem.
Jan 31, 2010 | Bissell 3576 CleanView II Bagless Upright...
No suction for rugs but the hose works fine. Removed the canister and suction is at that point
Remove the base plate and beater bar. Clean the suction cavity behind the beater bar. That's where they almost always plug up.
Aug 19, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
hello tnwalkergal the hose may have a clog inside the hose at the bend you can take the hose loose and run a broomstick or a yardstick thorgh the hose this is how I find the clog
Jan 24, 2009 | Dirt Devil M086700 Vision Bagless Upright...
Hoover U6630-900 WindTunnel Bagless Upright Vacuum Logo
234 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
