Question about Bugaboo Cameleon Jogger
I'm trying to install the wheeled board on the bugaboo. Have followed the instructions - but there seems to be a floor as the wheeled board is too wide for the clips its about 5mm too large. Anyone else had that problem?
  • helenevans Feb 01, 2009
    Hi we have exactly the same problem, our bugaboo board seems too wide for the chameleon chassis.Please help, how do I fix it to the bugaboo?
  • Anonymous Mar 19, 2009
    I can't get my wheel board attached to the Cameleon - does it even fit this model?
We have installed the board and have found that the fitting is quite tight. I have noticed that the clips slide slightly when turning the bugaboo over to fit the board, so you need to keep pushing the clips back into place....hope it helps! As an aside, we have bought the seat attachment (not sold/made by bugaboo) which has been fabulous...it has certainly helped when out with the two children and has been the envy of lots of other little ones!
Posted on Feb 03, 2009
  • Carly Louise
    Carly Louise Oct 08, 2010
    hey weefee..
    do you find that the board falls off?
    Im 99% sure i have the clips attatched properly, but like you said thy slip, and turn around, and if i go over large bumps, the board falls off!!
    Look forward to hearing back from you!
    carly@aanet.com.au
  • Erikaetgisel Sep 04, 2011
    Hi, where did you buy the seat? I am having trouble finding it in the states.
Can't get wheel off bugaboo bee (to replace it)
Screw the inner bolt back in but leave sticking up by a 1/4 inch then use a block of wood and a hammer to tap inner bolt to force the outer bolt out.
Jan 30, 2012 | Bugaboo Bee Stroller
Tip
Why not to buy the Bugaboo wheelie board for your Bugaboo
Because the Mutsy one is better, safer and cheaper. Mutsy make a wheelie board that comes with an rubber adapter for the all the Bugaboo's except the Bee. The Mutsy is made from metal vs Bugaboo's Plastic. The Mutsy has simply finger operated locks to take on and off vs having to virtually turn the Bugaboo upside down to get it off or on. The Mutsy has an adjustable length and a flat deck with no protrusions vs the Bugaboos fixed length and a massive protrusion in the deck. The Mutsy wheel is directly under the child putting less weight on the stroller vs the Bugaboo's wheel being behind the child putting half their weight on the stroller. And the clincher! It's half the price! Go try one out.
on Nov 03, 2010 | Bugaboo Cameleon Jogger
How do you pack a bugaboo travel bag? It does not seem to fit with the wheels on?
You can find detailed instructions on at www.bugaboo.com/userguides but short the answer is yes the back wheels have to come off to fit in the bag. There's a simple wire spring you compress with your fingers where the stub axel fits into the frame.
Apr 05, 2011 | Bugaboo Frog Stroller
Cannot attach wheeled board to Bugaboo Chamelean with Bassinet
In previous posts I've said the Bugaboo gets an A for design, The wheeled board gets a B-. Your problem is you're trying to fit it with all four wheels still on the ground. Put to on it's side and you can the rotate the board further around to fit the clips. Go here to get Bugaboo's instructions For those yet to buy a wheeled board click on my name or picture and click on Tips. There is a better alternative to the Bugaboo board.
Nov 27, 2010 | Bugaboo Cameleon Jogger
How to attach the wheeled board to the bugaboo cameleon
If you visit www.bugaboo.com you will be able to download the user manual in .pdf form.
Hope this helps.
Mar 14, 2010 | Bugaboo Cameleon Jogger
I need instruction for the bugaboo buggyboard
If you visit this link:
http://www.bugaboo.com/uk/en
Choose the 'Service' tab, then opt for the Cameleon (on the right hand side drop down menu) then, below that opt for the Wheeled Board on the drop down menu, you will then be able to view the instruction manual in a .pdf format and also save this to your computer.
I hope this helps.
Oct 17, 2009 | Bugaboo Cameleon Jogger
Spare Parts for Bugaboo Wheeled Board
For Bugaboo spare parts, the best way is to contact Bugaboo direct (www.bugaboo.com) or a local Bugaboo stockist who should be able to order in the spare part for you.
Sep 15, 2009 | Baby Gear
Bugaboo frog and wheeled board not fitting??
Had exactly same experience today. I emailed Bugaboo (via website) and got a reply the same day.
I attached the clips the wrong way round. The picture in the manual is not very clear....The little 'roofs' have to face each other and than you are able to push the clips further over the axle. The slot of the clip fits over where the small wheels comes in on the bar.
Hope this helps.
Jul 26, 2009 | Bugaboo Frog Stroller
Bugaboo toddler board instruction manual
If you visit www.bugaboo.com and click on the 'Service' option, then 'User Guides' then opt for the Cameleon (on the right hand side) then click on the Wheeled Board, you will be able to download the user guide for this. This is in a PDF format.
I hope this helps.
Mar 22, 2009 | Bugaboo Baby Gear
Bugaboo Cameleon Jogger Logo
420 people viewed this question
Top Bugaboo Baby Gear Experts
Jennifer Rock
Jennifer Rock
J.D. Browning
J.D. Browning
Jerry Greenberg
Jerry Greenberg
Are you a Bugaboo Baby Gear Expert? Answer questions, earn points and help others
