Question about Logitech Cordless Desktop MX3200 Laser Keyboard Mouse
Same problem you had with keyboard
I am having the same exact problem that you posted about in january - i tried to reconnect my keyboard with the receiver and the only button that seems to work is the sleep button.... did you fix your issue? if so, how???
  • yatsy Aug 30, 2008
    wireless keyboard and mouse not working tried to set it up again , wizard took me to step one, crtl./alt./F12 it then went to step 2. press connect and it went back to step one. put in new batterie, it is only 7 months old
Ctrl + alt +f12 did the trick!!
Posted on Oct 21, 2008
Few keys of mah laptop....vaio e series aint wrkin properly.... strugglin wid on-screen keyboard
Hi swabags_2299, these instructions will help you, first, click on the "Start" button", paul7of9_66.jpg in the "Start Search Window, Type: keyboard; the "Keyboard Properties" paul7of9_67.jpg window will open. You can (Test) to see exactly how your keyboard is responding. If you are still having the same problem, (Check the Keyboard Status), try "Updating the Drivers," by clicking on the "Properties" button. paul7of9_68.jpg Now in the event that neither of these solution solve the problem, which I hope you shouldn't have to do anymore; try "Uninstalling the Keyboard. To "Uninstall the "keyboard," do the following. Shut-down (turn- off completely), disconnect all the Keyboard Devices that are attached to the Computer. Next, turn-on the computer, and go back to the "Keyboard Properties," this time click on the "Change Settings" button, paul7of9_69.jpg next click on the "Driver" button, and select the "Uninstall" button. paul7of9_70.jpg Once that is finished, shut-down the computer again. Now you want to "Reconnect" all the devices that were connected before, and "Turn-on" the computer. You will repeat exactly what you did from the start, this will "Reinstall the Keyboard. Restart the computer again after all changes have been made; this will ensure the changes take place properly. "I hope this information is helpful, thanks for using FixYa, paul7of9"
Jan 28, 2011 | Sony VAIO VGP-WKB1 Keyboard
Error 301 on IBM 600x
HelloThe IBM error 301 POST code means the keyboard is not responding correctly. Folowing may be the reasons:-
  • You could have a stuck key, or the keyboard cable is faulty and not making proper electrical contact.
  • You could have a faulty keyboard controller.
  • You may have a faulty keyboard which may had some fluid spilt on the keys.
  • Try clean and reconnect the keyboard cable.
If this doesn't work try connecting an USB keyboard and see if this keyboard functions correctly.
If none of these work you have a motherboard problem.
Good luck, and do rate the solution if got help
Dec 08, 2010 | IBM ThinkPad 600X Notebook
My dell dimension xps 400 does not detect mouseand keyboard
Hi, these instructions will help you, and "everything that you do for the Keyboard; apply the same instruction to the Mouse." First, click on the "Start" button, in the ["Start Search Window], Type: keyboard; the "Keyboard" Properties window will open. You can (Test) to see exactly how your keyboard is responding. If you are still having the same problem, (check, the Keyboard Status). "Update the Drivers," by clicking on the "Properties" button. Now in the event that neither of these solutions solve the problem, which I hope you shouldn't have to do anymore; "Uninstall the Keyboard. To "Uninstall the "Keyboard," do the following: Shut-down (turn- off completely); disconnect all the Keyboard Devices that are connected to the Computer. Next, turn-on the Computer, and go back to the "Keyboard Properties," next, click on the "Change Settings" button, next click on the "Driver" button, and select the "Uninstall" button. Once that is finished, shut-down the Computer again. Now you want to "Reconnect" all the devices that were connected before, and "Turn-on" the Computer. "You will repeat exactly what you did from the start, this will "Re-install the Keyboard. "Restart the Computer again after all changes have been made; this will ensure the changes take effect properly. "Rating the solution will let me know if it worked; or you may need further assistance, thanks."
Jun 20, 2010 | Dell Dimension XPS 400 PC Desktop
Keyboard is not working
  • Hi, these instructions will help you, first, click on the "Start" button, in the "Start Search Window, Type: keyboard; the "Keyboard's" Properties window will open. You can (Test) to see exactly how your keyboard is responding. if you are still having the same problem, (check the Keyboard Status), try "Updating the Drivers," by clicking on the "Properties" button. Now in the event that neither of these solutions solve the problem, which I hope you shouldn't have to do anymore; try "Uninstalling the Keyboard. To "Uninstall the "keyboard," do the following. Shut-down (turn- off completely), disconnect all the Keyboard Devices that are attached to the Computer. Next, turn-on the computer, and go back to the "Keyboard Properties," this time click on the "Change Settings" button, next click on the "Driver" button, and select the "Uninstall" button. Once that is finished, shut-down the computer again. Now you want to "Reconnect" all the devices that were connected before, and "Turn-on" the computer. You will repeat exactly what you did from the start, this will "Reinstall the Keyboard. Restart the computer again after all changes have been made; this will ensure the changes take place properly. "Rating the solution will let me know if it worked, or you may need further assistance, thanks."
May 31, 2010 | HP Pavilion dv2000 Keyboard
How to reconnect my dell wireless keyboard
Hi, these instructions will help you, first, click on the "Start" button, in the "Start Search Window, Type: keyboard; the "Keyboard's" Properties window will open. You can (Test) to see exactly how your keyboard is responding. if you are still having the same problem, (check the Keyboard Status), try "Updating the Drivers," by clicking on the "Properties" button. Now in the event that neither of these solution solve the problem, which I hope you shouldn't have to do anymore; try "Uninstalling the Keyboard. To "Uninstall the "keyboard," do the following. Shut-down (turn- off completely), disconnect all the Keyboard Devices that are attached to the Computer. Next, turn-on the computer, and go back to the "Keyboard Properties," this time click on the "Change Settings" button, next click on the "Driver" button, and select the "Uninstall" button. Once that is finished, shut-down the computer again. Now you want to "Reconnect" all the devices that were connected before, and "Turn-on" the computer. You will repeat exactly what you did from the start, this will "Reinstall the Keyboard. Restart the computer again after all changes have been made; this will ensure the changes take place properly. "Rating the solution will let me know if it worked, or you may need further assistance, thanks."
May 18, 2010 | Dell Wireless Keyboard Optical Mouse w0147
Wireless desktop 6000 keyboard problem
Check the inside of the battery chamber to see if there is corosion on the spring or front pip for the + ve.Batteries leak ands should be chaged every 6 months regardless
Jul 27, 2009 | Microsoft Wireless Laser Desktop 6000 V2...
I have a Dell Dimension 3000 desktop computer. I
more info would be beneficial in diagnosing exactly whats wrong.. but try to rule out a few obvious things first. try disconnecting and reconnecting the keyboard and make sure it is properly seated in the usb/ps2 port. download spybot S&D and scan your computer to remove any keyloggers/trojans/malware that may be hogging your cpu and thus bogging down the Input from your keyboard.
Jul 17, 2009 | Samsung Pleomax PKB-7000X
Error code 301
If none of these work you have a motherboard problem. The Thinkpad 600 is a very old laptop and it would not be worth fixing. I suggest putting your money towards a new laptop.
Jul 12, 2009 | IBM ThinkPad 600X Notebook
Did you figure out your KVM?
if you tried to connect your mouse to the keyboard port and still it doesn't work. Power cycle meaning unplug the KVM from the CPU, monitor, keyboard and mouse. Then wait for about 30seconds before reconnecting again. If you still encounter the same problem that the keyboard port won't work then it means that keyboard port is defective. Replace it.
Jul 27, 2008 | IOGear GCS632U 2-port KVM Switch
Keyboard button not working properly
and how did you were able to post this problem??
Just joking:
Try the following:
-Desconect the keyboard then try to reconnect it again.
-Try pressing the Caps Lock / Num Lock Keys: does the led turns on?
-If the keyboard is USB/ try a differnet port
Jun 28, 2008 | Computers & Internet
Logitech Cordless Desktop MX3200 Laser Keyboard Mouse Logo
81 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
