Question about Samsung LE32R74BDX 32 in. HD-Ready LCD Television
Same problem: LA40R71B
We have the same problem with our 14 month old 42" Samsung LCD.
Problem is that TV switched off by itself, then red standby light flashes and tv makes clicking noise. Unplugging / replugging after an our makes no difference.
Dissapointed!
  • 41 Answers
Does it make the the samsung jingle when it trys to turn on? if it does you need a power supply if not then most likely it is the main board. I would contact you r local service center for help and if the standby lights in the front blink in a certain pattern write that down it is a error code that the technicain can use to solve the problem.
Posted on Oct 07, 2008
My TV randomly switches itself off and the red light flashes continously and i have to pull out the plug. its getting more frequent
Samsung TV Keeps Shutting Down - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - When I turn the TV on for the first time each day it shuts itself off within 30 seconds. ... green light flashing red light is [standby term] green light is [lamp]flashing. samsung plasma 850 picks up other remote signals?
Jun 12, 2015
Samsung LED UN55B7100 turns off on its own.
Jun 11, 2015
Volume goes automatically to 0 on my Samsung LCD TV
Jun 10, 2015
Why TV turns off by itself?
Jul 12, 2012
More results from www.cnet.com
Easy fix for new Samsung TV switching on and off power ...
? 4:41
https://www.youtube.com/watch?v=H0cG3lzjuw8
Sep 15, 2012 - Uploaded by alwaysafix
My tv turns on and off by itself the minute I plug in the cable. .... Samsung E6030 led tv hv blinkin red light ...
Dec 25, 2015 | Televison & Video
When you switch on the tv it goes to standby mode, and when you press standby it turns on to a orange light then goes back to a red light, any idea whay this is happening ....
My Westinghouse LCD tv has the same lights on it It goes orange or red when there is no signal from that source... or while it is calibrating itself to the new frequency etc.
Oct 19, 2013 | LG 42PM3MV 42 in. PLASMA TV
I have a Sharp LC-32D44E LCD TV. Purchased Oct 08. In July 09 when switched on, the power light showed green for about 20 seconds and then went into standby mode. Fault fixed by Sharp, and engineer stated...
The problem may be in any three things.No 1: Internal power supply.No 2: The video section.No 3: IFT (Intermediate Frequency Transformer).
Solve:Check all the section one by one and find out where the fault lies.Then repaier the faulty components.
Dec 30, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
I have a 46 lcd samsung tv that has no power we changed the capatiors still no power any ideas 14 month old.
You need to check for standby 5vdc, it should be there the minute you plug the TV into the outlet. This a must have voltage. Replacement power supply is only $53 here: http://www.shopjimmy.com/catalogsearch/result/?q=Samsung+LN32A330+
Please post back what kind of voltage reading you are getting at the DC output connectors.
Dec 24, 2009 | Samsung LN32A330 32 in. LCD TV
Vertical line on LCD TV Panel
Had this same issue on right side of 52" about 1 inch from side but had 3 vertical lines that disappeared after 40 minutes. Have Samsung LNT5265FX/XXA and about 16 months old. LCD Panel itself had to be replaced to fix it, fortunately had extended service plan
Oct 17, 2008 | LG 42LC2D 42 in. LCD HDTV
Sony bravia
what model of Sony is it? On many of the Sony projectors, a 3 flash error code indicates the lamp is not properly seated/installed or the lamp door is not closed properly
May 15, 2008 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Samsung HPS 5073
Unplug TV, take off the back. One each board there will be capacitors. the tops are flat unless one has blown then it is bubbled up. If you find one that is bad, copy the number and search the internet for a replacement. Unsolder and remove the old one ( there is a line drawn on the negative leg, mark the neg side on the motherboard so you can replace the new one the same way). Now solder the new one back onto the board. This worked for my TV, hope it helps
Jun 01, 2017 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
LCD TV SCREEN PROBLEM RED HORIZONTAL LINES OF DOTS ALL OVER SCREEN PLEASE HELP
This should be repairable. It may be the LVDS Cable or the Main board problem. The only other problem is the T-Con Board.
Dec 13, 2007 | Samsung LN-S4051D 40 in. LCD Television
Sony blinking standby light
This is Sony's way of telling you that there is a short in you set.Probably the horizontal deflection circuit.(Horizontal output transistor shorted??). Also any other short. You need to take it to a techincian and have it checked out. It would be wise to get an estimate! Stargazer
Feb 05, 2007 | Sony KV-32CS70 32" TV
Samsung LE32R74BDX 32 in. HD-Ready LCD Television Logo
414 people viewed this question
Jerry Greenberg
Jerry Greenberg
