Question about Dishwashers
Hello. our dishwasher is leaving the dishes dirty. as far as i am aware, its going through its sequences and processes properly
    President:
  • 1,462 Answers
Open door when in cycle and check spray arms are rotating. these only rotate with water coming out of angled jets at end of arm. if there is a blockage in the jets then no rotation and poor wash. take them out and clean
Posted on Aug 09, 2008
Westinghouse dish washer brand new leaves dishes wet why
Hello Larry Franke,
Over the last 12 yeas (I've noticed)...
Dryer elements have been becoming pass?...
in the name of economy...
Just like those piddle stream shower heads...
Takes twice the water and 4 times as long if you
are actually dirty when you shower... (real SMART).
I became vaguely aware when our (very) old washer
finally rusted completely through...
and had to do SOME SERIOUS HUNTING to find a DRIER EQUIPPED with a drier.
Check with your RETAILER... They are FULLY AWARE
of the VERY COMMON disappointment/surprise suffered
by BUYERS of these NEW & IMPROVED versions.
They might even be reputable enough to offer
an UPGRADE ...
EXTRA CHARGES... will no doubt apply.
Sorry... (just another gotcha!)
Carnac the Magnificent
Jan 22, 2017 | Westinghouse Dishwashers
It' no longer cleaning my dishes
hello,
If your dishes are coming out of the dishwasher covered by a removable dirty film, your water may not be hot enough, or you could be using an inferior brand of automatic dishwashing detergent. If you have tested your hot water and find it is between 140 degrees and 160 degrees Fahrenheit, consider how long it takes for the hot water to reach the dirty dishes in the dishwasher. If the hot water has to travel a long distance to reach the dishwasher, chances are the water filling the dishwasher starts out cold. To alleviate this problem, run the hot water nearest to your dishwasher until the water coming out is hot. This will guarantee the water filling the dishwasher is as hot as it should be to properly clean dirty dishes.
To remove this type of film from dirty dishes, after running the dishes through a basic rinse cycle, set a bowl filled with a cup or two of white vinegar on the lowest rack of the dishwasher. Remove any metal pans or utensils, and with the vinegar on the bottom rack, wash the dishes as usual. Dirty dishes that were once covered in film should come out squeaky clean
thanks.
Oct 23, 2010 | Dishwashers
Dishes are still dirty at the end of the cycle
hello,
hope this help?
thanks.
Oct 23, 2010 | Kenmore Dishwashers
Filters clean, arms unblocked, salt and rinse-aid ...
Yes! you are already having the answer. check your water inlet flow. Clean the strainer at the machine water hose connecting end.
Check the drain filter also. Refer user guide for instructions on cleaning.
May 19, 2010 | Dishwashers
Dishwasher cycle runs: tablet is not dissovlved, dishes dirty
If the dry cycle has a problem, check these:
Heating element
Drying fan
Thermostat
Heating element Your dishwasher has an electrical heating element that helps to dry the dishes. If the element is burned out, the dishes won't dry properly, and you need to replace the element.
Drying fan Many high-priced dishwashers have a small fan that blows air or heated air into the dishwasher to speed up the drying process. If the fan is defective, you need to replace it.
Thermostat Some dishwashers have a thermostat that monitors the drying temperature. If the thermostat is defective, the heating element may not cycle on or off properly. If that's the problem, you need to replace the thermostat.
Aug 29, 2009 | Frigidaire Dishwashers
I have a whirlpool quiet partner dishwasher that is not getting even light food residue off the dishes. Cycles seem to be running and progressing normally, tho I do not think the water is spraying from the...
Welcome to fixya,
You said, you have a whirlpool quiet partner dishwasher that is not getting even light food residue off the dishes. Cycles seem to be running and progressing normally, tho you do not think the water is spraying from the arms with adequate force.
I have the same machine.
And I notice if I leave the dishes in the sink rather than rinsing them off and putting them directly into the dishwasher, (Like My Wife says to do). That sometimes I have the same problem.
So I bought Jet Dry, and filled the holder. It's a small sometimes clear plastic knob that unscrews out above the soap dish.Fill it once a month!
Do you put the detergent in both cups or only the closed one?
1. If the load is not real dirty you should only have to fill the one with the door that closes.
If it is real dirty then both. To always use both is a waste of money!
2. If your hot water heater is far from your dishwasher, let the hot water tap run a minute till it comes out hot, before starting the dishwasher.
3.If the dishes or pans are very dirty and or baked on use hi temp scower and heavy or potscruber for those loads.
I use heavy wash and hot temp scower if the stuff is relly messy or dryed on.
And for baked on HI- temp scower and pot scruber which sprays harder.
You will have to experiment a little to see what works for you.
You will find it washeing good after you find what works for your families dish habits!
If you have any more questions let me know!!!
Please remember to leave me a solved before you leave the site.
Thank You for using us!
Huuum
Oct 02, 2008 | Dishwashers
Indesit D63 dishwasher dishes not getting clean
Dishwasher seems to cycle through but dishes are still dirty, like there is no water being sprayed?
Jan 23, 2008 | Dishwashers
Poor/Uneven Wash Quality
there is a new product out that filters the water going into your dishwasher. it works great and my dishes look fantastic. they use to look dirty with a white film on them. after the first load when i hooked up the dishwasher filter my dishes looked brand new. it is affordable and works everytime. you can get it at www.dishwasherfilter.com.
Oct 11, 2007 | Kenmore 15529 Built-in Dishwasher
Dishwashers Logo
106 people viewed this question
Top Dishwashers Experts
