Question about Acer Aspire 5100 Notebook
Upgrading my laptop's processor
Sir as you told i visited the site youtube and a saw a user having the same laptop as mine an Acer Aspire 4315 and he just upgreaded his celeron processor to an ohter high powered processor and he recommened to the viewer to change thier processor to an Intel Core 2 Duo T5550 socket P Sir if this can be done to my laptop is it ever possible to do this things and if i can do so then will my motherboard be harmed or any other part.will my system work perfectly and faster and if so then is there any ohter Intel processor which is more faster and is compitable with my laptop ACER ASPIRE 4315 and as you said my system say that it only supports 2 gb maxium ram is there anyhing that i can upgraded it to 4 gb or more THANK YOU VERY MUCH FOR YOUR HELP BEFORE
  • Acer Master
  • 19,396 Answers
Possible it is possible, but if I was in your shoes I wouldnt do this to my laptop. First is not worth, a Intel Core 2 Duo T5500 alone costs about £.100, the CPU replacement is not a simple operation and should be performed by an expert repairman, this will cost you about £ 80 plus VAT labour, replacing cooling system with a better one would also be good.
Then after you replace it you risk to overheat your new CPU and blow it, this is one of the reasons why Acer tells customers not to upgrade to core 2 duo. Additionally, if you want to DIY you risk to damage your laptop on a complex cpu replacement operation.
The guy on you tube wanted to show his skills, but I am sure any genuine computer repair engineer will suggest you not to proceed with this kind of operation.
With all money required, labor, and risk involved in operation you will better buy a new laptop, if you really need a powerful laptop buy Alienware, uk custom made supercomputers.
Regarding the memory I know that some customers successfully mounted 4 Gbs on 4315, while I also read on the Internet other 4315 did not support 4 Gb. I assume it depends on Bios version. I suggest to contact the memory seller posted in previous message and ask if 4Gb are supported, giving them exact model number from your laptop service tag, and also ask if you can eventually get refund if this does not work.
Cheers
Posted on Aug 09, 2008
I would like to upgrade my Acer Aspire 4315 PC Notebook it has celeron processor 1.73ghz 533mhz fsb 2.53gb ram running on win xp pro what dual core processor can this laptop take?
Well most modern laptops cannot not be upgraded in this manner because the processors are hard soldered on the motherboards. Even if you have a removable type processor the newer dual cores will not be compatible with your type of motherboard.
May 29, 2010 | Acer Aspire 4315 Notebook
I don't think my aspire 4315 acer laptop meets the sims 3 requirements my processor is only 1.73ghz and the sims 3 requirement is 2.40ghz can I upgrade my processor???
more than likely you can, but is it worth it to upgrade the cpu. alot of times the board wont take up to a certain cpu and cost and if you change a cpu, you may have to change memory and more than likely video. might be better off selling the one you have and using that money and the money you were gonna use to upgrade and buy a new computer
Apr 30, 2010 | Acer Aspire 4315 Notebook
Celeron 540 upgrade
Aspire 4315 Specifications Specifications
Part Number
Varies by specifications
Processor / Speed
Intel Celeron mobile processor 530/540/550 (1 MB L2 cache, 1.73/1.86/2 GHz, 533 MHz FSB), supporting Intel 64 architecture
if you have a 2 Ghz processor installed, you will have to replace the motherboard to go with a faster CPU.. which will be spendy..
Hope this helps
May 06, 2009 | Acer Aspire 4315 Notebook
Upgrading my laptop's processor from celeron 540 to 560
there is no way you can upgrade the VGA on a laptop. You can upgrade everything else. But tis always better and cheaper to get a new one.
check with the cost of the celeron 560 and the 4gb + the 250 gb together.
but how much a new computer cost? so its your choice...
Aug 11, 2008 | Acer Aspire 5100 Notebook
Processor
I told you my opinion, If I was in your shoes I won't upgrade the CPU.Professionals do not do works against Factory specifications, and I fixcomputers for living.
Acer says Pentium dual is not supported on Acer 4315, I can only tell you not to do such an upgrade.
Itwould be the same as if you ask me if you can mount a Jaguar engine ona Mini, yes, for sure there is the way to mount it, but the car won'twork as it is supposed to, and risk to blow at first corner.
If you really want to replace your CPU consider the following.
Acersays pentium 2 dual core is not supported on 4315, if you do ityourself you risk to damage the computer. Do not do the CPU upgrade ifthis is your only laptop, or if you care of this laptop, chance ofdamaging laptop are high. This kind of upgrades are done more as anexperiment.
I know Core 2 Duo T5300 1.73 Ghz had been installedsuccessfully on Aspire 4315, Acer says not to install any core duo, Iknow for sure Pentium duo T5200 1.6 Ghz works on Aspire 4315 with noneed for replacing cooling system.
Both chipset are difficult to find, best place to find them is Ebay.
Check this link for an extensive report on this matter:
check also: Is it worth upgrading the CPU on Acer Laptops?
Aug 10, 2008 | Acer Aspire 5100 Notebook
Upgrading my laptop's processor to a lower processor
No laptops graphics are integrated into the motherboard and cannot be change with any bit of ease
Graphics card
Unlike desktops, notebook video cards are not usually modular or interchangeable, as the are integrated on mainboard.
On laptops usually you do not have a graphic card that mounts on a slot, like desktops PCI, or AGP video adapter.On your laptop the display adapter chipset is integrated on motherboard, and usually it is not possible or not convenient replacing motherboard to upgrade graphic adapter.
Aug 08, 2008 | Acer Aspire 4315 Notebook
Acer Aspire 5100 Notebook Logo
161 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
