Recovery disc will not respond in my computer
I have a PC Compaq Presario with Winows ME. My computer is working poorly so I wanter to use the recovery disc to reset my computer. The recovery dis will not respond. When I put it in and start or restart the comuper all I get is a black screen and a cursor at the top left corner of the screen forever. I have used this disc before and it work without any trouble. I have tried this proceedure with the internet hooked up and disabled. I have tried this a a restart and I have tried starting the computer with the disc installed. I have also tried all three of the CD drives on the computer. I just want to reset my computer. Can anyone help?
Best regards,
Peter
  • Yurcak Aug 09, 2008
    All CD Drives were connected but I am will unplug tywo of the drives jut to see. I don't think that this is the solution.
    Sergeant:
  • 395 Answers
When you used it before, did you have all three CD drives connected? If not, try unplugging two of them.
Posted on Aug 09, 2008
  • Steve Si
    Steve Si Aug 09, 2008
    If you lock this solution then I cannot help you further...
Where can i receive a compaq recovery disc?
You can burn one in some cases if it hasn't already been done. Usually computers don't come with recovery discs anymore.
Feb 04, 2011 | HP Compaq Presario SR1303WM (PP150AAR) PC...
How to do system recovery on compaq presario 5000 windows me
Starting a Recovery Turn on the computer and immediately begin pressing the F10 key repeatedly until a Recovery Screen appears. You can also start a recovery from recovery discs, or from Windows. For more information refer to Performing a Full System Recovery in Windows XP . Back to topRecovery is taking too long If your computer stops responding after using the recovery program, do the following:
NOTE: If the computer appears to have stopped responding after restarting from a recovery, please wait, it may take several hours or longer to complete the initial Windows XP setup process, especially if a recovery was run from a recovery disc set sent by HP. A Standard recovery may also take longer, depending on how many files are stored in user accounts (like in My Documents ).
  1. Exit the stalled recovery process by pressing the POWER button on the PC until the power turns off, this takes approximately five seconds.
  2. Before recovering, disconnect personal media drives, printers, scanners, cameras, camera-type memory cards, and other devices that did not originally come with the PC.
  3. If you are using recovery discs, be aware of the following items:
    • If you created the recovery discs using Recovery CD Creator, be sure to run the recovery from the same drive that you used to create the discs.
    • Clean the discs with a soft, clean, lint-free cloth wetted with distilled water. Wipe from the center of the disc to the outside edge. You may also use disc cleaning kits or disc restoration kits from your local computer store. These kits produce better results than using cloth and water.
    • You may also use available CD/DVD Drive cleaning kits to clean the laser reading lens of the CD or DVD drive.
  4. Try running a full system recovery again from the hard drive by turning the on the computer and pressing the F10 key until a Recovery Screen appears. This performs the recovery from the hard drive.
  5. If the recovery stops when recovering from the hard drive, use the section Disc errors occur during the recovery process to eliminate errors on the drive. Try recovering again after the disk errors are removed.
Jan 13, 2011 | Compaq Presario 5000 PC Desktop
COMPAQ PRESARIO M2000 RECOVERY DISC WILL NOT LOAD ON NEW HARD DRIVE
The issue here to be quite frank is the hard drive needs the compaq image before the recovery disk can be loaded. This provents people from taking there compaq disk and getting wise and installing it on multiable computers what authors call piracy.
What you need to do is have compaq NOW HP send you out a IMAGE recovery disc usually when a hard drive crashes they send you out the hard drive with the IMAGE.
The other solution is purchasing windows 7 upgrade and going at it from there.
Thanks hope this helps please do not shoot the messenger and leave postive feedback and ratings.
Jun 11, 2010 | Compaq Presario M2000 Notebook
I BOUGHT A COMPAQ SR571UK FROM PC WORLD IT WAS A DISPLAY MODEL IT WAN'T LET ME MAKE RECOVERY DISCS IT SAYS ONLY ONE SET PER COMPUTER PC WORLD SAYS THAT THEY PUT IT BACK TO FACTORY SETTINGS AND WILL HAVE TO...
Hi:
Your only choice to get recovery discs now is to order them thru the HP/compaq website. They are not too expensive, and it is about the only ;thing you can do since someone already used your option on the display computer you bought.
Jan 23, 2010 | Compaq Presario SR5710Y PC Desktop
Sr1603wm recovery problem
used a recover disc that for HP poduct or distop.
Nov 05, 2009 | HP Compaq Presario SR1603WM (ED861AA) PC...
Compaq Presario CQ60 recovery disc how to use
insert the disc into the drive, restart the computer.If it doesn't boot from disc, restart again.
As it restarts, press and hold F8(may be F2 or F12 depending on the settings)until the boot options screen appears. Using the arrow up/down keys select drive "d" or what ever drive letter represents the drive you put the disc into.
It will now(or should) continue to boot from the disc, follow the onscreen instructions to restore.
Aug 27, 2009 | HP Compaq Presario CQ60-249US Notebook
Computer hangs during pc recovery process
you may need to swap the disc from one cd-rom to another.
Mar 10, 2009 | HP Compaq Presario SR2011WM PC Desktop
Can't extract files on System Recovery Disc 4 for Compaq Presario model 6350US
At this point, you can try to clean your disk # 4 and see what happen,
or try to make a copy of disk # 4 (if you can copy the disk) and try again.
or
1) Contact your customer support and ask for a new set of disks.(or only # 4)
or
2) Boot your computer with another OS disk (win XP)
or
3) Boot your computer with some utility disk
Oct 19, 2008 | Gateway MX6421 Notebook
RECOVERY DISC ALONG WITH UP GRADE IF POSSIBLE
if you dont have the recovery disc for your computer, you will need to purchase a new windows installer, ones it is installed just download the drivers from the manufacturer website.
Feb 21, 2008 | Compaq Presario 5000 PC Desktop
Computers & Internet Logo
60 people viewed this question
David Payne
David Payne
