Question about Nikon D40 Digital Camera with G-II 18-55mm Lens
CAMERA WON'T TURN ON; BLINKING RED LIGHT
After the card was full the camera shut off and would not work and blinking red light appears on the base of the camera.
Bought a new battery but that didn't work. Help and thanx!
  • cameracust Aug 11, 2008
    Found the camera manual and read that the blinking green light (not red-- sorry) indicates that the card is full. True, but the camera will not function.
    Any ideas?
    thanx again
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 100 Answers
Is there an error message?
Posted on Aug 10, 2008
I bought a power adapter for the camera, but it doesn't seem to work without batteries in the unit. If I use the batteries alone, I will eventually get a red blinking light at the back of the camera,...
Because the camera is what is technically known as 'Portable'and is designed to work purely from the internal battery. the Power Adapter merely charges the internal battery
May 08, 2017 | Kodak EasyShare C330 Digital Camera
I mistakely deleted pictures from my camera (Kodax Esay Share M340) Move picture to internal memory.How can i get the pictures back
If Try one or more of the following
Ready light does not turn on and the camera does not work.
Ready light blinks green.
  • Camera is operating normally.
Ready light blinks amber.
  • Wait. Resume picture taking when the light stops blinking and turns green.
Ready light blinks red and camera turns off.
Ready light glows steady red.
Ready light is off or glows steady green.
Mar 10, 2011 | Kodak Cameras
When i turn on my camera the red light won't stop blinking
change or charge your battery. The red light will blink to indicate the flash circuitry is charging.
Jan 08, 2010 | Bushnell Trail Sentry 11-9200 Digital...
When charging battery green light flashes then red 3 times
KODAK Easyhare digital camera light status
1. Blinking green light(or blinking blue or white light in some models) - Means camera is performing a power up procedure. Note: Wait a few moments to see if the camera displays a solid green (or blue or white) light or a blinking red light.
2. Solid green light(or blinking blue or white light in some models) - Means Camera has sufficient power
3. Blinking red light - Means camera batteries are weak or need replacement; If battery are new and still red light camera needed to be repaired
For futher assistance contact Kodak support line 1 800 235 6325 (23KODAK)
Nov 21, 2009 | Kodak EasyShare M863 Digital Camera
Should the power light be green or red, when I turn camera on it shows a green light then turns red
Red light indicates that the camera is out of charged., Try to charged your battery for 3-4 hrs if you encounter flashing red on a fully charged battery you need to call kodak 1 800 235 6325 ext 12
You can charged you camera using 5V AC Adaptor or a USB cable taht attached into the computer
Nov 16, 2009 | Kodak EASYSHARE M1063 Digital Camera
Reads card error and red light keeps blinking
Try cleaning the contacts on the memory card with a pencil eraser.
May 28, 2009 | Vivitar ViviCam 8400 Digital Camera
Blinking red indicator light
Hey pollyannac,
The red blinking light probably means either the flash is recharging, or the camera buffer is full and it is writing files to your memory card which the lcd monitor should read Busy while the camera is writing the files. If it is the flash recharging then you could try using more powerful batteries such as the Canon NiMH AA batteries. If the problem ends up being the camera is writing images to the memory card you could try getting a memory card that has a high write speed. These memory card are usually more expensive, but in my opinion well worth it. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Jun 04, 2008 | Canon PowerShot A720 IS Digital Camera
WON"T WORK
sounds like a dead battery. Plug the origional charger into it and the front led (below the flash) should flash red. If the red led in the back of the camera flashes or stays lit, then you have the wrong charger plugged in. (the camera won't power up if the back red/green led is on when plugged in)
May 08, 2008 | Jazz DV-179 Digital Camera
Polycom ViewStation H.323 Red Blinking Light
Are you able to move the camera using the remote?
If not, then you may have a hardware issue.
If yes, then try to connect to the Viewstation (web interface) using its IP from a Computer.
Let me know what happens
Jan 18, 2008 | Polycom ViewStation ISDN (pcy220011323001)...
Blinking Red Light
just push the button one or two more times at will take a picture while the light is blinking red.
Dec 05, 2007 | Vivitar ViviCam 3705 Digital Camera
Nikon D40 Digital Camera with G-II 18-55mm Lens Logo
102 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
