Question about Refrigerators
Defrost problem... I would like to know... My freezer is totally frozen behind the back panel, AND all the evap coils are covered in ice. I've been defrosting it with a hair dryer for the last 2 weeks...ugh Is there a method to manually engage defrost cycle, check if defrost heater is bad, or test the thermostat? The thermostat is CHEAP, and I'm considering replacing it just to see if this fixes it. Any and ALL advice welcomed...except advice to replace board, please? :-) At this point (before any real diagnosis is complete), spending $300 on a new board seems premature. THANKS!
  • 29 Answers
Check at front of fridge on bottom behind kick panel or at rear of fridge near compressor on some models you can manually engage defrost cycle,it looks like a small sometimes metal box with wires out of it,it will have either a protruding knob which is turned or a depression in which a screwdriver can be placed to rotate it.if it goes onto defrost and works o.k. this timer will need replacing
Posted on Aug 13, 2008
I have an old kenmore fridge maybe a 90's model it's an off white color probably from age and alittle rusty, it's a top freeze and the freezer works great but the fridge section can barely keep...
all the fridge does is the freezer gets cold and the evap fan blows cold air from the freezer down into the fridge section,so open the freezer door,if you don't hear the fan blowing you have a bad evap fan motor,also the drain can be blocked and it freezes up the air ducts so the air can't circulate down into the fridge,is there water under the bottom crisper draws?if so the drain in the freezer is blocked,you have to take everything out of the freezer,remove the back wall,melt out all the ice and clean out the drain under the evap coil.i use a steemer to clean out the drain,if you don't have a steemer you have to melt out the ice in the drain with the hair dryer,then get like a turkey baster or anything that can blow down into the hole,pour hot water into the drain,if it drains out then you're done,if it doesn't keep hitting it,another thing is touch the inside back wall of the freezer,if there's like frost or like snow covering the back in side freezer wall you have a defrost problem,bad defrost thermostat,heater or timer,the last thing is the door was left open,you can tell this by looking at the food packages and the ceiling and walls,if you see frozen water droplets on your food packages or on the shelf or walls the door was left open and the air ducts are frozen,you have to melt the ice out of the air ducts.so open the freezer door,listen for the fan,no fan could have a bad fan motor,look for ice on back inside freezer wall or frozen water droplets,the door was left open or you have a defrost problem. also when was the last time you vacuumed out the coil unless it's on the back wall,if the coil is behind the bottom kickplate vac it out that will make a big difference.you can get back to me and let me know what you find or melt it out with a hair dryer like i said.good luck and let me know what you find.one more thing,if your ice cream is not staying hard just soft you could have a leak in the sealed system,but if i were you i wouldn't put any money into that machine,if you change it out you'll save money on your electric bill and usually once something on those old dogs starts to go wrong it's not long before it totally dies
Sep 22, 2011 | Kenmore Refrigerators
Inside bottom of freezer every few days theres about a 1/8 of an inch of ice. Can you help me. I have cleaned out the freezer several times but cannot find the origin of the water. Thank you
The water is from the defrost cycle thawing the evaporator coil.
The defrost drain line in the freezer is frozen over with ice and the defrost water is not draining.
Turn off the power and remove the rear freezer panel and the freezer bottom panel.
Use a hair dryer to defrost the ice at the drain hole in the center of the drain trough underneath the coil in the back of the freezer.
This will take some time to do because the process will be slow.
Jul 31, 2011 | GE GTS12BBPR Top Freezer Refrigerator
Maytag fridge has not been staying as cold as should. In last day freezer is starting to leak water and food not staying frozen. Have turned up controls to coldest.
I would guess that the evap. coil in the freezer section is ice up, could be a bad defrost timer or just a heavy accumalation of ice, turn it off and let it thaw, or locate the defrost timer and advance it to a defrost, the timer is usally in front just behind the bottom vent cover.
Jun 26, 2011 | Refrigerators
I have Whirlpool refrigerator without ice maker, It leaks water down inside of the crisper drawers . What can be wrong with it
The most common problem is the defrost drain hole is plugged or frozen over.And the defrosted water from the evap coil is leaking in the fridge compartment,You may have to remove the back panel in the freezer compartment and defrost the evap coil and drain area.
Jan 07, 2011 | Whirlpool 21.0 cu. ft. Top Freezer...
Freezer does not defrost, ice piles up, using hair dryer to defrost. Refrig. 5 yrs. old. Thanks, Laura
unplug and unload the freezer section. a panel in the back of the freezer should come out. behind it is the evaperator coil. if it covered with ice, thaw it out with a hair dryer. check the fan near the evap. coil to see if it turns freely. after drying out compartment, plug back in and see if fan works. if all looks fine, look for a florescent looking light bulb in the compartment.have it checked and replace if needed
Jan 02, 2011 | Kenmore Refrigerators
The freezer fills with water and overflows about once a week.The food is partially frozen and the ice is clear and wet. The fridge is cold and no problems but the freezer doesn't fully freeze and water...
your evaporator coil in the rear area behind the freezer back panel is frozen over with ice and the coil can no longer deliver cold air due to ice blocking the air flow from the evaporator fan,remove this rear panel,defrost it with a hair dryer,check the defrost heating coil for continuity,they go bad regularly,if not the heater coil under the evaporator coil,it may be the defrost timer in the refrigerator section of the unit that powers the defrost coil that needs replacement
Jul 25, 2010 | GE 22.3 Cu. Ft. Bottom-Mount Refrigerator...
The top half of the upright freezer is totally thawed but the bottom is frozen. I need the whole thing to freeze.....
Check for ice on back wall if iced up check defrost heater and defrost timer also check and besure evaperator fan is working check wireharness on heater, timer, and evap. fan motor.Sounds like you have a defrost prob. Turn off for 24hrs to melt ice turn unit back on if it works for a few days then ices back up you have a defrost prob.
May 16, 2010 | Freezers
Freezer works fine but fridge has lost its temperature.
The fridge gets its cold air from the freezer through a vent between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
Jul 02, 2009 | Refrigerators
Freezer is frosted in back Refrigerator is warm
The problem is the defrost system located behind the freezer back panel.
The defrost system (AKA evap. system) is composed by an heating coil, a fan , and a defrost thermostat, and its function is avoiding ice formation on coil.
When defrost system is defective the fridge wont cool down properly
In your fridge , either evaporator fan, thermostat or heating element is faulty, and the ice on coils is preventing the appliance from cooling down properly.
Mar 29, 2009 | Hotpoint HSS25GFP Side by Side...
Ice formation
sounds like a drain clog in the freezer compartment above. remove the freezer rear panel and totally defrost the evaporator area, directly under the evap you see( under all taht ice) a small drain hole that has become frozen over, try defrosting with either a hair dryer( not a heat gun too much heat youl melt everything) or by pouring hot water donw the drain until you get a free flow of water down the tube. after its clear reassemble and you should be fine
Jan 04, 2009 | Refrigerators
Refrigerators Logo
115 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
