Question about Microwave Ovens
How to replace light bulb under the hood for JVM1430BD002?
  • Microwave Ovens Master
  • 9,098 Answers
The first step is to unplug the oven before changing bulbs.
I have a diagram at my site which helps you find & replace many GE cooktop and cavity light bulbs. It's at
If it's an over the range type, remove the vent grille across the top and see if bulbs can be accessed there. There may be a panel on the bottom covering the light(s), instead.
If there's no obvious removable cover over the bulb (and the owner's manual doesn't address it) some disassembly may be required.
If not, chances are you'll have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
If you don't have your instructions, you can download them here.
Once it's out of the wall, the outer cover (wrapper) will need to be removed, just as you'll need to do on a counter top model.
The screws you need to remove should be pretty obvious, and a special driver (such as a T20H Torx type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
Posted on Aug 12, 2008
Light bulb above stove under microwave hood
According to the GE manual it is a 120 v 20 watt halogen bulb, the GE product number is WB36X10213. That is the cooktop light/nightlight that would be on the stove hood. HTH!
Sep 25, 2012 | GE Profile Spacemaker 1.8 Cu. Ft....
Sounds like a power source issue from under the hood.
Unplug or turn off all power and take a closer look in there,. alternatively - this may sound crazy, but are you certain both bulbs are working by testing in another fixture??
Jan 05, 2011 | Sharp R-1480 Microwave Oven
The range-top light blew and now replacement bulbs
My Whirlpool/Roper microwave/hood combo has the same problem. I replaced the bulb twice, checked the bulb and it works, but not in the microwave. I wrote to Whirlpool asking about the problem. Haven't heard from them yet.
Apr 02, 2010 | Whirlpool MH1150XMQ Microwave Oven
The hood light blew and I replaced it. It worked
The cause could be anything from defective bulbs(least likely, to a bad bulb socket or vibration during operation. A voltage measurment at the bulb will tell you if it is getting too much.
Dec 24, 2009 | Microwave Ovens
Model is GE JVM1430BD002. Microwave works but range fan and lights do not. Unit "popped" when fan was turned on one time and hasn't worked since. Is there a fuse or breaker for the range hood functions?
Yes - there is an internal "special" in-line fuse. Most likely it is the fan that has caused it. Clean the fan with switch-cleaner spray and make sure it is smooth running. Replace special fuse with identical version.
Check lights before operation.
Replace all covers before test.
Oct 10, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE JVM1440BD Microwave hood lights don't work
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
If your relay is bad and you want to replace it yourself, it is part # 3501-001050 and you can find helpful exploded view diagrams of your microwave and order that part here.
Be sure to also do any needed circuit board repair with 30AWG wire to prevent it from doing worse damage if another bulb shorts.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. Miller
Jan 09, 2009 | GE JVM1441 Microwave Oven
Microwave Ovens Logo
314 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
