Question about Garmin Rino 120 2-Way Radio
Menu send note missing
I 4 pcs Rino 120 that have different programs installed version 3.9 and 5.5
I get up its menu for Mark Waypont-Fin `N Go-Enable Keylock but Send Note missing on the two radios that have version 3.9
It works quite nicely for those who are running version 5.5
I have tried and install 5.5 on those with a 3.9 but it is not possible
I have run web Update but it changes nothing.
So now, I hope you have a good explanation of this issue and have a solution that allows me to send messages with them?
  • 1 more comment
  • jorgen1920 Aug 09, 2008
    I can not updated it from 3.9 to 5.5 this is not possible!
    The only one I have the opportunity to have been and install v3.9 again, but I have tried, it is not helpful.
    The advice I have received have not helped me.
    Send note should also work in v3.9
    All four are completely new and makes it softver version 3.5 for those I do not get the menu send note
    Should it be possible, and upgrade from v3.9 to 5.5?
    No it was not the
    Genius:
  • 1,011 Answers
Dear Sir/Madam,
When you send a note, it appears along the bottom of the display on every Rino 120 user who is using the same Channel and Squelch Code that you are using.
Make sure other radios are on the same channel and Squelch Code
Thanks
good luck
Posted on Aug 09, 2008
    Master:
  • 521 Answers
  • 594 Answers
When you do updates it might have taken off the message option. it is just like a computer when you upgrade it will take off old programs and install the new ones... so you might check into that...
2 Suggested Answers
vrc_tech
  • 109 Answers
SOURCE: Rino 120 Send note
This sounds like the new firmware version may not work on the
older model.
The best solution would be to contact Garmin
Product support at (913) 397-8200 or 1-800-800-1020
Monday - Friday, 8am-5pmCDT or by email at sales@garmin.com
Pat
Posted on Aug 21, 2008
Master reset xerox 8560 printer
Your Administrator Guide book should have these instructions listed for you. It should be on the CD's that came with the printer.
If you have lost/misplaced them, you can download the guides from the Xerox.com website.
The steps below are what I did from my laptop as a Repair Technician:
1. Connect a crossover cable between the PC and system. To print an Event Log or Runtime Log:
2. Verify the system is Ready.
3. Use the system's control panel to enable AutoIP:
a. Select the system Setup menu.
b. Select the Connection Setup menu.
c. Select the Network Setup menu. 5. The page should now print.
d. Select the TCP/IP Setup menu.
e. Set AutoIP to On.
f. Exit the menu so the system is Ready.
4.
NOTE: To print the Connection Setup or Configuration page, select the system Setup
menu.
Reset the system to cause AutoIP to assign a new IP address (cycle power or select
Restart system from the Shutdown menu).
5. After the system's IP address is set, test communication by sending the "PING" com-
mand.
6. If the test fails, install a different cable and retest.
Sep 27, 2014 | Xerox Phaser® 8550, 8560, 8560MFP Extended...
I am using samsung s duos.Amdroid version 4.0.4.Previously I used to receive gmail notification when the phone was connected with internet but suddenly stopped getting gmail notification.I want to enable...
Try these solutions:
1. Go to settings > accounts > Google > **your email**@gmail.com > Enable Gmail sync
2. Settings > Mobile Data > Gmail > Restrict access disabled
3. Settings > Mobile Data > (menu button) > Enable Sync
4. Settings > Applications > (scroll right to all) > Gmail > Show Notifications enabled
5. Gmail > (menu button) > Settings > **your email**@gmail.com > Enable Notifications and enable Sync gmail.
*Note that I'm using a dutch language on my phone so the terms I used are guessed translations, actual buttons might have a somewhat different text on your phone.
Mar 18, 2014 | Samsung GT-S7562L Galaxy S Duos With Dual...
I want ti install JDK version 1.5
1.Remove the previous version of Java installed on your computer by selecting "Start->Control Panel->Add/Remove Programs" from your computer's Start menu. Then, choose the Java program in the program listing and select the remove icon.
2. Uninstall Quicktime from the Add/Remove Programs menu after Java is uninstalled. In past versions of Quicktime, it has been known to interfere with new Java JDK installations.
3.Download JDK 1.5 from the link listed in the Resources section of this article.
4.Choose the installer program after download is complete and choose the default menu options displayed by the installer to install the JDK to your computer. Restart your computer after installation is complete and you will have JDK 1.5 installed on your computer.
Feb 21, 2011 | Computers & Internet
New computer with 64-bit...can't install my current version of Compton's Interactive Bible. Is there a fix available
Install it in compatibility mode as an administrator.
1. Right click on the program's shortcut, .exe file, or installation program.
2. Click on Properties.
3. Click on the Compatibility tab.
4. To Run a Program in Compatibility Mode -
NOTE: Runs the program using settings from a previous version of Windows. Try this setting if you know the program is designed for (or worked in) a specific previous version of Windows.A) Check the Run this program in compatibility mode for box. (see screenshot below)
B) Click on the drop down menu arrow and select which version of Windows the program was made for. (see screenshot below)
NOTE: Always pick the latest Windows version the program was written for to have a better chance of it running properly in Windows 7.Check run as administrator.
Aug 31, 2010 | The Learning Company Compton's Interactive...
Want to use my rhino 120 with military maps
It can show this by going into the the menu [second icon] setup map, orientation/ grid setup. Change Lon/Lat Grid to On.
Apr 19, 2009 | Garmin Rino 120 2-Way Radio
Screen goes blank except a thin line
There is a firmware upgrade from Garmin that appears to address this problem for units still running Version 3.2 or earlier. If your problem only occurs when WAAS is enabled, you might try upgrading. To find what firmware version you have, from the main menu: Setup, System, then select the (options) icon on the top row, to the left of the 'X'.
Nov 24, 2008 | Garmin Rino 120 2-Way Radio
Rino 120 - Disabled WAAS
Have you upgraded from Software version 3.2? Version 3.3 addresses a memory overflow problem when receiving two or more WAAS satellites.
Oct 04, 2008 | Garmin Rino 120 2-Way Radio
RINO 120 :: screen blanks out with just a single horizontal line
Had to wait 24 hours to be able to post my own answer
By reading a number of forums, I've found that there was a WAAS satelitte update (bug), that causes this foul up.
The only solution I've been able to arrive at is DISABLE the WAAS feature, as no Garmin Update/patch (for Rino120) has been made available.
To shutoff the WAAS feature press your [Page] button until you arrive at the "Main Menu"
go down until your on the "Setup"(hammer)
go in (by pressing in, on the directional button)
go down until your on the "System"(gears)
go down until your on WAAS, go in and select the Disabled
go up to the "X" (top right) press it, then you can [Page] button anywhere you want from there.
Wonder what WAAS is?
http://www8.garmin.com/aboutGPS/waas.html
Take care.
PS- Garmin if you read this....I would like to have my WAAS back, and since I registered for updates, back in 2005, why didn't I get an email from you telling me about this issue (when it happened and provide a solution - at the same time :: even a work around as I've posted here)
Oct 02, 2008 | Garmin Rino 120 2-Way Radio
Heya I have problem for watching the vedios on youtube. I dont know how turn on the java ,and also have problem for installing the new version of adobe flash player.Dont know want to do. Can u help...
dear donya, Internet Explorer 7 To enable or disable Java:
  1. From the Tools menu, or the Tools drop-down in the upper right, select Internet Options... .
  2. Click the Programs tab.
  3. Click Manage Add-ons.
  4. Highlight Java Plug-in.
  5. Under "Settings", click Disable.
  6. Click OK, and then OK again.
To enable or disable JavaScript:
  1. From the Tools menu, or the Tools drop-down in the upper right, choose Internet Options... .
    Click the Security tab.
  2. Click Custom Level... .
  3. Scroll to the "Scripting" section of the list. Click Disable or Enable.
  4. Close and restart your browser.
Internet Explorer 6 and earlier
  1. From the Tools menu, choose Internet Options... .
    in version 6, click Custom Level... .
    • Java: Scroll to the "Java" section. (In version 6, you will find this section under "Java VM", under "Java permissions".) To disable Java, click Disable Java. To re-enable Java, click a different setting, such as High Safety or Medium Safety.
      JavaScript: Scroll to the "Active scripting" section of the list. (In version 6, this is under "Scripting".) Click Disable or Enable.
  2. Close and restart your browser.
download latest adobe flash player and install.
if u r using ie6, try to upgrade it ie7.
thanks,
Sep 25, 2008 | Computers & Internet
Rino 120 Send note
older model.
Pat
Aug 09, 2008 | Garmin Rino 120 2-Way Radio
Garmin Rino 120 2-Way Radio Logo
Top Garmin Radio Communications Experts
eradiostore
eradiostore
Steve
chris
Are you a Garmin Radio Communication Expert? Answer questions, earn points and help others
