Wd 860 hotpoint washer dryer heater
How do i get to the heater element to replace it? ( the heater to heat the water, not the dryer element ?
    President:
  • 1,462 Answers
Take rear bottom rear panel off. you will see heater slightly towards the rhs held by 1 10mm nut in centre. loosen nut and prise out. why do you want to replace it as obviously you haven't tested it?
Posted on Aug 09, 2008
Hotpoint wd420 shows error code f13 after replacing heater element for dryer.
Change electronic board it is what will cause this problem if you checked all ducts an fan and still heats board is bad
Oct 28, 2014 | Hotpoint Ariston Aquarius WD420 Front Load...
Hotpoint WDD960 Washer Dryer - no error code but whenever I put it on a dry cycle it just spins as if working but without actually drying. Any suggestions?
Sounds like heating element is not coming on ..Heating first then with a Fan motor running and water flow the steam that is produced by the heaters are changed to water by the cold water over a condenser , the pump then puts his out to waste..
Jan 28, 2011 | Hotpoint Washing Machines
I have a Hotpoint Aquarius WD420 washer/dryer that is not heating the washing water, yet does heat when in drying mode. Does the machine use the same heating element for washing and drying, or are there...
There is a seperate element for the water heater. so likely to be a faulty heater or thermistor which is fastened toi the element
You really need a test meter to determine which part is faulty.
Dec 27, 2010 | Hotpoint Washing Machines
Problem with hotpoint as66vvxna1 dryer
There are a couple of things that you can check. FIRST go to the electrical box where the circuit breaker or fuse for the dryer is. Sometimes on half of the circuit breaker is tripped allowing the controls of the dryer to work, but not the heating element. Turn off the breaker and turn back on. Or replace the fusees. If this does not work, then you may have a loos wire or a burned out heating element. Sometimes there is a bad high temperature switch. Do the circuit breaker or fuse first. If the washer did not spin out the water well enough, the water can short the element to trip the circuit breaker or blow a fuse.
May 26, 2010 | Hotpoint Ariston AS66VXNA1 Electric Dryer
Tumble dryer isn't woking
You may need to replace the thermostat or the heating element.
Apr 13, 2009 | Hotpoint -Ariston Aquarius WD645 Front...
Dishwasher Hotpoint 7885 Aquarius Ultra Plus
sounds like the heater for sure. engineer job.
Jan 25, 2009 | Hotpoint Aquarius WD640 Front Load...
Hotpoint WD 865- washes ok, dryer won't work makes loud popping
sounds like the dryer heater element has worked loose perhaps and shorted out against the metal dryer box which sits on top of the drum.
best to get an engineer out i'd say.
Jan 14, 2009 | Hotpoint Aquarius WD63 Front Load...
Test
Hi i have a hotpoint wd 860 washer dryer the display is showing f 08 heater relay cannot be activated.can you please tell me how i can fix this problem myself.Thank You
Jan 04, 2009 | Hotpoint Ultima WF860 Front Load Washer
Washer dryer not heating up
If your dryer won't heat up, it's possible that it is not being supplied with the proper voltage. Here are three ways to make sure power is getting to your dryer: First, make sure your dryer is plugged in. Next, check the circuit breaker panel to make sure all the circuit breakers are in the correct positions. Finally, check to make sure no fuses in your fuse panel are blown. Any of these could explain why power is not getting to your dryer.
Oct 20, 2008 | Washing Machines
both the 'wash' & the 'dryer' have their own heating elements, If the 'wash' completes its full cycle including 'spin', then I suspect this heat element is ok.Re the dryer, most likely the heat element circuit is 'open circuit' somewhere, could be  the element, thermal fuse, thermostat, or a wire burned out
Oct 23, 2007 | Hotpoint Aquarius WD640 Front Load...
Washing Machines Logo
96 people viewed this question
Top Washing Machines Experts
