Question about Hitachi 50V500 50 in. HD-Ready LCD Television
Hitachi 50SBX78B TV comes on and immediatlly goes off. Fuse ok.
  • 4 more comments
  • cha_whiz Aug 12, 2008
    I have the 50v500 the power, heat and lamp lights blink at the same time upon start for about a minute then the engine shuts down afterwards the only light remaining on is the lamp light. There is no sound or picture just the motor or fan noise when I turn on the tv .. Tech said it could be the ballast or the temp gauge after a brief examination of the lamp. No major diagnostics have been performed.
  • newyorker_74 Aug 13, 2008
    yes that's exactly what is happening to my TV
  • egear00 Aug 14, 2008
    Hi. I have the same problem as this. TV powers on, both fans come on briefly, and the bulb comes on also. Screen flickers for a moment, then everything powers off. Once off, the TEMP light blinks. I have replaced both fans, and also replaced the Power P.W.B. board. What should I look at now?
    Thanks for any help!!
  • Anonymous Aug 15, 2008
    HHMMM...I would like to update my problem, I hope that by doing so it will be easier for one of you experts to help with this problem.
    When I turn it on, all of the LED's turn on, but in a few seconds when the TV powers itself off...the green LED at D913 stays on. All of the others turn off. It will stay on until you unplug the power from the TV.
  • Anonymous Dec 13, 2008
    I HAVE A HITACHI 60V500A AND I HAVE A PROBLEM..AS I TURN THE TV ALL THE LIGHTS BLINK THE POWER TEMP AND LAMP..AS IT CONTINUE BLINKING THE TV POWER OFF AND ONLY THE LAMP LIGHT STAY ON..
  • CHINITAMOREN Dec 13, 2008
    I HAVE A HITACHI TV 60V500A AND I HAVE A PROBLEM..AS I TURN THE TV ON THE POWER BUTTON THE LAMP AND THE TEMP BLINKS ALL AT THE SAME TIME AND A FEW SECONDS IT TURN OFF BUT ITSELF..BUT THE LAMP BUTTON IS NOW NO LONGER BLINKING BUT ON..
    Problem Solver:
  • 3 Answers
Hello Ecollier2012,
I have a Hitachi 60v500a with that has that same type of problem (comes on briefly then shuts off), and the green LEDs on circuit board light up for a few, then turn off (except D913, which stays on), would one of those repair kits work for this unit?
Which board is the blown cap & pico fuse on?
Thanks!!
Posted on Nov 05, 2008
  • Hitachi Master
  • 3,459 Answers
If you have Hitachi model number 50UX58B, 60UX58B, 50UX58K, 60UX58K, 50SBX78B or 60SBX78B and you have the following symptoms you may want to grab a repair kit from www.TvRepairKits.com. They have put together a kit that includes the parts and instructions to fix these models. This is a fairly common problem with the above model numbers. It is typically caused by a blown capacitor and pico fuse. Again, you can get a kit from the above address.
Here are the symptoms...
Primary Symptom: No Audio or Video. Power light will come on briefly then shut off.
Other Possible Symptoms : The green LEDs on the circuit board light up for a few seconds then turn off.
Hope this helps,
Posted on Nov 02, 2008
  • 927 Answers
Good Day, dpmc;
There are many items in the TV that can cause this concern. CAN you repair it if I guided you through this??? I will..... If not call an authorized service center and get an estimate of the cost of repair.
Come back on this sight and I will help you further in detail.
Good Luck, big IRISH.
Posted on Aug 12, 2008
I have the same problem as above. I have a Hitachi 50SBX78B and it was working great until some water from the plant on it got into the screen. Now the red light comes on for a split second, then goes...
Unless the main board is checked the damage to the board cannot be accessed. so open out the set and check on for any failure of fuse or fusbile resistors that could have opened out with the water shorting.
If water is still found use a dryer to warm off the moisture.
It area of the water spill must be checked for the possible damage
Sep 15, 2010 | Hitachi 50SBX78B 50" Rear Projection...
Green leds turn on momentarily when first plugged in then shutoff
ok , on hitachi pro tv is very common with bad power supply u may want to replace the voltage regulator which is next to the fuse u already replace , also loose connection on all the power supply seccion , also u may want to check the resistor close by the convergence ic 2.2 ohn if this are smoke replace stk392-110
May 07, 2009 | Hitachi 50SBX78B 50" Rear Projection...
Hitachi tv model 50ux58b starts to come then goes off
Hope this helps,
Nov 07, 2008 | Hitachi 50UX58B 50" Rear Projection...
Tv dead
hello. the loud pop you heard was .maybe a fuse.? u need to uplug .!!! the set !!!. and take off the back and see if fuse is bown.? ok let me know.!! ok
Jun 02, 2008 | Hitachi 50UX58B 50" Rear Projection...
Tv will not power on
Hope this helps,
May 01, 2008 | Hitachi 50SBX78B 50" Rear Projection...
My tv will not power up?
Hope this helps,
Mar 14, 2008 | Hitachi 50SBX78B 50" Rear Projection...
Hitachi model #60SBX78B
The green led or lights on the board indicate some of the power supplies are working. The key is do you see any come on and then go out. this would indicate which part of the power supply is failing. also there are fuses in the set that do not look like your standard glass fuse. WARNING television generate lethal voltages that will hurt you. extreme care should be used.
Jan 18, 2008 | Hitachi 50SBX78B 50" Rear Projection...
No power
You need to check E991, E994, Q777, for more info ctechnicians.com
Jan 09, 2008 | Hitachi 50SBX78B 50" Rear Projection...
Hitachi 50ux58b
Hope this helps,
Jan 02, 2007 | Hitachi 50UX58B 50" Rear Projection...
Hitachi 50V500 50 in. HD-Ready LCD Television Logo
352 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
